Kenmore top loading machine not spinning
Belt is worn but i cannot figure out how to replace it
not sure what model #
10 years old
  • 72 Answers
You have to loosen the mounting bolts on the motor (of course after you unplug it) and there should be a little play in it. You then use a prybar or large flathead to gently pry off the pully and installation is just the opposite. DO NOT OVERTIGHTEN BELT. It will cause a lot of friction and will make it fail faster. Leave about 1/8" of give on it ( you can push it in about an 1/8" in middle of either side of belt after tightening the mounting bolts) and rub down inside of belt with bar soap to dress the belt to keep it from squeaking. Hope this helps.
Posted on Jan 28, 2008
Sm8280871 is the model listed under the lid. It is a Roper by Whirlpool top load washer about 10 years old. I can hear the motor however the washer does not spin, or drain. It appears that it tries to...
I suspect the V belt is worn out try taking the side cover off you would have to tilt the machine another helper maybe needed make sure you drain the remaining water out and unplugged the cord safety first
Oct 24, 2013 | Roper RAK2751WWH Top Load Washer
Kenmore 70 belt drive starts to spin then stops then will try again an stops but is slow
if toothed belt,teeth worn away ,need new belt or motor failing.Check belt,,if in good condition inquire about replacement motor and costs of replacing it against cost of new machine,??,,hope this helps..
Jul 05, 2011 | Kenmore 22422 Top Load Washer
Washer doesn't spin ; model 3200 bosch; 4 yrs. old; other cycles work
Although all brands are different in design, the basic concept is the same. When a machine won't spin, there are several things to consider:
  • Is the belt broken? Loose?
  • Does the lid switch click when closing? (see video below)
  • Does the spin solenoid engage? (1984 and before)
  • Drive coupling worn out? (on some newer Whirlpool & Kenmore top loaders)
  • Clutch worn out?
  • Current to motor? (Use voltmeter to check)
Dec 03, 2009 | Bosch WFMC 3200 Front Load Washer
My Kenmore Top Load Washer 22712100 will not spin clothes. What is the problem?
It sounds like your drive belt is excessively worn. Note that some machines will (barely) agitate with a worn belt, but when subjected to the demands of a spin cycle, a worn belt will slip indefinitely.
Oct 05, 2009 | Kenmore Washing Machines
Kenmore 110-23022101 washes and tries to spin, but can't. Clothes stay sopping wet.
not sure if ur machine is washing but not spinning....if none is working the u have to check the drive belt on ur machine u will find on the bottom of ur may its to lose and u have to adjust it like a fan belt in the car.....or u may have to replace it all to gether as it may have worne out or have slippet of the motor drive wheel
Mar 28, 2009 | Kenmore 22422 Top Load Washer
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
My washing machine will not spin or agitate
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
Jan 19, 2009 | Kenmore 24932 Top Load Washer
Kenmore 22442 not spinning unless you physically help it along
Sounds like a worn belt problem!
Call service now before it gets worse and cost you a lot more money!
You'll be okay!
Electronic problem. just call service.
If its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Give me a good rating on this site , FIXYA.COM
Try these guys,they are good!
A&E Factory Service is nation wide!
They are open 7 days 24 hours to make appointments
Aug 23, 2008 | Kenmore 22442 Top Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
