Question about Nikon D1X Digital Camera
On the top screen where it says the amount of shots left for a sequence, it says FL
FL appears when i press the shutter button and it will not take a photo.  i have tried reformatting the memory card, but this did not fix it.
does anyone know what this means ? or how i can fix it ?
thanks
  • enuffx Feb 03, 2009
    I have the same issues with the D1x body and the same card works fine in D1
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    Have you tried another memory card?
FL means that the full amount of space on the card is available...it doesn't give you an amount like say the d70 which says you have , say, 1.1K available of space...the d21x goes in reverse and starts counting how many pics you have taken...the FL becomes a number at 99 and goes down from there depending on how many pics you take.So you then end up with a number on top instead of FL and a number below indicating how many pics you have taken.
Hope this helps.
Posted on Apr 13, 2008
How to use the shutter timer on the canon power shot A620 camera
Press the FUNC/SET button. Use up/down to select Drive Mode (the rectangle, third item from the top). Use left/right to select the desired delay and press FUNC/SET. Start the self-timer by pressing the shutter release button.
Feb 27, 2011 | Cameras
I don't know how to activate the self timer on my canon a450 power shot camera
Feb 09, 2011 | Cameras
I dont know how to set the automatic timer on my canon 510 power shot camera
Jan 09, 2011 | Cameras
How do I set the timer for delayed shots?
Press the FUNC/SET button. Use up/down to select Drive Mode (the rectangle, third item from the top). Use left/right to select the desired delay and press FUNC/SET. Start the timer by pressing the shutter release button.
Jul 29, 2010 | Canon PowerShot A430 Digital Camera
NUMBER 8 BUTTON WON'T WORK
Warning
In the keyboard test (below), make sure the keys are pressed in the right order. If the calculator fails the keyboard test then it needs repairs. (Ignore the beginning of the post and skip to the last part For Repairs )
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the diagnostic tests.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Release the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterward you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a high pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.-
For repairs
You can also try this site. They do repairs on most models, except the newer ones.
May 27, 2010 | HP 48gx Calculator
How to use the panoramic function in my olympus 1050 SW.
I won't say it's in the manual.
Turn the selector to the square "camera" icon (just above AUTO).
Press the Menu button, select Panorama. Choose Combine In Camera 1.
Point your camera at the left or right side of whatever you are taking the picture of and press the shutter button. A flashing icon appears with arrows pointing left-and-right. Pan the camera left or right (your choice) as if to take the next shot in the panorama ... a blinking diamond appears and then a square box - keep moving the camera until the diamond enters the square box, the camera will automatically take the next photo. Move the camera again in the same direction, another diamond and square box appear and the photo is automatically taken as before.
To take another panorama shot, repeat this entire procedure, beginning with the Menu selection.
Oct 09, 2009 | Olympus Stylus / mju 1050 SW Digital...
The calculator is dead. Batteries are OK.model
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Self test.
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
System Halt
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
Hope it helps.
Aug 05, 2009 | HP 48gx Calculator
Smile shutter feature
Select the smile shutter option from the program settings. You will see an icon of a smiley face on the bottom left hand of the screen. To activate the automatic shot of when a person smiles, simply hold down the shutter button for a second or two. Now, when the camera face detection senses a smile, it will automatically take the picture. To deactivate it, press the shutter button again, the camera will then tell you how many shots it took. Hope this helps.
Dec 29, 2008 | Sony DSC-T70 Digital Camera
Lg viewty camera flash not working
This worked for me: I turned the ISO to 800 and set the flash to "auto" - even in quite bright light the flash still goes off so I'd definitely try this. To turn the image stabiliszer off, press the "unlock" button next to the shutter on the side of the phone.
Dec 02, 2008 | LG KU990 Viewty
ON switch
.The selft tests will show you what is wrong, and if the calculator requires repairs.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jul 01, 2008 | HP 48gx Calculator
Open Questions:
Nikon D1X Digital Camera Logo
316 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
