Question about Nikon D50 Digital Camera
D 50 focus problems
I have having a hard time now with my nikon d50. when i take a picture there is only one thin straight line in the middle of the picture in focus. everything else is out of focus. i have tried manual, auto, p modes different lenses, filters no filters adjusting f stops iso and white balance shutter speeds too. i have done everything i can, i took it somewhere and they were baffled. they said it was the macro filter i was using, even though the lenses that they used did the same thing. can anyone help im really bummed. ive tried everything, also pressed the reset button too, nothing is helping. thanks.
  • fotomama Jan 30, 2008
    thanks so much i called nikon and was extremely polite and they said send it in and it'll be anywhere from 42. - 178. but thats better than the 400 i was quoted from one guy.
    also the camera body came with a 5 yr extended warranty and they said it only covers the lens. the guy i spoke to on tech support said there was no way it was nikons fault. yeah right!
    Scholar:
  • 33 Answers
This sounds to me as if the sensor in the camera has become angled slightly from abuse or manufacturing defect.  If you think about what is happening when you focus the lens, it is that the focal point is being moved forward or backward until it is exactly in the vertical plane that the sensor is in.  That is, unless the sensor is no longer in the vertical plane.  In that case the focus point is in front of some of the sensor, and behind some of the sensor, with it being on the sensor only on the line across the sensor that is where it is supposed to be.
You can probably test this by intentionally mis-focussing.  This should shift the line that is focus above or below the line that you have now.
If you did not do this by sticking something against the sensor and the camera is under warranty, Nikon should fix this.  In my experience, if you didn't do this by abusing the camera, and if Nikon has ever seen this before, and if you had registered the camera with them, and if you talk to Nikon tech support and are polite and respectful, etc., there is a better than 50% chance that they will fix it at no charge anyway.
I hope that helps. Good luck.
Posted on Jan 28, 2008
I own a Nikon D50 and the 55-200 lens will not autofocus (lens continually extends then retracts but never locks into focus). Ive read that depressing the lens release button whilst holding the lens in...
Why don't you just clean the sensors properly? Remove the lens and clean the contacts on both the camera body and the lens with a cotton swab lightly dampened with rubbing alcohol. There's a 50-50 chance something else is causing your problem but try the cleaning anyway.
Oct 14, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 16, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Auto focus doesn't auto focus
So you having problem with AF problem?
Try this (mind your camera to protect it from dust OR another small parts to get in while you opening):
1. Re-connect the lens and the camera.
2. Make sure the connectors is clean.
3. Connect it together again.
Hope this will help! Any questions? Feel free to PM me =]
Jul 07, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Help black line on bottom of picture.
After a bit of experimenting, I have found a solution that works in my case. The problem was the shutter speed. At 1/200 I got the black line on the bottom of my pictures, but when I tried it at or below 1/100 it was gone. Hope this helps.
Jun 15, 2008 | Nikon D50 Digital Camera
The auto focus is not working on my Nikon D50
I assume the AF/M switch on the body is set to AF as well? This has not been mentioned but the D50 has two drive systems for AF.
Feb 25, 2008 | Nikon D50 Digital Camera
Nikon D50 LCD Display does not work
NatD, The D50 and indeed most SLR digital cameras [ I have a D40 ] does not allow you to take pictures using the LCD display ... this is by design, you are meant to use the viewfinder and the image you see through it is straight through the lens via a mirror block [ called a reflex pentamirror or prism ]. When the mirror is down such that you can see the image in the viewfinder it is obscuring the sensor [ the bit that takes the picture ] and when you take a shot the mirror lifts and the picture is recorded. Its this reason that DSLR's dont use the LCD to shoot, however there are a few now available that do let you do this, such as olympus, new panasonic one and higher end Nikon and Canon cameras. Hope this explains it without getting too detailed!
Dec 04, 2007 | Nikon D50 Digital Camera
Nikon D50 70-300 mm lens
Send it to the repair shop Digital cameras like most folk object to brute force. you have probably wreck the focus motor and gearing.
Jun 06, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Problems with taking pictures of horizons and buildings
This Nikon's expertise to fix - contact customer support- they may repair or offer a replacement.
Jun 04, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50
I have this problem too - Nikon have looked at the camera and said I set up a custom setting so that the focus only works when you press the AE/AF Button (!). I also had a problem with the flash not working - its looking like this is a known problem. I think I was sold a Turkey
Apr 19, 2007 | Nikon D50 Digital Camera
Nikon D50 Digital Camera Logo
67 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
