Question about Canon ZR65MC Mini DV Digital Camcorder
NTSC ZR65 MC
It has stopped working i charge the battery dosent turn on i plug it in to the wall works and show a canon sign and stays on for about 1 min.
  • kylemhall May 27, 2008
    Worked fine, plugged it in to charge overnight.
    Battery is fully charged ( tested it with a multimeter ), but camera does not get power ( won't even eject tape ). With AC Adapter, it works for a few seconds, shuts off, comes back on, shuts off, repeat ad infinitum. Should be noted that the AC Adapter is generic aftermarket one, should be 8.4 volts, but putting out about 8.7. Fully charged battery puts out that much so I don't think it's a big deal, unless the extra voltage has burned out something in the camera.
Can this camcorder (canon ntsc zr65 mc ) can the video be downloaded to my mac laptop?
Posted on Feb 17, 2010
I have a one outlet utilitech timer and forgot how to set it ....help
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Steps:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
Nov 27, 2010 | Day-Timer Hardware & Accessories
Tip
Canon Powershot Cameras With Pink/Black Display or Images w/Odd Lines on LCD
This is almost always a malfunction with the CCD Image Sensor. Canon openly acknowledged fault in the matter and will repair the camera free of charge + they pay the shipping costs.
Affected products:
- Camcorders: ZR60, ZR65 MC, ZR70 MC, ZR80, ZR85, ZR90, ELURA 40 MC, ELURA 50
- Digital Cameras A60, A70, A75, A300, A310, S230, SD100, SD110, A40(*), A80(*), A85(*), A95(*), S1 IS(*), S60(*), S200(*), S330(*), S400(*), S410(*), S500(*)
*Models added as of Oct.31, 2006
If your model number Is included in the list, follow this link for all of the information you need to obtain this free service:
SERVICE NOTICE: CCD IMAGE SENSOR ADVISORY
It is a simple process & I know that you will be very happy when the camera comes back in perfect working order!
on Nov 12, 2008 | Canon PowerShot A300 Digital Camera
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
I have a pair of sp10 and having trouble charging them and the batteries are new and when i put them in the charger i have to turn them on for the chargeing light to come on is this normal or are the...
You do not mention if you are using a wall plug charger, or a drop-in charger. We will give troubleshooting tips for both. To answer your question: If the light comes on and stays on, on the charger your charger is good. You have a radio or battery problem.
Wall Charger:
The light on the HTN8232 wall charger should come on and stay on when plugged into the radio, with the radio turned off. The fact the light comes on when the radio is turned on indicates your batteries are either no good, too low to charge, or you have a battery contact problem.
Solutions: 1) Clean your battery contacts with a pencil eraser.
2) Be certain the batteries are installed correctly.
3) Check your battery date code (three digit number on back of battery above the stop sign. First number is year, next two numbers are the week of the year. Batteries last about 2 years.)
4) Check to see your new batteries are NiCd batteries. The wall charger method is not compatible with NiMH batteries.
5) Try a charged battery from another radio and see if the charger light comes on and stays on with a different battery.
Drop-In Charger:
If you are using a drop-in charger, you would be using the above listed HTN8232 wall plug charger plugged into the tray. Here are some possible solutions for the drop-in charger:
1) Clean the exterior battery contacts with a pencil eraser.
2) Check to see if the wall charger will work when plugged directly into the radio.
3) If the charge capability of the radio seems compromised, take the battery out of the radio and charge it alone in the drop-in charger.
NOTE: Do not use the PTT if you are turn on the radio when plugged into the charger. This will burn out components in your radio.
The SP10 radio is known to be a repairable radio. (Generally around $69 flat rate.)
Best regards.
Dec 05, 2009 | Motorola Walkie Talkie 2-Way Radio
There is no focus when attempting to record or play back
Contacted Canon, there was a faulty part in the ZR80 and other models. they offer a free repair including shipping and handling. Camcorders: ZR60, ZR65 MC, ZR70 MC, ZR80, ZR85, ZR90, ELURA 40 MC, ELURA 50
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=227&modelid=9740&keycode=2112&id=48266
Oct 07, 2009 | Canon ZR80 Mini DV Digital Camcorder
Canon NTSC ZR25 MC Digital video camcorder eating tape how can I fix it
Canon NTSC ZR25 MC Digital video camcorder is eating the tape. I've loaded a new tape and get an "eject tape" message each time. Does anyone know how to fix this issue?
Jun 24, 2009 | Canon ES75 Camcorder
Canon zr65 does not work on battery power
I would guess that ur battery is bad and will not hold a charge. Try a new battery and see if that fixes it.
Nov 06, 2008 | Canon ZR65MC Mini DV Digital Camcorder
The display is not working
See this link:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=9825&keycode=2112&id=48264
There is a problem with the CCD image sensor for the following cameras:
Malfunction:
It has been confirmed that the connecting parts of the internal wiring of the CCD used in affected products may become disconnected, especially if the affected products are stored or used in high-temperature and high-humidity environments. If this occurs, the signal is not output from the CCD normally in Shooting Mode, which may cause a distorted image or the absence of an image. This malfunction can be confirmed on the LCD monitor screen during shooting. The same malfunction also appears on the recorded image.
Canon's Response:
Effective immediately, and regardless of warranty status, Canon will repair, free of charge, the products listed above exhibiting the above-mentioned malfunction if Canon determines that the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
Jul 31, 2008 | Canon PowerShot SD100 / IXUS II Digital...
Cannon SD100
Affected products: - Camcorders: ZR60, ZR65 MC, ZR70 MC, ZR80, ZR85, ZR90, ELURA 40 MC, ELURA 50 - Digital Cameras A60, A70, A75, A300, A310, S230, SD100, SD110, A40(*), A80(*), A85(*), A95(*), S1 IS(*), S60(*), S200(*), S330(*), S400(*), S410(*), S500(*) *Models added as of Oct.31, 2006 Malfunction: It has been confirmed that the connecting parts of the internal wiring of the CCD used in affected products may become disconnected, especially if the affected products are stored or used in high-temperature and high-humidity environments. If this occurs, the signal is not output from the CCD normally in Shooting Mode, which may cause a distorted image or the absence of an image. This malfunction can be confirmed on the LCD monitor screen during shooting. The same malfunction also appears on the recorded image. Canon's Response: Effective immediately, and regardless of warranty status, Canon will repair, free of charge, the products listed above exhibiting the above-mentioned malfunction if Canon determines that the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair. U.S. residents are kindly directed to contact the Canon Customer Support Center for further assistance at 1-800-828-4040. Support hours are Monday thru Friday - 8:00 AM to 12:00 midnight; and Saturday 10:00 AM to 8:00 PM (all times EST). Alternatively, if electronic support is preferred, please send your email to carecenter@cits.canon.com
May 29, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Canon ZR65MC Mini DV Digital Camcorder Logo
537 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
