FixYa.com
Tags:
Epson LCD PROJECTOR, XGA, 3500 ANSI, 1024 x 768, 450:1 => Model POWERLITE 7850NL Monitor
TLP-B2 projector lamp problem
posted by precisesound on Jan 28, 2008
When I turn on my lcd projector the lamp flashes three or four times then goes out. The on lamp indicator and lamp indicator go from steady green to steady red. Does this mean the bulb is bad or the bulb can not start. I figured if the bulb is bad then the unit will try to pulse start it with small flashes of light emittance then go out. Does anyone have any technical info or ideas as to whether the bulb is bad or if the unit is faulty.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 28, 2008
Not Rated (0)
glamaxjoe
Rank:Wiz Wiz
Rating: 70%, 35 votes
my suggestion that unit is faulty and i recommend that you bring to the service center for repair that unit.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Monitors problems?
Monitors
power saver mode
have a LG L226W (digital)... Answer This...
Monitors
Dead Monitor
Hi, I bought my parents an HP... Answer This...
Monitors
monitor isn't working!
At first, there was a hazy... Answer This...
Monitors
SERVICES MOOD OF CRT MONITOR
how to get services mood of... Answer This...
Epson LCD PROJECTOR, XGA, 3500 ANSI, 1024 x...
LCD Projector
My light bulb went out during a... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
