Question about Linksys Wireless-G WRT54G Router
Router wireless my wirerless router will not work on my lap top[ my lap top works at all hot spots
    Novelist:
  • 113 Answers
Do you have the router setup to provide either WEP or WPA encryption? If so, you will need to provide that Encryption key (think password) for your SSID (the wireless network you connect to).
If you then can connect to the router, but still can't get on the Net, you may need to go into the Advanced settings of that particular wireless network (Windows XP - open Available Wireless Networks, and click on the last item on the left Advanced Settings - then click on the 2nd tab - Wireless Networks - pick your network in the box at the bottom, and change one setting from "Open" to "Shared". You should then be able to connect properly.
Posted on Jan 28, 2008
Net gear box won't connect wirelessly with my lap
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | NetGear WGR614 Wireless Router
What do I need to make a wifi hot spot for my lap
In order to create an effective Wi-FI hotspot in your home or place of business you will need the following:
1.) A broadband internet connection, such as DSL or cable.
2.) A wireless router, Linksys makes a decent one but the brand is not really relevant for our purposes.
3.) Your laptop must have a wireless adapter on it. If it did not come with one, you can purchase one that will plug in to a USB port.
4.) That should do it, though configuring one can be tricky if you've never done it before. Post if you need some more help with it.
Oct 10, 2009 | Computers & Internet
Have 2 lap tops,1 desk top. Desk top and 1 lap
For the 2nd laptop, first upgrade the LAN card driver, then reinstall the driver if the problem is not resolved with the driver upgrade.
Hope this helps.
Aug 29, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Can"t get wirerless to pick up from router
  1. can your laptop connect to other wireless networks? if not, the laptop's wireless may be the issue.
  2. if yes, it's possible that the router has the wireless functions turned off, or is set to not broadcast it's SSID (network name). Check these settings, or just press and hold the reset button until the power led goes out. After resetting the router to factory settings, it should broadcast the name "Linksys'. If still no good, it's likely that you have a defective router.
  3. As a last resort, plug an ethernet cable directly from your pc to the router and see if you get an ip address and can get to the web. If this works, log into the routers web interface by typing in 192.168.1.1 in the address field ofyour web browser and look at the wireless settings.
  4. If nothing still, contact linksys......let me know if I can provide any other suggestions.
Aug 08, 2009 | Linksys Wireless-G WRT54G Router
Although cable to desktop connects to internet, my router from desktop to laptop via router won't connect.
Desk top to internet is OK.
How about Destop through Router connection to Internet OK?
Assuming you want to connect wireless from Lap top to Network, need to configure correctly for wireless in Router.
If you connect Lap top to router by wire and it didn't work that mean your router is bad.
Jul 03, 2009 | Linksys WRT160N Wireless Router
Wireless WRT54G
Considering there are problems on the two computers it shouldn't be the wireless system. It may be the router or what's feeding the router. Cabling is always suspect. Whatever is feeding the router may need to be reset by a power of and on cycle. So I would unplug the router and equipment feeding the router and turn off the computers and wait 30 seconds and start with the device feeding the router, the router and then the computer directly wired to the router. If there is a problem still call your internet service provider.
Sep 17, 2008 | Linksys Wireless-G WRT54G Router
Need help getting wireless netgear to work with lap top. Lap top was reconfigured and don't have old password.
If you don't have the wireless password for your wireless connection. The thing to do is log into the Router's webpage via the Router's IP address. From there you can go to the wireless section and in most routers this section shows the wireless password.
If you have trouble getting on to the Router's webpage. Just comment back on this and I can probably step you through it.
Aug 16, 2008 | Computers & Internet
How to set up router with a lap top
well you will have to setup the router to run on ethernet, perform a mac clone for your cable modem then setup the wireless.
Aug 14, 2008 | Linksys Wireless-G WRT54G Router
Cant go wireless
I think the problem is not your laptop configuration. Can you check the setup configuration of the router it's maybe the wireless function is disable. Or try to reset the router to his default configuration. Press the reset bottom of the router for 15 second then try to connect your wireless connection if still not working setup again the router configuration.
thanks
Apr 15, 2008 | Belkin (F5D5231-4) Router
Lap top problem
Wireless network adapters require an associated wireless receiver (such as a wireless router or wireless access point) to recieve the radio signals from the adapter and eventually route them to a wire and in you case it would be the wire providing internet services to your desktop computer. If there is no wireless receiver there is no device to convert the radio communications of the wireless adapter and rout those signals to the internet.
I hope this helps.
Dec 08, 2007 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
79 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
