Question about Brother DCP 130C All-In-One InkJet Printer
Printhead cleaning how can i clean the printhead manually?
  • 832 Answers
The ph can only be cleaned by useing original brother ink (carts).
Do run the cleaning feature by pressing ink etc.
There is NO way to clean the ph outside the machine due to the ph technique!
Posted on Jan 28, 2008
HP Photosmart B210a error message
Simple. Remove the ink and printhead. You can remove printhead by pulling gray latch up and sliding printhead up and out. Clean printhead gunk off using warm running water. Remove any ink gunk on the right side of printer if you see any. Turn printer off and on. See if problem went away. If it did, try putting the cleaned printhead inside printer again. If problem comes back, seems like the issue is with a bad printhead. Below are video instructions on cleaning head manually. The printheads are not same. B210 printhead is not the same with HP 6500, but instructions are same.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Jun 07, 2017 | HP DeskJet F4280 All In One Printer InkJet
5300aio
Take out the cartridges and clean their sides, which pick up hair.
Clean the cartridge-cleaning mechanism itself on the right, especially the foam pad.
Take out the cartridges and clean the bottom of their carriers.
Aug 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Getting lines across the page when printing pictures
This is a well known (painful)phenomenon.From the steps recommended by HP inthe manual I would try the following:1. Usea higher print quality setting.
2. Align the printer.
3. Clean the printheadTo clean the printhead from thecontrol panel:Press Setup.Press the down arrow button tohighlight Tools, and then press OK. Pressthe down arrow button to highlight Clean Printhead, and then press OK. Theproduct cleans the printhead. Pressany button to return to the Tools menu.After cleaning the printhead, printa print quality report. Evaluate the print quality report to see if the printquality problem still exists.
Oct 22, 2011 | HP Photosmart Premium C309A All-In-One...
It does not print black
Try Cleaning the Cartridges manually and automatically.
For the cartridge clean it with a damp lint free cloth and also for the printheads wher eyour gonna be inserting the cartridges.
Follow these steps do do the automatic aligning and cleaning:
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Go to Printing Preferences 3. Click the Features Tab 4. At the bottom of the window you will see Printer Services or Device Services. Click on it. 5. Choose Align Printheads on the list.
For Cleaning the Printheads, Instead of choosing Align Printer choose Clean Printheads.
I hope this helped.
Try Printing Again. I hope I was able to solve your problem. :)
Feb 14, 2011 | HP Photosmart C7280 Printer
My printer will not do color it comes out purple
I hope this helped.
Feb 13, 2011 | HP DeskJet 820Cse Printer
I am getting white lines going through my documents? Does that mean I need black Ink or does it mean my proint heads are having a problem?
hello, yes you will need to replace printhead, just the black/yellow #88 . thats if you already tried going thru the cleaning process.
Nov 30, 2010 | HP OfficeJet Pro K8600 Printer
Blue and yellow will not print have replaced ink cartridges
Manually cleaning the printhead isnt difficult and could solve your problem. You need distilled or de-ionized water, tap water might work but i dont recomend it. You need a lint free cloth, dont use paper towels or anything that will leave material behind that will clogg the nozzls (a clean soft tshit should work tex Wipe lint free cloths work the best) . Heating the water will help. Remove the printhead look at the nozzles on the buttom. you should see 6 lines in a yellow area. you want to wipe with these lines not accross them. do not scrub or use circular motion. Wet the cloth area your going to wipe with well. put some pressure but dont break it and wipe a few times slowly. you can also soak the nozzles in warm or hot distilled water just only in very shallow water just enough to touch the nozzles do not submerge the whole printhead. you can also google manually cleaning inkjet printheads just use your best judgement some things people do to clean a printhead might damage them. If after manual cleaning and using the built in cleaning the prints1.gif still dont come out right call kodak and request a new printhead. I hope this helps! Don't Let this road bump turn you away from these printers they print nice prints and have low cost ink. Kodak and or I am not responsible for any data loss or any damage to any equipment that occurs as a direct or indirect result of following the procedures described above.
Dec 15, 2009 | Kodak 5300 All-in-One InkJet Printer
Clean print heads? Kodak 5300
Yes,it can be cleaned but not manually. Here are the steps on how to clean the printhead on your printer:
a.Press the Menu button of the printer.
b.Use the down arrow key and go to Clean Printhead.
c.Press OK button then select Deep Clean.
Sep 24, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How do you take print head out for cleaning
Check the link below. This should help http://www.fixyourownprinter.com/forums/printer/18540 Thanks Ranjit
Jun 16, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Kodak 5100 EasyShare All in One
Hi Miss Patti,
Regarding your issue, you shouldn't clean the printhead manually because it might damage the printhead with it. You need to clean the printhead with the printer first. Open your Home Center Software first on your computer and then click on the "?" mark icon on the top right corner of the window and then under General Links tab click on Maintenance and then choose Clean Printhead. Clean the printhead twice and then try to make some prints. If it still doesn't work, call kodak technical support so that they could replace your printhead because it might be already damage due to the manual cleaning of it. I know it will work...
Kodak technical support: 1-800-421-6699
I hope I helped out... Take care!
-BabyYanYan
Nov 05, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Brother DCP 130C All-In-One InkJet Printer Logo
226 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
