Question about RCA D61W130 61" Rear Projection Television
RCA D61W130 tv
Lost all main cable channels. Cable is working on other tv in house. tried to auto setup still not working.. When to pip the main chanels are there but you cannot swap to the main picture it is static.
    Genius:
  • 1,030 Answers
This unit has two tuner modules. one is the main tuner and the other is the slave or the pip tuner. it would apear from your description that the main tuner has failed. it is possible that this can be replaced.
Posted on Feb 08, 2008
The only channels available are throu ch 2-13, I have tried doing numerous auto searches. and have tried to restart it. I checked the cable, everthing is plugged tightly and nothing is frayed. It has done...
Make sure the TV is set for "CABLE" or "CATV" tuning. I forget on this model exactly where in the menus the setting is. Sorry. But it's usually in a general setup page, or part of the channel setup. If the TV is set for "AIR" or "ANTENNA" tuning, cable channels 14 and up won't be detected.
Jan 13, 2011 | RCA TruFlat 27F520T 27" TV
Rca hdtv channel changed by mistake
RCA channel setup and selection is not easy to understand. You may try to add channel 3 on the add/remove channel section. If that doesn't work try pressing the input button. Good Luck.
Feb 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
The main picture screen is not receiving the cable signal. Only the PIP search frame is receiving cable signal but it's stuck on channel 3 and cannot change channels. I've tried doing the auto scan for ALL...
either you don't have your cable connected to the right spot or your main tunner has failed check your cable connection also try to swithch the pip input to the main see if that works
Dec 09, 2009 | Televison & Video
Trouble with Channel setup
It is important for the TV to know what type of
signal-Cable TV (CATV) or a normal antenna
you are using. Choose your signal (Antenna or
Cable):
Press MENU to see the main menu.
Press CH+ or CH- to highlight Setup.
Press OK
to enter the Setup submenu.
TV/CATV is highlighted. Press VOL+ or
VOL-
to select TV or CATV.
Choose CATV if you have Cable TV
service. (See page 4 for connection
details.) If you do not have Cable TV
service and you connected an antenna
to the TV, choose TV. (See page 5 for
connection details.)
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
control.
And here is the manual if you need .
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
Good luck and please rate
Sep 24, 2009 | RCA TruFlat 27F520T 27" TV
Tv tuning instructions how to?
The quick user guide is available here: F32648 F36648
Tuning is automatic on this TV, ensure that auto channel search is on from menu.
Advanced Auto
Channel Search
Auto Cable/Air Switch sets tuner
to cable or “off-air” frequencies
during initial setup. Then system
automatically scans for and locks
active channels into channel
memory.
May 06, 2009 | RCA F32648 32" TV
Channels disappearing
this would apear to be a defective main tuner which a tech can replace this unit has two identical tuner modules one for main and one for pip There could be a issue with something called rf switcher. the signal goes in and is switch or routed to the pip tuner. so somewhere between the switcher and tuner the signal is lost.
Jan 28, 2008 | RCA D61W130 61" Rear Projection Television
No display
Press the DVD button on the Philips remote. Make sure the yellow part of the RCA cable is plugged into Output/CVBS/Out on the back of the Philips, and that it is plugged into a yellow input of your TV. Change your TV channel to Av1, av2, video 1, video 2, aux, aux 2, or whatever the correct video channel is on your TV. Then press setup - you will get your picture.
In order for the coax connection to work on Ch. 3 of your TV, you will have to get an additional piece of equipment - an RF modulator. It's better just to stick with the RCA red, yellow, white cables.
Sep 02, 2007 | Philips DVDR3455H/37B
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
PICTURE IN PICTURE TV RCA
The PIP puts a smaller picture on your main picture. Usually, the smaller picture is generated by a second source, such as a VCR. The VCR must be connected to the main cable signal and connected to the TV through the red, white, yellow RCA jacks. The VCR picks the smaller picture whilt the tuner in the TV picks the main pucture. The PIP circuits digitally add the smaller picture to the larger picture. The PIP cannot be used to veiw 2 different channels at once on satellite systems because the satellite receiver sends only one channel to the set at a time.
Aug 22, 2007 | RCA F32665 32" TV
Lost channels 2 through 52
I think the low band (Channel 2-6)in your tuner is not working. This could be in the tuner itself or in the band switching circuits. Possibly she deleted the low channels or locked them out. Stargazer
Jun 14, 2007 | RCA F32632SB 32" TV
RCA D61W130 61" Rear Projection Television Logo
161 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
