Question about Fujitsu LifeBook 790Tx Notebook
Need CD rom drive
Looking for a CD rom drive to fit in the multi-function bay of my lifebook 790tx.
    Problem Solver:
  • 9 Answers
Where is your location if you are in melbourne i can supply you.
here is my email add.
compexaustralia@yahoo.com.au
Posted on Jan 28, 2008
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Computer does not recognize the cd-rom drive
possible, you can also search if your registry files have Upper and lower filters, the path is HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
then restart PC
Jun 16, 2010 | Fujitsu LifeBook N3010 Notebook
I just got a refurbished Dell on E-Bay. The
You could have a defective CD drive. or the power connection inside the tower could be disconnected. First, remove the side and look at the back of the CD drive. See if it has a smaller rectangular type 4 prong plug pushed securley into the right side of the back of the CD drive. Also there should be a longer rectangular black plug that takes up the middle of the back of the CD drive. This is the data drive that connects to the motherboard.
If these connections are all secure, you can look at the front of the drive for a very small hole that would fit one end of the paperclip. Push the end of the paperclip into this hole, this should release the CD drive door.
If you just got the computer thru Ebay, you should verify if you do have a bad CD drive so you can get it replaced.
Brian
Apr 16, 2010 | Computers & Internet
I want to replace my acer laptop Cd rom , from where can i remove old one
Here are the steps on how to remove your old CD-ROM so you can replece it.
Remove all power sources from the laptop. This should include not only the AC power adapter but also the battery.
Locate and remove the screw that locks the CD-ROM in place. Some laptops may have two screws that serve this function. In addition, many will also have a sliding switch that needs to be moved in order to remove the drive.
Slide the drive out gently. It should easily come out and does not require excessive force.
Replace the defective CD-ROM drive by sliding the new one gently into place in the laptop bay, the same way the old one came out. Again, excessive force should not be applied. The drive will only fit into the bay one way.
Secure the CD-ROM drive in place by replacing the screws that were removed previously. Reconnect all power supplies to the laptop and power it on. If the replacement CD-ROM is the exact same make and model as the previous one, the system will probably recognize it right away. If it is a different make or model it will prompt you to supply the appropriate software and drivers to optimize the use of the new CD-ROM drive.
Jan 22, 2010 | Acer (91.49C37.001) CD-ROM Drive
How does a small cd install on my cd rom device?
There is usually a space right in the center of the slot that comes out when you eject your CD Drive. If it cannot read it, then chances you will need a DVD reader.
Dec 29, 2009 | Electronics - Others
My Lifebook C2340 won't recognize it's own DVD-ROM. When I set the CD in the BIOS, it goes back to "None". It doesn't show up in My Computer. I've cleaned the contacts and tried another DVD. Still won't...
Does it show the device in the BIOS? If not then there could be a problem with the motherboard hardware. If it is not showing up in the BIOS then I would first verify that the power connector for the drive has voltage. Also verify that the slave/master jumpers are correct if the drive has any. You could also try downloading the BIOS update from Fujitsu and see if after updating the BIOS it brings the cd-rom drive detection back. If the BIOS is seeing the drive but Windows is not then the problem could be with the Windows drivers or installation. You could try going into the control panel for windows and use the "detect new hardware function" and see if Windows detects the drive.
Dec 16, 2009 | Fujitsu LifeBook C2340 Notebook
Hi, I have a T3010 Tablet pc Fujitzu Siemens
I removed harddrive from tablet pc and copied neccesary files onto drive via USB to IDE adapter. Then re-installed harddrive into tablet pc and now it works.
Oct 13, 2009 | Fujitsu Siemens LifeBook T3010 Tablet PC
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
Cd drive causes system hang when inserted in multi-drive bay
Is your virus scanning program set to scan the cd rom drive on access? It may be scanning the cd before it will allow you to use it.
and
some times caused by missing drivers so intall them properly again
Jun 24, 2009 | IBM ThinkPad R40 2722 Notebook
Fujitsu LifeBook 790Tx Notebook Logo
73 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
