2003 Mazda MPV Logo
Posted on Dec 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to replace the #1 coil on a mpv mazda van. Which coil is 1
Where is the #1 coil on the mpv mazda van.
Ronnie Wilson
Level 3:
  • Master 1,596 Answers
  • Posted on Dec 28, 2009
Ronnie Wilson
Master
Level 3:
Answers
1596
Questions
Helped
880957
Points
5626
# 1 Cylinder is the one Closest to Firewall on Passenger side, so if it has a LONG Spark Plug Wire Fallow it back to the COIL and that is the COIN you Replace,
Jonah Oneal
Level 3:
  • Mazda Master 14,092 Answers
Jonah Oneal
Mazda Master
Level 3:
Answers
14092
Questions
0
Helped
7234386
Points
44533
Looking under hood to the back left cylinder.that number 1 follow it to coil number 1.
1helpful
How to remove the stereo on a 1996 mazda mpv
Mazda MPV Dash Trim Removal, Stereo Removal - Auto ...
? 3:38
https://www.youtube.com/watch?v=REoTeVM2S-o
Jul 1, 2013 - Uploaded by Robert DIY
Dash trim removal: 5 minutes. This video will show you how toremove the dash trim piece on the Mazda ...
[PDF]MAZDA 1996-UP MPV - Scosche
www.scosche.com/media/guides/ma381.pdf
164. 1996-UP MAZDA MPV. MINIVAN. RADIO REMOVAL USING SCOSCHE DT-1 TOOLS . FRONT DOOR PANEL. FRONT AND REAR DOOR 61/2" 3-HOLE.
DIY Mazda Car Radio and Speaker Removal, How to Remove
www.carstereoremoval.com/htm/stereoremovalMazda.htm
'96-99* Car Stereo Removal · Ford Stereo Removal Tools Stereo Removal Tools. How To Install and Remove Mazda MPV Van Car Radio and Speaker, '89-95*
MY VAN HAS NO POWER WHEN I TRY TO DRIVE IT
Sounds like you have a issue with fuel flow . Try to replace inline fuel filter . Also Fuel injectors could need flushing or possibly replacing . Try filter first .
1helpful
2answers
I have a 2003 Mazda MPV , the problem only happen
I ahve same issue with my 2004 MPV. I replaced the plugs, coils etc. No help.
did you ever get it fixed?
10helpful
2answers
I am getting a P0031, P1512, & P0421 code
P0031 - most likely pointing to a failed O2 sensor (bank 1 sensor 1 is located before the catalytic converter)
P0421 - failed catalytic converter or a failed O2 sensor
P1512 - intake manifold shutter valve is stuck - may be caused by the O2 sensor, but may not
I recommend replacing your O2 sensor first and see what happens
4helpful
2002 mazda mpv 3.0 cylinder 2 misfire
For the 2002 Mazda MPV 3.0L V6 DOHC:
Firing Order:
1-2-3-4-5-6
Cylinders:
4..........6...........5
3..........2...........1
Ignition Coils:
4..6..5
3..2..1
4helpful
Where is the starter on a 1995 Mazda MPV van?
it is located under the skid plate. you'll need to remove the front drive, the alternator, and power steering pump out to remove the starter. need to remove the bottom cover to see it.
21helpful
2answers
2004 mazda mvp firing order
The firing order is 1-4-2-5-3-6. The cylinders are, front bank is from drivers side to passenger, 6-5-4 , and 3-2-1 at the firewall. This is for a 2004 Mazda MPV.
Top Mazda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mazda Expert? Answer questions, earn points and help others
