posted by marcetj on Jan 28, 2008
Question I have an older tv that only has the RG Hook Up (or where cable screws into) My question is...is there such an adapter that would have the single cable screw in on one end and adapter for 3 RGA plug ins on other, so my son can plug his xbox to it
Solution #1
posted on Feb 12, 2008
What you are looking for is a Coaxial (or F pin cable) to RCA (or Composite) converter. You are going to need an actual converter...not just a cable ...because you actually need to convert the signal.
The biggest question is where do you get one of these things? I found one on line that I think would work for what you need to do. http://www.cablewholesale.com/specs/40x3-30400.htm
Check it out but before you order it, email them and tell them exactly what you want to do...or make sure they have a good return policy in case it doesn't work the way you think. Another option is to go into your local Radio Shack...they may have something that will do the trick.
Good luck!!!
Good luck!!!
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Input Adapters problems?
Repair Service
Find Input Adapter Repairman Near You:
