Error 1202
SOURCE: trying to redeem itunes and I keep getting error
Right click on "redeem" on the itunes home page. It will give you a choice to open or copy - choose "copy this link". Then paste it into a new internet explorer window. Accept the security prompt then it should load up the space to put your code in.
SOURCE: how do i fix itune error 1202
load up the space to put your code in. This works on all internet programs - copying the link into a new window.
SOURCE: error 1202
make sure your date and time and time zone are correct on your cpu
if this dose not fix it try this
1. If you look a the Certificates snapin for your 'Local Computer' in
MMC and only find a few Trusted Root Certificates then you should run
the Microsoft May 2009 Trusted root certificate update from here: http://www.microsoft.com/downloads/details.aspx?FamilyID=f814ec0e-ee7e-435e-99f8-20b44d4531b0&displaylang=en
The above fixed the 8192 problem for at least one person that I know of.
As a matter of fact it wouldn't hurt to re-run that whether you think you're missing Ceritificates or not.
2. If you ever had your computer connected to an Active Directory
domain then there might be a problem with your Certificate policy. The
Local Computer Policy MMC snap-in might show you some settings that you
can fiddle with.
This fixed a raft of problems for people to do with updates and sign-ins an so on.
3. Apple now have a support document that points to to an MS
knowledgebase article on how to troubleshoot certificate problems on
Vista. It's long and involved and the final step if nothing has worked
is a reinstall. You should check out the article here: http://support.microsoft.com/kb/822798
This last one was presented as a solution to problems that were fixed by the first two so try those first.
Best of luck!
SOURCE: I am trying to redeem an itunes card on
TRY COPYTRANS MANAGER ITS EASY AND BETTER THAN ITUNES
http://fr.copytrans.net/copytrans.php
DON'T FORGET TO RATE
