Question about Toshiba Tecra 510CDT (P000224080) Motherboard
Dispaying broad colourfull vertical lines.
Hi, I have been given a very old Tecra 510cdt/2.1, circa stone age.
I am not techno able, but am guessing the vertical lines suggest graphic/video card problems??. If so, could you please tell me where I can buy a card, roughly at what price, and how to fit it myself???.
This laptop also ignores discs in its cd rom driver, which I also need advice/help with. Any help or advice would be great.
Thank you for your time.
x liliz4th
  • liliz4th Jan 28, 2008
    Hi djnick989,
    how are you,
    Wow that was a fast reply!!, thank you so much.
    As I am not in the least techno savvy,I am struggling to follow your advise!, think you may be typing too fast for me!!ha!. I am in England so you may have to shout louder too!!.
    I am brave enough to try replacing the parts myself, but you seem to imply I need many?!, and they will be expensive??. I do have a good computer, I just like a challenge and do not like throwing stuff away. The tecra has been upgraded to Win/98, in the past. Have to say, these old laptops are much more substantial than the newer variety, I am tempted to press on. Where do I find the video ram?.
    Thanks again djnick989. xliliz4th
    Genius:
  • 1,067 Answers
Hi how are u 1st off replacing aonbord video not that easy its built on motherbord ok would need new bord and
Posted on Jan 28, 2008
  • 6 more comments
  • nick helpap
    nick helpap Jan 28, 2008
    cd rom drive if thers firmware update from ther website that would help read new disk but if older model will have hard time if u have usb ports u can buy a dvd rw burner on side throw usb prot extnal one
  • nick helpap
    u would need a new mobo tho for video repair does the video vga out port work on a reg crt screen use it that way instead it could lcd screen also going bad
  • nick helpap
    http://www.impactcomputers.com/toshiba-t...
    hers the parts list for yours also
  • nick helpap
    ever single litte part they sell it there 70 bucks for motherbord but ther tricky getting in and out u could sell it as is on ebay toward new one also dont forgetto mark this as fix ya now ok
  • nick helpap
    Model name/No.
    Tecra 510CDT / PA1232U-T2xx
    Processor
    Intel Pentium(R) 133MHz w/VRT
    Memory(MAX)
    16MB/144MB
    HDD
    2.02GB
    Display
    Display
    TFT Active Matrix Color 12.1 968x726
    Display controller
    C&T HIQV32 (CT65550)
    Video RAM
    2MB
    Sound
    CS4232, OPL3(YMF262), YAC512
    PC Card controller
    TypeIIx2 or TypeIIIx1
    IrDA
    IrDA 1.1:4Mbps
    USB
    (none)
    Modem
    28.8/14.4Kpbs Data/Fax/Voice
    LAN
    (none)
    Last update
    11-18-2004 these are your specks
  • nick helpap
    u could cheak your video ram pop it out back in once
  • nick helpap
    your welcome buddie anytime u need anyting come back talk to me mark tis ass fix ya then and vote
  • nick helpap
    video ram on bottem usally under a door
Why has my Toshiba flat screen tv got a broad green horizontal band across the top?
One of the circuit board ribbons connected on the vertical control is probably loose there is a few vids on you tube for this repair , failing that some of the driver capacitors need replacement with higher voltage caps same microfarad.
Oct 15, 2014 | Toshiba Hi-Def Flat-Screen Lcd/Led TVs 32"...
Westinghouse LCD TV - broad vertical green and blue lines
try to go to the factory reset and see if that helps. If not, you can then check your connection. if you use component (red, green and blue for video and red and white for audio), make sure all the color matches when you plug it in. if everything have been checked then you need to replace the main board and it should correct the problem.
Jun 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Toshiba Tecra 510CDT Laptop
hi,
this is mainly dependant, on what input/outputs the laptop has at the rear. If it has a printer port, or USBs. you need to be able to physically connect, laptop to printer, as i,d imagine it has no bluetooth or infra-red et,c.
Thankyou for using fixya.
Mike at compurepair.
Jan 20, 2009 | Toshiba Tecra 510CDT (P000224080)...
No windows system
in bios put the boot sequence so that cd is first when computer as to boot from cd click enter after installing xp - use drivers downloaded here (if u dont have the cd) - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1073769787&rpn=PA1232U&modelFilter=510CDT&selCategory=3&selFamily=1073768664&selModel=1073769787|PA1232U
Dec 26, 2008 | Toshiba Refurbished TECRA 510CDT...
My tecra 510cdt needs a bios update it.wen i turn on the computer it sais put in bios disket and press any key.....how do i put it in it has no disket drive?? i downloded the bios on a disket but how do i...
you have to buy a toshiba FDD attachment case which plugs into the computer.I have the opposite problem.. I have a built in floppy drive but I must buy a cd-rom .
Dec 15, 2008 | Toshiba Tecra 510CDT (P000224080)...
Memory Up-Grade
hi there, the memory slot is under the main case. lift the computer up from the front and you will see a panel on the left with two small screws. undo these two screws and you will see the memory card. they have also two small screws that must be removed to be able too remove the card.
sam
Oct 31, 2008 | Toshiba Tecra 510CDT (P000224080)...
Start Up Problem
Usually means that Operating Sytem needs to be reloaded or the hard drive is dead. Try to re-install Operating System first.
Hope this helps!
Mar 24, 2008 | Toshiba Tecra 510CDT (P000224080)...
Dotted vertical line on my Toshiba Tecra
Please post in the correct section.
Oct 24, 2007 | Video Game Consoles & Games
Toshiba Tecra 510CDT (P000224080) Motherboard Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
