Question about Philips SA5125/37 MP3 Player
Major problem My mp3 keeps reading all data cleared and then push ok but it freezes after that....what do I do
  • Anonymous Aug 30, 2008
    my mp3 has memory corruption
  • 8,596 Answers
Especially if you have Vista or Windows Media Player 11, the firmware upgrade for this device should resolve that problem. If the firmware fails to update, then perform a Repair through Philips Device Manager first, and retry the Firmware Upgrade.
If you find that the GoGear will not load the firmware upgrade, then:
1) Backup all files on the GoGear (Repair will delete all files on your GoGear)
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
You will now be able to load the upgrade
Also, if the Philips Device Manager says that your device is already updated with the latest software, then go to: www. usasupport. philips. com,and enter in your model number, SA5125/37, on the next page select SA5125/37 (not "37B"), on the next page click on software and drives, and click on Firmware Upgrade Software - this will ensure that your player really has been given the most current firmware upgrade
-Tha Mp3 Doctor
Posted on Feb 04, 2008
Had the tc 8 months just turned it on and the screen and volume keeps breaking up and freezing
try to reset the systemand upgrading to the latest update that is wat i had done all good now..
Mar 31, 2012 | Audio Players & Recorders
My printer reads unable to clean and will not work
Welcome to Fixya
You need to clear the ink waste counter and clear the purge counter. Please see procedure below:
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 OK (the display is showing this message)
- now push the START button 25 times until you see PURGE: xxxxx
- Press 2783
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 25, 2011 | Brother Office Equipment & Supplies
My sand disk sansa mp4 keeps on freezing on the music play all the time and the computer cannot read it
How to Reset a Sansa Clip
The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Turn Sansa Clip on. Press the "Menu" (home) button.
Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
Scroll down to "Reset All" and select. You'll be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow Steps 4 and 5.
In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm that you wish to format. Select "Yes."
Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
Resetting a Frozen Sansa Clip
Push the power button up and hold it for 20 seconds. Release it, then turn it on again.
Go to the Sansa website and download the "Sansa Firmware Updater."
Select "Run" when the updater installs. (Installation will take less than two minutes.)
Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
Connect the Sansa Clip. Remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Tips & Warnings
You should download the Sansa Firmware Updater to your computer even if you aren't having a problem with your Sansa. This will ensure that your device software remains up-to-date and free of technical glitches.
Reformatting the Sansa Clip will erase all songs and data on the device. Resetting will simply change your player's settings.
Have a nice day....
Feb 19, 2011 | SanDisk Sansa e260 MP3 Player
My iphone keeps freezing,i`ve tried reset many times and it`s ok for a little while then it freezes again
Try a reset. Hold down the power key at the same time as the round home key until phone powers down. Release buttons only when you see the apple logo, then wait a min or two for phone to re-boot. You will not lose any data on the phone.
If this does not work, try an actual system reset. Sync iPhone to computer to back up essential data ie contacts apps etc, then go to settings general and reset. Reset all settings as a last resort. This will give you a fresh start and should sort out the majority of any bugs the phone has. A resync with you computer will restore apps etc.
Hope this helps and if so please vote.
Thanks
Jim
Aug 31, 2010 | Apple iPhone 3G Black Smartphone
I have a creative Zen 2GB & when I turn it on it has to rebuild libraies and then once that is complete it freezes on the one song & I cant turn it on or off
Ok just fixed mine by pushing pin into reset hole. Hold play button turn zen v back on format player. yes you will lose your data but its better than buying a new mp3 player. download zen firmware update plug player in and update. This problem is caused by a corrupted file so the only way to fix it is full formate.
Sep 14, 2009 | Creative Labs ZEN V Plus MP3 Player
What do these codes mean on 1994 Cadillac Eldorado -A012 and A047
Sound like you have a bad cv "constant velocity joint " REPLACE.
The first thing you need to do is to clear your old codes then drive
and see if they come back .
1. Re-enter back into the climate control panel and after all the codes display the display will stop at PCM?
2. Push and release the FAN UP (^) button on the climate control panel and you will see PCM DATA?
3. Keep pushing and releasing the FAN DOWN (v) button until you see PCM CLEAR CODES?
4. Push and release the FAN UP (^) button and you will see PCM CODES CLEAR?
5. Wait 5 seconds and then keep pushing the OFF button until you see PCM?
6. Push and release the FAN DOWN (v) button and you will see IPC?
7. Push and release the FAN UP (^) button on the climate control panel and you will see IPC DATA?
8. Keep pushing and releasing the FAN DOWN (v) button until you see IPC CLEAR CODES?
9. Push and release the FAN UP (^) button and you will see IPC CODES CLEAR?
10. Wait 5 seconds and then keep pushing the OFF button until you see PCM?
11. keep Pushing and releasing the FAN DOWN (v) button and you will see ACP?
12. Push and release the FAN UP (^) button on the climate control panel and you will see ACP DATA?
13. Keep pushing and releasing the FAN DOWN (v) button until you see ACP CLEAR CODES?
14.Push and release the FAN UP (^) button and you will see ACP CODES CLEAR?
15. Wait 5 seconds and then keep pushing the OFF button until you see PCM?
16. keep Pushing and releasing the FAN DOWN (v) button and you will see SIR?
17. Push and release the FAN UP (^) button on the climate control panel and you will see SIR DATA?
18. Keep pushing and releasing the FAN DOWN (v) button until you see SIR CLEAR CODES?
19. Push and release the FAN UP (^) button and you will see SIR CODES CLEAR?
20. Wait 5 seconds and then keep pushing the OFF button until you see PCM?
21. Push the AUTO button to get out of diagnostics.
22. Turn ignition OFF for 15 seconds.
23. Re-enter diagnostics and see if any history codes re-appear.
Mar 27, 2009 | 1994 Cadillac Eldorado
Zune freezing
You may read this to solve the problem. here is a link
http://tech.yahoo.com/news/pcworld/20081231/tc_pcworld/microsoftsaysleapyearbugcausedzunefailures;_ylt=AglElnv.sPm6b9FZIubqw68azJV4
Jan 02, 2009 | Microsoft Zune JS8-00001 Digital Media...
DVD Drive will not read any DATA Disc just blanks,,,freezes up while trying to read data
lense requires cleaning up, you can try a DVD lense cleaner available in market and run it i the drive, hope so if its not major problem with lense it will be cleared.
Apr 17, 2008 | Computers & Internet
ZENV has firmware problem
try downloading the
MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
I hope it won't keep freezing on you after the update.
Jan 11, 2008 | Creative Labs Zen V MP3 Player
Garmin Street Pilot i5 Stopped working all of a sudden
Resetting Your StreetPilot
If your StreetPilot freezes (stops responding to button presses), try turning it off and then on again. If this does not help, remove the batteries and then reinsert them. Disconnect from external power, if necessary.
Clearing all User Data
If resetting does not fix your problem, you may need to clear all user data from your StreetPilot.
• IMPORTANT: zf you clear all user data, you will delete all saved locations from My Favorites I and all settings in your StreetPilot. Be sure you want to clear all user data before proceeding.
To clear all user data, press and hold down all buttons in the following order: ciJ, Wheel, Power.
Continue holding down all buttons until you see a prompt, “Do you really want to erase all user data?”
Select
Yes.
Nov 16, 2007 | Garmin StreetPilot i5 GPS Receiver
Philips SA5125/37 MP3 Player Logo
162 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
