Question about Maytag PGR5710 Performa Gas Kitchen Range
Oben takes half an hour to heat up
I have a Maytag, MGR5710ADW. I took off the bottom insulated cover to check the ignitor. The ignitor turns red and about 60 seconds or so the oven lights but it takes 30 minutes for the oven to get to 350 degrees. I am suprised how little flame there is in the bottom of the oven. Can my ignitor be going out? I do not have a problem with the burners so does that mean my gas valve is ok?
  • 4 more comments
  • proudfrog Jan 28, 2008
    Anyway of testing the gas valve or unlocking the orifice?
  • proudfrog Jan 29, 2008
    Is it possible to test the pressure myself? What can of tool do you need and how do you do it?
  • aswaneck Mar 31, 2008
    I am having the same issue with our MGR5710ADW Maytag gas range. I called a repair man since I cannot find a solution. We turn on the oven and the flame ingnites, but it is very low and takes 30 minutes to get to 300 degrees.
  • lukeyolds Apr 12, 2008
    same problem, only mine takes almost 90 minutes to reach 350 deg. HELP!!!
  • marcekb Mar 10, 2009
    Same problem -- takes 45 - 90 minutes to preheat between 350 and 450 degrees. When I smack the (valve?) box at the back of the oven where the gas flows into the oven, it supplies lots of gas for a short period and then either stops or restricts the gas again. I can hear it trying to allow gas, and sometimes it can get a full opening, sometimes restricted. I pound again, and it opens full for a short time. Doesn't sound like a blockage, but I don't know for sure. Ideas?
  • Anonymous Mar 16, 2014
    I would like to remove the bottom oven panel in my maytag MGS5870 gas range so that I can check the ignitor. Where are any screws located? The back seems to pop up and it slides around, but I can't get it out.
  • 63 Answers
I doubt its the igniter. It could be a faulty gas valve or maybe the orifice is blocked, and not letting enough gas into the burner
Posted on Jan 28, 2008
  • Daniel Phillips
    Daniel Phillips Jan 28, 2008
    It would be a rare occurrence for the orifice to get dirt or something in it and block it. With out a gage to test the gas pressure it would be difficult to test the gas valve for proper pressure. You might have to call a repair man for this one.
Our oven has been very slow to preheat and today it barely heated but when it did, it wouldn't keep the temp. Plus there's an low odor almost like gas when it's on. Model # MGR5710ADW, serial#...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 06, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
Pre heating oven takes 45 minutes to an hour what part would be needed
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 01, 2011 | Maytag CWG3100A Gas Single Oven
My Maytag Gemini cooktop and top oven work. The bottom oven will not heat up past 100 degrees. What is the problem?
Replacing the ignitor is not difficult or dangerous. To get at it, you will first take out the racks. Then undo the box-like cover inside the bottom of the oven; the screws face front. Underneath that is a wing-shaped cover, held in place with wingnuts. Remove it.
The pipe that the gas comes out of heads straight back; the ignitor is just to the left. You'll be able to see the wires going out the back of the oven. Remove the plates that hold the tube/ignitor combination.
Once the pipe is free, then get your head out of the oven and pull out the oven so you can see, and get at, the back. On the lower left is a cover, about 12 x 15 or so, held in place by four screws. Remove it.
At this point you can see where the ignitor connects to the orange wires (at least mine are orange) with a plastic connection. Undo that connection.
Viola! You have removed the ignitor! Now, before you forget, make a diagram of everything you did. Put the screws in separate plastic baggies, with paper number tabs that correspond to your drawing. This will greatly help in putting everything back together.
Dec 12, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
My Maytag model no. MDG6200AWW will not ignite. Gas is on; electricity is OK; dryer acts like it's on "air dry" when it is on "regular" setting. Can I repair on my own?
It sounds like you could have a ignitor issue. Usually there is a small plastic plug located at the bottom right of your dryer in which you can view the ignitor in action. if there isnt a plug you will have to first take off the door by removing the hinges. after the door is off there are two screw at the bottom of the front access panel remove them and your panel should lift out from the bottom. once this panel is off you should again be able to see the ignitor in action. turn your dryer on a normal heat setting and wait for the ignitor to come on, if it glows RED hot the ignitor is NOT good. if it is burning WHITE hot you do not need to replace this, ignitor part number is 304970. hope this helps
Thanks
Oct 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Waring Waffle Maker no heat
Remove 4 Black Phillips Screws 2 on the front near the handle that flips Use a Good fitting Screwdriver These screws have a thread locker on them. They will strip the heads out if proper care is not used when removing them.Then remove the two screws at the rear of the Iron Just rear of the cooking surface. This will remove the chrome cover on the bottom of the cooking surface exposing the wiring. The thermal fuse is located under a section of insulation under a clamp held in by another Phillips screw.Do not cut or Damage the insulation. Gently pull it back exposing the fuse. After replacing the fuse, insulation ,Clamp and screws check to be sure the iron heats and cycles on and off and the ready light works properly. If it does not cycle the new fuse will blow . Good luck
Sep 22, 2009 | Waring WMK300 Professional Belgian Waffle...
Gas dryer won't heat with cover off
The 2 coils on the gas valve , need to be replaced . After the dryer runs for a short time , the coils get warm from the electricity going thru them . The weaker valve , shorts internally , not letting the gas go thru . After the dryer cools down , and the coils cool down , then the short will close ( giving continuity ) , until they warm up again . If you had given the model number , I would have given you the part number .
Sep 17, 2009 | Maytag Dryers
Oven heats very slowly
If your top burners work ok, regulator should be ok. Majority of times the fail part in the oven is the ignitor...turn oven on and check for a flame after 10 mins. small flame could mean a bad safety valve.
Jun 09, 2009 | Maytag MGR5870 Gas Kitchen Range
Oven heats to 185 degrees in a hour on preheat
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Mar 23, 2009 | Jenn-Air JGW8130DD Gas Single Oven
I have a maytag MGS 5770 ADA range/oven. The oven does not heat. The top burners and broilers work fine. However, the bottom oven burner doesnt kick in. the igniter glows red hot but the gas never...
I would start by replacing the ignitor. It could glow enough to light the oven, but to maintain the burner, it often re-ignites several times during a cooking cycle. I have had the problem before, replaced the ignitor and all was well. You should be able to find an ignitor for under $40 online. Just google 'Maytag oven ignitor' and you should find many offers. My sister just bought one for $19.99!
Mar 15, 2009 | Maytag MGS5770 Gas Kitchen Range
Bottom oven does not heat up, top oven works
the most common problem for your description is that your bottom ignitor is not working properly just because the ignitor glows doesnt mean your ignitor is working it has to draw 3 amps or more to ignite the bottom burner part number for the ignitor is 12400035 let me know how you make out
Aug 08, 2007 | Maytag MGR6772 Gemini Gas Kitchen Range
Maytag PGR5710 Performa Gas Kitchen Range Logo
437 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
