Question about Denon AVR-1700 Receiver
Back channel turn off and on
The back channel turn off and when that happens the display says h/p input on. It will switch to h/p input off, when this happens the back channel speakers work. Anybody have a clue what this is?
  • 5 more comments
  • Psaunders47 Apr 25, 2008
    I have a similar problem with my Denon 4802. However all speakers turn off, then back on when the h/p input off is displayed.
  • Anonymous May 03, 2008
    Same problem with the 2.1 channel DRA-297. All sound cuts off and
    screen reads h/p input. I don't even know what that means. What's wrong
    When it happens, the receiver makes a clicking noise. it goes back and
    forth from being on to h/p input shutdown. sounds like someone
    repeatedly flicking a lightswitch.
    Thanks to whoever can help!
  • tkechub Jun 08, 2008
    AVR 4802 same issue it clicks and then goes to H/P input on and then there isn't any sound from the speakers.
  • nawnr Sep 03, 2008
    I have the same problem with a 4802. Sent to Denon in NJ they replaced the H/P jack. Worked for two weeks. Now the problem is back. Anybody find a solution?
  • messman Jan 01, 2009
    Same problem. It says H/P input on and switches the speakers off. It clicks back and forth incessantly when its at its worst. Some days doesn't do it at all. I had already sent it into Denon, but at that point didn't know this was the problem. I just couldn't get any sound and anyone whos used this receiver knows its not easy to know whats not right when its on the fritz.
    Very dissapointed in Denon and their support line is not much help- horribly long waits. So much for American made....
  • guyr-13 Jan 04, 2009
    from last june, i meet the same problem with an AVC-11SR (european version of avr4802 but without tuner)
    The sound disappear when the amplifier is hot, few minutes after is appear, and do this 4 or 5 times. After half an hour, all is working perfectly.
    I think this a soldering problem around the chip which perform the mute when the head-phone is plugged.
    But i didn't have any time to open and take a look...
    This afternoon, the sound totally disappeared...
    so...i'll open !
    i'll let you know
    Guy - from France
Same problem with the 2.1 channel DRA-297. All sound cuts off and screen reads h/p input. I don't even know what that means. What's wrong here?
When it happens, the receiver makes a clicking noise. it goes back and forth from being on to h/p input shutdown. sounds like someone repeatedly flicking a lightswitch.
Posted on May 03, 2008
My vizio tv turns on but had no display
Check to make sure the device you're trying to use with your TV is plugged in and turned on. While it may seem like a silly oversight, it is possible that you switched on your TV and didn't actually turn on your DVD player, gaming console or whatever device you're trying to enjoy. If you tried to use a remote to turn on the device, check that the batteries still have a charge and turn on the device using its built-in power button.
TIP The problem may be your input device itself. Check your TV with other devices and see if it displays them properly. If it does, contact customer support for your device for more detailed troubleshooting instructions
Make sure that your TV is on the right input channel for the device you're trying to use. When your TV isn't switched to the right channel, no visual or audio input from the device will display on your screen or through your speakers. Turn on the input device and press the Input button on your remote to cycle through your input channels until you see the device's display on your screen.
If you're on the right input channel and your device is turned on, there may be a problem with the physical connection between the device and your TV. Make sure that all cable connections are secure, and also that all cables are connected to the In ports on your TV and the Out ports on your input device. If you're using a connection that has color-coded plugs, make sure the connectors are inserted into their appropriate color-coded ports.
If you're using an HDMI connection, make sure that the cable you're using is compliant with High-bandwidth Digital Content Protection, especially if your TV and input device are both HDCP-enabled. HDCP is a copy protection system that prevents the copying of digital video and audio content as it travels over the connection. Systems connected with non-compliant cables won't display any video or audio conten
Periodically a TV may freeze up, showing that it's still turned on but not actually displaying any information from your input device or the TV's menu system. To fix a freeze, power cycling is the best solution. TEP 1 Turn off the TV by pressing and holding the Power button on the cabinet until the TV powers down.
STEP 2 Unplug the TV from the wall power outlet.
STEP 3 Press and hold the Power button on the cabinet for 30 seconds, and then release it.
STEP 4 Plug the TV back in and turn it back on using the Power button on the cabinet or your remote control.
If everything is correctly set up, powered on and on the right channel and you still aren't getting any picture or sound, there may be a hardware or software fault in your TV. The best way to check is to press the menu button on your TV or remote and see if the on-screen menu appears. If the menu doesn't appear, contact repair
Sep 28, 2016 | Vizio SV Televison & Video
How do i get my hdmi to work for my ps3 system
Note: How to reset video output settings
If you are attempting to change to an HDMI cable from a different video cable or if the video output settings do not match those required for the display in use, the screen may stay black. If the screen stays black for more than 30 seconds, you may need to reset the video output settings of the PS3.
To reset video output settings:
  1. Turn the PS3 system off by holding the Power button on the front of the console till you see the power light turn red.
  2. Then hold the power button on the front of the console for at least five seconds until you hear a second beep to turn the system on again. The video output settings will automatically be reset to the standard resolution.
