Question about Pioneer DVR-640H DVD Recorder/HDD Recorder
Tuner doean't appear to be using 525 NTSB setting for auto channel tuning
Got unit for x-mas. Still doesn't work right. This is a mutli region unit but seems not to have any NTSC-M. Have system set to 525 but seems to tune and set channels using 625 with its "auto scan" feature. "Auto Tune" results is horibly fuzzy presets. Then going to to manual tune feature results in availability of manual tune "windows" where you can change the channel system, but only offeres UK&IE, Fra, Western Europe, and Eastern Europe which are 625 areas. All channels tuned are still very fuzzy even after adjustment of AFT. No sound is present and Sound System selection availability in the same manual tune area is I, L, B/G, D/K which are 625 ITC broadcast codes. Listing of tuned channels preview shows nothing but I and B/G. The AV2/L1 input is set to NTSC as well as L2 and L3. No matter what I do, it seems like this thing is trying to use 625 tuning. Unit plays DVDs fine. Unit is DVR-550H but this format only lists similar 640H. I am pretty A/V savy, have reviewed the operators manual indepth but making little progress. I can see why people go Tivo. Help!
  • 1,512 Answers
It certainly looks like it should work according to the manuals. There are firmware updates available for this unit. Or you may have to take the unit to a pioneer agent to have it sorted.
The tuner may be faulty also. The agents would be able to check this for you. You could try to get to the source direct
Posted on Jan 28, 2008
  • Graeme Ross
    Graeme Ross Jan 28, 2008
  • Graeme Ross
    To check and install a new firmware just follow the six easy steps below:
    1. Check the current Firmware Version:
    • Switch on your DVD Recorder
    • Select "Home Menu"
    • Select "Initial Settings"
    • Select "Audio Out"
    • Select "Dolby Digital Out"
    • Select "Dolby Digital" and push the "9" button on the remote
    • Remember, you'll only need to update your DVD Recorder if the FW version is lower than the version mentioned in the download table.
    • To return the DVR to its normal operating state, press the Home Menu button on the remote control.
    2. Download the Update:
    • Click on the filename in the above download table to start your download
    • If your browser does not automatically start the download process, be sure that your browser or security software is set to allow downloading of files from this web site.
    • You can also right-click the button and select "Save Target As" to start the download process.
    3. Check the Firmware File
    • Check the file size (see table) of the downloaded firmware file by right-clicking on the file and selecting Properties. (Download again if the file size is incorrect.)
    4. Decompress the file
    Once you have downloaded the file to your computer, locate the file on your hard disk drive and double click the file to decompress it. (If you do not have a decompression utility installed on your computer, you can easily download one for free.)
    5. Create the Update Disc
    • It is important to use a good quality branded blank CD-R disc or completely erased CD-RW disc.
    • Create the update disc by burning the file to a CD-R or CD-RW disc.
    • Burn the decompressed file to the disc using disc-at-once mode (2x Speed) and ISO 9660 CD-ROM file system format. (The player will not recognize the update disc and the update cannot be performed if the file is not burned correctly to the disc.)
    • Make sure that the disc session is closed / the disc is finalised.
    6. Update your device
    • Update the firmware using the CD-R or CD-RW disc containing the firmware file.
    • Perform the update following the procedure given in the PDF DVD Recorder Update instructions.
    • Note: Do not turn off or disconnect power, or remove a disc while the update is in progress
  • 1,067 Answers
Do they have firmware update online for it at ther website
  • nick helpap
    nick helpap Jan 28, 2008
    ya try that firmware update 1st should help alot on that issue
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
Check and replace its main system control memory IC. If this IC is faulty, auto tuning will not work, or, the TV will store any received channels. If the TV do not tune into channels too, the AGC voltage to its tuner, and tuner itself should be checked.
May 27, 2013 | TCL L32D20
Cant tune in any channels
Look to see if set functions via rear audio/video inputs--if no channels either not hooked up right, no signal, or a bad tuner.
Using rear inputs will bypass the tuner in the set.
Jun 16, 2012 | Televison & Video
How do i tune the channels on a toshiba rc3910
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
Jul 10, 2011 | Toshiba Televison & Video
We can't get any of the channels don't know where to start from menu area
You just do autotune to receive all channels. In this mode TV will tune through the entire channel band automatically, and finally will stop tuneing, and will show the first channel receved. You must be patient for these time. about two or three minutes, without disturbing is process. The tuning process follows.
Auto Tuner Setup
In Auto Tuner Setup, the TV automatically scans
t h rough all available channels, memorizing the active
ones and skipping over blank ones or channels with
weak signals. This means when you scan (using the
CH A N N E L +/- b u t t o n s ) you will receive only clear,
active channels
P ress the ME N U b u t t o n
Press Right or Left button to operate
Press Vol+ or Vol (--) to choose CABLE or AIR
Press UP or DOWN button to move to START
Press Right or Left Button to start Auto Tuner Setup
Tv will show "NOW PROGAMMING" display.
Programming will take approximately 1 to 2 minutes.
After all it will show
Some cable systems experience interference from radio frequencies on cable Channel 95. You may delete this channel from
your scan by removing the "X" next to it on the Channel Summary screen.
Nov 29, 2010 | JVC AV-27120 27" TV
There is no local channel,cable only international..i lost my manual,
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
VCR tuner cannot tune in my cable channels
It is working as designed. The purpose of your cable box is to take in a wire containing all of the possible channels you might watch, and then extract *one* channel, and force it to appear as channel 3. If you connect the cable directly to the VCR, then the VCR's "tuner" (ie, channel selector) has an opportunity to extract any channel it wants. But... as you point out, your VCR won't be able to "see" any of the digital channels. So... if your goal is to be able to watch any of the digital channels, the signal must pass through your cable box, which will put the selected channel on channel 3. There is no value in going from the VCR to the cable box, since the VCR's tuner will have already filtered out all but one channel. It would be helpful to make a list of what your useage goals really are, since there are so many different ways to hook these things up. Are you interested in: - watching digital channels? - recording digital channels? - watching one channel while recording another? - using higher quality video signals (composite, s-video, component, etc) rather than RF (ie, channel 3) And so on. Keep in mind that you have *three* tuners: Your cable box, your VCR, and your TV. It sounds like only your cable box can tune in the digital channels. If your cable box puts out any non-RF signal, then the best choice would be to go: Coaxial Wire -> Cable Box -> Video Connection -> VCR -> Video Connection -> TV, with the VCR and the TV both set to "video". Then you would only use the cable box as a tuner, the VCR would only see the tuned channel (via video in), and the TV would see the same channel (or whatever tape you are playing) on its video input.
Mar 29, 2007 | Zenith VCS442 VHS VCR
[MSI 8606 TV Tuner Card] Can't get a picture
here is a link for the driver,
Mar 10, 2007 | MSI 8606-020
Pioneer DVR-640H DVD Recorder/HDD Recorder Logo
212 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
