Question about Emerson EWL20S5 20 in. EDTV-Ready LCD Television
Help tv is only one year old. a few months ago we noticed that it woulndt power up after we tried to turn it on. usually it would work if we left it alone for a few hours. but the problem has been getting worse and now day go by with us not beeing able to turn it on. ??????
  • 1 more comment
  • ccarr123 Mar 06, 2008
    TV will not power up. When I hat the power button the red light comes on for about a second the a faint blue flicker. The tv never comes on
  • Anonymous Apr 06, 2008
    I removed the back cover and found the power supply fuse had burned. I replaced it with the recommended fuse, plugged the unit in and the fuse blew up again! I did some tracing with my meter and found two caps in the power supply module apparently defective. Problem is there are no markings on the caps. Any recommendations?
  • Moviebuff4 May 24, 2008
    I heard a buzzing sound for a few seconds and then our TV went off. When I tried to turn it back on, it blinked the green light for maybe 2 seconds and then turned off again!
    Scholar:
  • 133 Answers
Some of these sets had bad caps in the power supply . Others have had to had the power supply replaced . There is a website called www.shopjimmy.com that sells used modules if there available . Check to see if they might have a cheap one . Good luck
Posted on Mar 04, 2008
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Tv is on with no picture or sound, only 4 months old!!
Hello
The power supply regulator board to your set has the fault. If you try to open the set, or try to repair it by yourself, the warranty will void. The set must have warranty as it is new. Why do you spend for it? Just contact the nearest authorised service center for Sceptre. the components in this set will be very hard to get from open electronic spare part market, and will costly too.
Mar 11, 2012 | Sceptre 32 X320BVHD 32 LCD TV
Samsung LNR408DX/XAA Won't power up. Sound works but as far as the screen, no input/source works. After it died I noticed that the screen was very hot especially the upper Left side. In the dark, the...
It sounds like this is a problem with the inverter boards on the LCD panel. Unfortunately the inverter boards are usually only available with the whole LCD panel and the only way to fix it is by replacing the whole LCD panel. This is the most expensive part of the TV (about $1000) and you will need to take the whole TV apart in order to replace the panel. A new TV of similar make and model will usually be about the same price as the repair.
Nov 09, 2009 | Samsung LN-R408D 40 in. LCD HDTV
Starting problems
I had the same problem with my 97 olds 88. I would leave it off for work all day and would start up fine. If left for 15-20 minutes like you said it would not have inough power to turn over. You will probly have to replace your starter. I had the problem for about a year and finally had to replace it. got it about 10 months ago and have'nt had a problem since. You might want to have it checked out first by a professional first though. Hope this helps!
Mar 08, 2009 | 1997 Oldsmobile 88
Samsung rear projection tv
I think it could be a faulty diode on the power supply board. If you can check this for yourself otherwise call out a competant technician. Good luck.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
All TV's in house failing, a few at a time
Hey PNorris,
If multiple electronic devices are failing in your home all at once, I would probably first have to ask if your home recently experienced an electrical storm or major power surge of any kind.
Normally the effects of such large-scale surges are immediately noticeable - TV's and other major electronic devices may fail to turn on, fuses may be blown or circuit breakers tripped, and in some cases electrical wiring may be melted.
If nothing like this has happened recently, low-level power surges may still be a potential cause of this problem. When the motor from any large appliance (such as an air conditioner or refrigerator) turns on or off, it often diverts power to and from other electronic devices using the same circuits. This fluctuation in electrical current may result in low-level power surges to every connected device. While not immediately noticeable, these low-level surges can often cause the eventual failure of (and gradually degrading quality in) many audio/video components.
Typically, the easiest way to avoid situations like this is to make sure that outlets are not overloaded and surge protectors are used with every major electrical device in your home. For older homes however, replacing the house's wiring may be necessary. Homes that were originally built at the turn of the 20th century may not always have wiring capable of supporting the electrical needs of many modern appliances.
Ultimately, this means that in addition to contacting your local TV repair facility, you may want to also speak with an electrician. This is probably the best way to determine whether or not power surges have caused these failures, and may give you a better idea how to proceed.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 12, 2008 | Televison & Video
Panasonic PT 44LCX65 model
I also have this problem. TV is 2 years old. Service tech says the repair will cost about $600 per spot. I have 4 spots
Oct 30, 2007 | Panasonic PT-52LCX65 44" HDTV
Emerson EWL20S5 20 in. EDTV-Ready LCD Television Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
