Back to:
Tags:
Onkyo TX-SR605 7.1 Channels Receiver
Searching Signal (by 2 users)
posted by perrie on Jan 28, 2008
I have FTA Reciever that showed is Searching for Signal and noting else in the Screen,but the Channel Number it showed and that was the Channel for the Oversea. I can not go to CNN Channel or others. I have VIEWSAT PVR 7000
perrie
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 18, 2008
VIEWSAT ULTRA 2000
Solution #1
posted on Feb 27, 2008
Not Rated (0)
clusterfx
Rank:Guru Guru
Rating: 90%, 84 votes
you have to upgrade the firmware & key codes and i am assuming your satellite is working and pointing at the right direction
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Searching Signal:
I don't want to Accept this solution
Can you Help with these Receivers problems?
I have got an Onkyo TX-SR606. It is about 4 weeks old and...
I am having problems setting up my system. Once a connect...
can you please help how can i hitch my sub to a remote...
what should i set db and distance in mt onkyo 898 integrra...
My room size is 16ft.1" X 17ft.3".00. Hight is...
Loading problems.
Repair Service
Find Receiver Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
