Question about Denon AVR-3801 Receiver
Systems setup I cannot get the systems setup to display; I have successfully initialized the microprocessor
  • lowmwnd Feb 06, 2008
    My problem is that I cannot get the setting menu to display on my TV screen. When I select the setup function on my DENON RC-883 remote control unit, the display on the remote control indicates "AVR SETUP" 0)))How do I get to the display settings in the settings menu and where are they displayed
    Genius:
  • 1,665 Answers
Your user manual is here:See Troublelshooting, check also for correct fitted interconnections.
http://www.manualnguide.com/download/manual-guide/denon-avr-3801-av-receiver-owners-manual.html
Posted on Feb 20, 2008
  • 1,512 Answers
You can dwon load the manual from http://www.manualnguide.com/dl/5939/
I will have a read and see if I can help you directly
Posted on Feb 06, 2008
  • Graeme Ross
    Graeme Ross Feb 06, 2008
    hehehe the instructions are quite extensive for this model, but pretty easy to follow. You may have to get through it yourself to get there :)
  • Graeme Ross
    Graeme Ross Feb 07, 2008
    How did you go with the setup, was the manual any assistance to you? A "FixYa" rating would be great if it did. :)
    Graeme
    Genius:
  • 3,422 Answers
Hii,
Try this out:
Go to the display settings in the settings menu. Pick HDMI for your video output and follow the steps to set your screen resolution. When I accepted the video settings I was taken automatically to the audio settings options. If you’re not given this option just go to the set audio output settings and enter this screen. Pick the optical connection and follow the screens choosing the audio options that match your receiver. DD and DTS.
At this point you should have video to your TV through HDMI and audio to your receiver through the optical cable.
Goodluck,
please dont forget to rate me as fixya..
Posted on Jan 28, 2008
Standby indicator flashes
When the "Protection" indicator comes up the display panel of my receiver or the On/Standby LED is flashing, does that mean my receiver needs to be repaired?
The "Protection" light comes on when the receiver's current sensing and thermal monitors detect some unusual operating condition that, if left unchecked, might damage the amplifier. This can happen if there's a dead short in a speaker wire or if you're using very low impedance loudspeakers at high volume for an extended length of time. On older model AVRs you may see the word "Protect" on the receiver's display. More current models will indicate a flashing red light on the Standby LED when a Protection circuit trips
n thermal cases, the circuitry will automatically reset after a few minutes of cool down and the Protection indicator will go out and normal operation will resume. If the protection light came on due to a speaker wire short, low impedance condition or a bad speaker, the receiver's power will need to be turned off to reset it. Before turning the power back on, all speaker wire connections should be checked for their integrity at the receiver side and at the speaker side. If the protection light goes on immediately after you turn on the receiver, disconnect the speaker wires at the receiver side and retest. If the receiver's protection light goes off, then there would still seem to be a problem with one channel's speaker wires or speakers. Connecting them one by one and retesting should allow you to find the problem speaker or connection.
If after checking all your connections, the Protection indicator stays lit, you may need to "initialize the microprocessor (see the FAQ on that topic) or take your receiver to an authorized repair center for a diagnostic. The "Initialization of the Microprocessor" or "reset" procedure can be found in your owner's manual on current model AVR product. Please note, this will erase all setup configurations in the system and require the system to be setup again. You may want to mark down the settings before resetting your receiver to aid in the setup process. If you had an installer setup your system, you can contact them for assistance and any associated costs that may apply to setup the receiver again would be the responsibility of the owner.
Jul 17, 2016 | Sony DAV-FR1 System
How to reset avr5805
n very rare instances, the AVR-5805 internal microprocessor might lock up, or otherwise cause mis-operation. This might be caused due to an AC line surge or line spike noise, or by static electric discharge on or nearby the unit, or to connected components. If the condition cannot be corrected by powering off the unit, including disconnection of the AC cord for a period of ten minutes and subsequent re-connection, then the unit may have to be re-initialized. Doing so will restore the microprocessor to its original out-of-the-box state, with all custom memories and settings erased, and the original factory default settings restored. Only use this procedure if you are sure that the microprocessor requires re-initialization.
1 Switch off the unit using the Main unit's power operation
switch.
2 Hold the following STANDARD button and HOME THX
CINEMA button, and turn the Main unit's power operation
switch on.
3 Check that the entire display is flashing with an interval of
about 1 second, and release your fingers from the 2 buttons
and the microprocessor will be initialized.
NOTES:
If step 3 does not work, start over from step 1.
If the microprocessor has been reset, all the settings are reset
to the default values (the values set upon shipment from the
factory).
May 13, 2015 | Audio Players & Recorders
I m getting c6 code on my msi motherboard 7642
Hello here is the homepage:
http://www.msi.com/product/mb/890GXM-G65.html#/?div=Manual
Make sure ALL the drivers is installed on the mainboard:
http://www.msi.com/product/mb/890GXM-G65.html#/?div=Driver&os=All
Post Status
FF Power on and first initialize CPU.
C0, C1, C2 Early CPU Initialize.
C4, C6 Initialize chipset.
