Question about Nikon Coolpix L11 Digital Camera
Lens error I've had my camera for about 9 months and it's been working fine. 2 weeks ago I turned it on, went to take a photo and instead got this "Lens error" and the lens won't retract back in and the camera won't do anything. Sounds like this is a typical problem. Anything I can do to get my camera working again?
  • Anonymous Feb 24, 2008
    when i turn the camera on it says lens error. how do you fix it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
SOURCE: lens will not retract
Just solved this problem on my Dimage G530. An earlier time the lens (inner part) was cocked to one side after a small drop. Pulling it back straight, out of the outer part, fixed it and the lens closed.
Then just this past trip, the lens was not retracting with the MF00C error and the lens looked straight. It had opened in a pocket and gotten bumped. I had even taken the case off but that did not offer any insight into fixing the problem. (They certainly cram a lot into the case). I was about to give up and just buy a new camera or was going to inquire at vistek to see how much it would cost to have it looked at this Saturday because I really like the camera. Anyway, to make a long story short. I decided to pull hard on the inner part to pull it out - basically try to cock it to one side then the other. The lens popped out to it normal position and now everything works fine. So it appears that if bumped the lens goes to a lock position to prevent any damage to the drive mechanism.
Hope this helps someone else with this problem.
Posted on Jan 23, 2008
  • 5 Answers
SOURCE: lens error 126,1,0,-9
Lens error 126 is telling you that the lens is out of alignment. You can try cycling the On/Off button several times to see if it works itself.
Posted on May 03, 2008
pull on the lens.
Posted on Jul 13, 2008
arclight1217
  • 208 Answers
SOURCE: Lens problems... kind of
HEY, I REALLY LIKED YOUR PRESENTATION OF YOUR PROBLEM! VERY WELL DONE! I'M GOING TO OFFER A SOLUTION THAT I THINK WILL SOLVE YOUR PROBLEM. I THINK YOU NEED TO GO ONLINE TO TO THE CANON WEBSITE AND DOWNLOAD THE LATEST FIRMWARE FOR THE SD750 OR AT LEAST DOWNLOAD A FRESH VERSION, THEN CONNECT YOUR CAMERA TO THE COMPUTER AND SYNCRO THE TWO AND SEE IF THIS DOESN'T SOLVE THE PROBLEM. I BELIEVE THAT WHAT HAS HAPPENED IS THAT THE FIRMWARE HAS BEEN CORRUPTED SOMEHOW AND YOUR CAMERA IS GETTING CONFUSED SIGNALS. RESETTING IT TO FACTORY DEFAULT FIRMWARE SHOULD SOLVE THIS PROBLEM. IF IT DOESN'T THEN I THINK THERE IS A POSSIBILITY OF A MECHANICAL PROBLEM, BUT RIGHT NOW I FEEL IT IS A FIRMWARE PROBLEM. TRY THIS AND SEE IF THIS DOESN'T WORK.OK? REPLY TO:ARCLIGHT1217--GOOD LUCK!
Posted on Nov 11, 2008
  • 105 Answers
SOURCE: lens won't retract
There are special springs, motors, gears, and guides inside these lenses.
If your lens won't retract, one of the above is bent, misaligned, or broken. There is not a 'quick fix' that can be applied in your situation since it is a physical problem, not a software malfunction. You can try to dismantle yourself but speaking from experience you are likely to make the problem worse. If you are unwilling to attempt repari yourself, either take it to a repair shop or upgrade.
Posted on Aug 18, 2009
I have a Half a year old TAMRON 70-300mm Lens which i have actively used for both macro and normal zoom almost every day since i bought it. For maybe one month ago, when i turned to portrait mode it said:...
cleaning the contacts on lens and camera is about all you can do.
If its faulty and still under warranty then you'll need to send it back to where you got it from, any attempt to fix it yourself will void the warranty.
Mar 03, 2017 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Hi i have a JVC Everio model gz-ms215aaa camcorder had it about 3 months went to use it yesterday and everytime i try to zoom in it wouldnt work but instead it makes it all out of foucus and you can't...
There is a problem in the lens housing, probably caused by a defective ccd sensor not working properly, or seized motor. The systems control board is tied with the ccd circuitry and constantly makes any correction through a small motor, if one of these fail it can cause a variety of symptoms. Since the camera is three months old it should be returned for repair or exchange.
Jan 31, 2011 | Cameras
CAMERA FROZEN..nOTHING WORKS. sAYS "LENS ERROR. rESTART CAMERA"
try to remove the ring over the lens- this is just alluminium ring. I had same problem when my camera felt on floor... i thought its wrecked ... but it was 4 months ago and since that i made thousands of photos and its working fine. Remove the ring, i did it by forcing it, twisting and when removed - lens error was not appearing. I fixed that ring and placed back with a little super glue. Everything is ok.
May 21, 2010 | Canon PowerShot SX20 IS Digital Camera
About 2-3 months ago my camera suddenly said lens
If it says lens error all you have to do is try pushing the lens back in. If that doesnt work, sorry! lol =(
Oct 10, 2009 | Canon PowerShot A710 IS Digital Camera
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 29, 2009 | Nikon COOLPIX P90 Digital Camera
Dropped my camera in a pool of water in a glacier 12 months ago. I immediately took out the battery and memory card. I then spent 2 hours with a hair dryer drying the camera. Since then the camera has...
There is no relation between the two incidents that you explained. The recent problem might have occurred due to damaging of the lens. MY solution is to replace the objective lens ( lens assembly) and the motor ( if needed ). If it costs much, then go for a new one, since digital camera with high pixels rates are available cheaply now a days.
Mar 30, 2009 | Canon PowerShot S500 IXUS 500 Digital...
Wont turn on but light is blinking
Are there any error messages on the LCD display?
Will the camera lens stay out when the camera is turned on?
Can you still take a photo/flash/sound without seeing the photo?
If the camera will not turn on even with a fresh set of batteries it could have a system or lens error in the camera.
a possible lens jamb when closed and the green led on top comes on then shuts off after the lens attemps to extend but cant.
Aug 29, 2008 | Nikon Coolpix L11 Digital Camera
Nikon Coolpix s210
Hey SandyG1019,
If you just purchased this camera 2 weeks ago it might still be within the retailers return/exchange period, and I would suggest you just exchange it for a new one. This error message should mean that something is obstructing the movement of the lens (i.e. sand), but could also be do to a problem with the lens mechanism itself. If you choose to try and resolve the problem you could try blowing compressed air into the side of the lens to try and dislodge whatever is stuck in the lens. This being said I would suggest instead having the camera looked at by an authorized service technician since the camera is most likely covered under a manufacturers’ warranty, and the repair would most likely be free. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 29, 2008 | Cameras
Lens Error - Cool Pix L6 - Camera unuseable
helppppppppppppppp mne is stuck open and it wrks but whn iturn it off it stays open (1/2 of it)
Jan 07, 2008 | Panasonic Lumix DMC-FX10 Digital Camera
Dont know if this will help anyone. I had a lens error for ages. In my long lasting devotion to google serk I found that many equall contenders found that a strike with a soft book in different directiions solved the problem. I ended up beating the camera from all angles with the palm of my hand. But hey! it worked. 4 months later im looking for the cure to system error 2. If you can help wi that one.
Sep 11, 2007 | Nikon Coolpix 5200 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
