Question about Toshiba 65HX81 65" Rear Projection Television
Toshiba 65Hx81 model rear projection
We acquired this T.V. from my dad. The picture is darker now than it was. We have tried making color adjustments. Any suggestions?
    Genius:
  • 1,694 Answers
Remove speaker grill,then remove screen assembly..carefully.
Clean RGB lens with soft cloth...reassemble....T.
Posted on Feb 01, 2008
  • 77 Answers
The picture tubes dim over time. It's possible they need to be replaced and/or cleaned. There are 3 of them (one blue, one red, and one green).
Posted on Jan 30, 2008
How to adjust the color on a HP Officejet 4635 Printer? The is much darker and "off" color from the original picture.
Colour control is not a function of the printer. You need to adjust your PC/laptop display to show a more realistic image by sourcing some test patterns, see link:
http://www.lagom.nl/lcd-test
When your screen is properly set up, open the picture you want to print and see what it looks like. Use a suitable photo editor to adjust brightness, contrast etc. and then try printing again.
Jul 12, 2016 | HP Office Equipment & Supplies
My wonderful Coolpix recently seems to be letting in too much light when I go to take a picture..worked fine before
It is mostly due to changing the exposure compensation. You can change it from +2 ....0 ....... -2. +2 Makes it Brighter while -2 makes it darker... On the back of the camera you will see an OK button surrounded by a disk that on the right side shows [+/-]. You use this to change exposure compensation. When you get the camera READY to take a photo you can use that [+/-] button. When you push it you can adjust it to zero (o) normal or to make it lighter or darker.
Sep 29, 2015 | Nikon Coolpix S3300
Mitsubishi tv troubleshooting
Darker picture is lamp. Weak colors is not. Clean out dust to make lamp last longer.
Apr 06, 2014 | Televison & Video
Tv is about 6 years old hd-ila 56g657 have replaced lamp 3 times over that time but the picture started to get darker and darker.the last time i replaced the lamp it did very little good and the ptcture...
you cleaned the reflector glass, then tried to make the manual adjustment of the color to have good convergence. you can do the adjustment in the menu set up. if can not get with adjustment, their might be a problem in the convergence circuit board.a bad convergence ic or resistor.
Nov 18, 2012 | JVC HD-56FB97 HDTV
MY TV PICTURE HAS GONE A LITTLE DARKER AND ADJUSTING BRIGHT, CONTRAST, COLOR,ETC. DOES NOT HELP
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
Aug 16, 2011 | RCA TruFlat 27F520T 27" TV
We cannot seem to make a copy darker??
i would suggest that 1st you do the auto gradation adjustment full adjust under add function /adjustment cleaning then under additional functions look for one that says printer settings you can adjust black density under that setting
Sep 26, 2008 | Canon imageRUNNER C3220 Color Copier
The picture is not very bright
Good Day;
If this is a rear projection you may need to clean the lenses and mirror and try adjusting the contrast. If it is a direct view your picture tube maybe going soft (bad). If it's a Phillips/ Magnavox change CRT coolant.
Good Luck, big IRISH.
Sep 25, 2008 | Televison & Video
Color fading in picture
you need to replace the coolant in thr CRTs( picture tubes) Vert common problem in phillips. You can get the enitre repair kit at the following link which has the coolant and instruction CD for phillips coolanrt change. Heres the link its under the repair kit section.
http://servicemanuals.vstore.ca/
Jul 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Le40m86bdx picture not sharp
I have a two and a half month old Sharp, LC-19SK24U-W. It was fantastic with fantasic, clear, beautifully colored picture until two weeks ago. All of a sudden, the picture starting getting darker and darker. Nothing had been adjusted from day one when I set up contrast, etc. This comes and goes but most of the time is an issue. I can make it a bit lighter but then it is so fuzzy and grainy it is a very poor picture. Also, while this began, one time the television turned itself off and then back on without a power surger or anything.
HELP!
Jan 09, 2008 | Televison & Video
Strange picture issues
check near lineoutput transformer low value resistor eiher open circuit or high needs technician
Mar 18, 2007 | Samsung DynaFlat TX-P3064W 30" TV
Toshiba 65HX81 65" Rear Projection Television Logo
152 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