D4, D5 Initialize memory.
08 Initialize keyboard.
2A, 31 Initialize onboard devices. Load Option ROM (VGA and RAID
option ROM) form BIOS to memory.
37 Displaying sign-on message, CPU information, setup key
message and any OEM specific information.
38 Initialize USB device and different devices.
3C Mid POST initialization of chipset registers. Detect different
devices (parallel ports, serial ports and coprocessor in CPU...etc.)
75, 78 Initialize INT 13 devices and IPL devices. (include SATA/ PATA
HDD and CD/DVD ROM).
87 Enter setup screen. BIOS setup if needed/ requested.
A4 W ait for user input at configuration display if needed.
A7 Display the system configuration screen if enabled.
B1 Save system context for ACPI (Advanced Configuration and Power
Interface). Prepare give control to OS loader (INT 19H).
00 Pass control to OS Loader (typically INT 19H).
AA Enter OS (Vista or W indows XP).
Look also here:
http://www.dewassoc.com/support/bios/awardbios_error_messages.htm
Did you upgrade the ram memory, or the cpu ??
When and how did this problem occur ??
Jan 31, 2013 | Computers & Internet
How to reset the protector circuit in a Denon AVR 3801 unit?
14 INITIALIZATION OF THE MICROPROCESSOR
When the indication of the display is not normal or when the operation of the unit does not shows the reasonable result, the initialization of the
microprocessor is required by the following procedure.
1 Switch off the unit and remove the AC cord from the wall
outlet.
2 Hold the following AUTO button and PCM button, and plug
the AC cord into the outlet.
NOTES:
• If step 3 does not work, start over from step 1.
• If the microprocessor has been reset, all the button settings are
reset to the default values (the values set upon shipment from
the factory).
• Calling out preset stations from the main unit‘s panel.
1 Press the TUNING PRESET button. TUNING
PRESET
FUNCTION 2 Turn the FUNCTION knob and
select the desired station.
TV CD CDR/MD/TAPE RECEIVER
VCR DBS/CABLE
SKIP
SKIP
ENTER
MEMORY
CHANNEL VOLUME
VDP DVD
TUNER PHONO CD
DISPLAY
SETUP RETURN
MENU
SHIFT
SURR.
PARA. OSD
A/B
MUTING
BAND MODE
TUNING
TUNING
2 1
(Main unit)
Jun 11, 2010 | Denon AVR-3802 Receiver
Denon DRA-37 Receiver-Remote lock on. Need to unlock.
Refer to the "Initialization of the Microprocessor" section of the manual (page 16 of the PDF version of the manual).
1) Turn the unit OFF using the On/Off switch (not the standby switch).
2) Depress both the Speaker A and B switches, and turn the Power ON.
3) The entire display should flash at 1-second intervals. The microprocessor should be reset, and the remote should be unlocked.
Jan 23, 2010 | Denon DRA-37
Display Panel Microprocessor No.
is a programed microprocessor (microcontroler) , only the jvc has correct version.
Jan 17, 2010 | JVC THD-50 System
Freezes
Leave it unplugged for 24 hours. Sounds like the failsafe for a power surge. This is typical for RCA products. I have a 54 inch rear projection TV that will only tune 16 channels and none of them are correct when it surges. The solution: 24 hours unplugged. I also have the same type of thing with my RCA DVD recorder... Never had it happen to surround sound, though.
Sep 26, 2009 | RCA RT2380 Home Theatre System System
Denon 1508
This should resolve your propblem... taken from the Denon USA FAQ...
You’ll rarely need to "initialize the microprocessor" under normal operating conditions. In a few cases, the microprocessor will temporarily freeze or "lock up" just as your home computer does. When this happens, just follow the guidelines in the back of your owner’s manual to "unlock" the microprocessor and restore normal operation. (This is directly comparable to rebooting your computer. It’s an electronic wake up call to your unit’s temporarily paralyzed microprocessor "brain.")
If you experience some unusual behavior -- a channel that’s suddenly silent, "forgotten" level adjustments, some eccentricities in your unit etc. -- you may need to reset the microprocessor. Of course, you should check all connections carefully first. But if you’ve eliminated these items as a source of potential problems, you may need to go through the initialization process.)
Initialization is easy. Please refer to your owners manual for instruction on reseting the microprocessor as each unit may have its own individual protocal for reset.
What causes these problems? Several things can -- a jolt of static electricity, a current surge through an antenna input, etc. But don’t worry, the microprocessor is well shielded from any permanent effects.
When you do initialize the microprocessor, remember that this erases any setup instructions you may have previously programmed into the unit. However, the on-screen menu will quickly get you through a new setup. And, if you write down your preferred settings BEFORE you reset your unit’s microprocessor, you’ll have an even easier job!
If in the event you do intialize microprocessor reset please refer to your owners manual for instructions on setup..
Sep 20, 2008 | Denon AVR-1508 Receiver
Moved computer... now when botting up....I get the following message
Just "close" the message-window, after performing the indicated actions.
Aug 26, 2008 | Computers & Internet
Denon AVR-3801 Receiver Logo
173 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