HDMI Cable Installation
Interactive Video Tutorial
Click below for an interactive video walkthrough on connecting your PS3 to your television or display device (including HDMI).
alt="Click to play tutorial">
Minimum Requirements
  • PlayStation®3 computer entertainment system
  • SIXAXISTM wireless controller (and USB cable)
  • AC power cord
  • HDMI cable1 (sold separately)
  • TV or display monitor with HDMI port and capable of displaying picture in HD resolution
  • Updated system software installed on your PS3
    Visit PS3 System Software Update to download and install the most recent version.
  • TV "Input" or "Video" channel for the HDMI port
    You need to know the TV "Input" or "Video" channel for the HDMI port on your TV. For instance, if your TV has multiple "Input" or "Video" channels, (i.e., "Input 1", "Input 2", "Input 3", etc.), you will need to toggle through each "Input" channel on your TV until you find the correct channel that displays the HDMI picture. This is important to remember, especially if you do not see the HDMI picture after you connect the cable and configure the PS3 settings. Please refer to the TV instruction manual for more information.
  1. Before you begin installation:
    • Turn OFF the PS3TM system using the [MAIN POWER] switch (in the back)
    • Unplug the AC power cord from the electrical outlet
    • Turn OFF and unplug the TV
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    alt="line drawing of HDMI connection">
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet.
    alt="line drawing of AC power cord">
  4. Press the [MAIN POWER] switch on the rear of the system. A red light should appear on the front of the system indicating power is available.
  5. Turn on the PS3 by pressing the touch-sensitive [On/Off button] on the system front. The red light will turn green, indicating the PS3 is now turned on.
    Note: The blue light will also appear on the front of the system if you have a disc inserted.
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the alt="X button icon">button. (You may need to press the PS button on the center of the SIXAXISTMcontroller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the alt="X button icon">button.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the alt="X button icon">button to save your settings. You have now completed the HDMI installation.
Feb 15, 2015 | Video Game Consoles & Games
I have an e470vl vizio hdtv. i was plugging another component into the wall when the whole outlet sparked (biggest i have ever seen/felt). the tv and dvd player were connected to a power strip to that...
first of all just switch off everything then switch off the mains, open the mains socket as there might have been a loose connection to the terminals which you`ve got to tighten. also confifrm that the earthing is well connected before you switch on .
swtch on the mains then switch on your devices one by one, also confirm that the VGA cable is well connected to the display unit
Sep 17, 2011 | Televison & Video
My cable input has disappeared. All I have are HDMI, AV, and PC inputs. And the entire selection in the menu for channels is gone including auto channel scan.
- Press Menu
- Press 991
- Go down to Memory recall and press enter
- It will ask you "ARE YOU SURE"?
- Select "Yes" and press enter
- It will take you back the menu screen, turn off the TV and turn it back on user_offline.gif quote.gif
May 18, 2010 | AOC L22W898 22 in. LCD TV
Just bought a Sony XBR9 and Comcast gave me a Motorola DCT6200 box which has a DVI output to a HDMI input into the TV. When switching from a HD channel to an analog or digital channel, the picture is...
I am having the exact same issue. It started happening within the first few hours of turning on the XBR9 for the first time. I also have a Motorola box from Comcast. This did not happen with the HD TV that was hooked up previously. Did you return the TV?
Jan 07, 2010 | Arris DCT6200 DTV Receiver
After new installation of digital channels we turn the tv off , on switching back on there are no channels available.
If your remote has a button that says 'input' It is probabley defaulting to the wrong setting. When you turn the tv on, and get no channels, press the input button until a channel comes up. It should remember that input and default to that automatically.
Dec 08, 2009 | Televison & Video
Toshiba 1782tb -input chanel flickers to another channel too much
If you cover up the end of the remote does this continue to happen or does it stop? If it stops try disassemblying the remote and clean the holes the touch pad buttons stick through. and the bottom of the pad. very gently spray the end of a cue tip with windex and lightly clean pad. make sure the windex does not have any other addatives in it ie furniture polish, silicone etc.
Mar 06, 2009 | Televison & Video
TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Dec 05, 2008 | LG 32LG40 32 in. LCD HDTV
Sonny Play Station 3
how is it connected to the tv? does your tv auto switch channels? if not try manually switching inputs with your tv remote (ext1, ext2, scart, hdmi etc etc) you say you connected to tv put in a disc right away? did you set up your console first? (of course point one about the display needs to be resolved before set-up can take place)
example if you are connected to your tv with an HDMI cable and your tv does not detect and then switch to your HDMI input.. use tv remote and repeatadly press button (maybe called source on your remote maybe something else) untill the input is switched to HDMI
Oct 18, 2008 | Sony Playstation 3 (PS3) Console
Issue was with the HD channels only.
Updated the firmware of the TV to ver 2.
Now the TV will stutter for a second when changing to a HD channel but it no longer locks up.
Feb 15, 2008 | Westinghouse SK-26H590D Television
Denon AVR-1700 Receiver Logo
180 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
