Question about Epson Stylus CX9400 Photo Printer
Cx9400fax I am able to fax out but I can not receive faxes.
  • 5 more comments
  • jj93rx7 Feb 29, 2008
    I have the same exact problem. Epson support staff was of little help. I think it is ridiculous to have to disconnect my answering machine that is connected downstairs on the phone in the kitchen and connect it up stairs in the bedroom where I have the CX9400FAX. The fax function for receiving faxes is useless. I can fax out but cannot receive faxes.
    JJ93rx7@comcast.net
  • hsrosebud Apr 05, 2008
    I have the same problem. Did not know when I bought the machine that the answering machine had to be hooked up directly to the CX9400. Useless to fax out when the CX9400 is upstairs in the office and the answering machine is in a more convenient location (kitchen) for my wife. This snag should be more clearly explained in the literature.
  • lvg73 Jun 01, 2008
    I was told I need to change the baud rate to 9600, but I cannot get Epson to tell me how. Any ideas?
  • diaz1027 Sep 09, 2008
    I am able to fax out but I can not receive Faxes. this machine is useless
  • Anonymous Oct 21, 2008
    I had the same problem, I called Vonage Tech Support. All Fixed in less than 5 minutes. Great AllInOne. I could not send a fax. I referred to Epson Quick Guide, same problem. Vonage had me switch a few cables. Fax sent okay, Vonage sent me a test fax, received okay.
  • bcope01 Nov 21, 2008
    I have the same problem with my Epson Workforce 600 All-in-one, that is, when my phone answering machine (in the kitchen) answers first, the Epson Workforce 600 fax (in my home office) fails to receive the fax. Are there any work-arounds for this, other than connecting the answering machine directly to the All-in-one as suggested by others here?
    I have the same problem with my new Epson Workforce 600 All-in-one. That is, when my phone answering machine (in my kitchen) answers first, the Epson All-in-one fax machine (in my home office) fails to receive the fax. This happens even though everything is configured properly according to the owner's manual for the printer. Talked with Epson Tech Support and initially they said it should work, but later in the discussion they said that I should connect the answering machine directly to the EXT line of the Epson All-in-one. I'd like for things to work (as they did with my 7 year old HP All-in-one) with the answering machine still in my kitchen and the Epson All-in-one in my home office. Any work-arounds or solutions now that this has been a problem with Epson printers for some time now?
  • 4 Answers
Epson Quick Guide is incorrect.
Not sure of your exact situation but .........
Your answering machine MUST be connected directly to the output of your CX9400 and you can't use an answering machine with multiple "mailboxes". Set your answering machine to 4 and your CX9400 to 5/6 rings. Epson "Technical Support" has no clue of this problem .... yet.
The machine routes the call to your answering machine, it it's an incoming FAX and the answering machine starts the CX9400 will recognize the incoming transmit signal, turn on the FAX function, and disconnect your answering machine.
You may need to adjust the CX9400 rings setting based upon the duration of your answering machines announce message (longer message = greater number)
Posted on Jan 30, 2008
    Problem Solver:
  • 6 Answers
3 Suggested Answers
SOURCE: How do I change baud rate to 9600 on Epson CX9400Fax?
This fax speed is 33.6 or 33600
You can change settings to 14.4 or 14400 but not to 9.6 or 9600.
Under: Fax Settings you have this choices:
Speed Dial Setup
Scan and print setup
Communication
Header and time
Under Communication:
DRD
ECM - error correction put this one: off
V.34 - this one is for speed: on - 34400; off - 14400
Posted on Aug 19, 2008
localwonder
  • 6784 Answers
SOURCE: Our Epson Sylus CX9400Fax Series is not receiving
Ok, here's a check list for you.
SENDING
Check the following:
  • Make sure the phone cable is connected correctly and verify that the phone line works by connecting a phone to it.
  • Make sure that your recipient's fax machine is turned on and working.
  • If you connected the Epson Stylus CX to a DSL phone line, you must install a DSL filter to the line or you won't be able to fax. Contact your DSL provider for the necessary filter.
  • If your phone line has static or other noise problems, turn off the ECM (Error Correction Mode) setting and try faxing again.
    Follow these steps to turn off the ECM setting:
    1. Press Setup.
    2. Select Fax Settings, then press OK. You see this screen:
    4. Select Communication, then press OK.
    5. Press cp_button_44_er.gif and select ECM. Then press cp_button_42_er.gif and set it to Off.
    6. Press OK.
RECEIVING
Try the following if you can't receive a fax:
  • To receive faxes automatically, make sure the Auto Answer light is turned on. To turn it on, press the Auto Answer/Space button.
  • Make sure paper is loaded.
    1. Press Setup.
    4. Select Communication then press OK.
    6. Press OK.
Posted on Mar 03, 2009
What is error message 0407?
EPSON Stylus error message 0407
Aug 11, 2014 | EPSON Stylus CX9400Fax Series
Trying to fax i keep getting an error code 0503 what does this mean?
Try turning off error correction:
1. Press setup.
2. Select fax settings and press ok.
3. Select communication and press ok.
4. Press the down arror and select ECM and press the right arrow and set it to off.
5. Press OK.
The problem should be resolved.
Jun 22, 2010 | Epson Stylus CX9400Fax InkJet Photo...
Fax Problems
check and verify that the land line is correctly plugged into the right connector at the back of the fax.. secondly check that you actually have a dial tone.. this is not a fax problem.. its a connectivity problem.. Smiles
Mar 31, 2010 | Epson Stylus CX9400Fax InkJet Photo...
I had a wireless router installed and can no longer fax using CX9400FAX series. Receive communication error ''no dial tone''. There is a phone line from the phone to printer and from printer to wall jack....
I too was having the same problem. We too have a wireless router hooked up. However, that had nothing to do with the problem. Our problem was that the top phone line port on the fax machine should run to the phone jax in the wall. The bottom phone line port on the machine should run to the phone. We had them switched around.
I hope this helps.
Dec 22, 2009 | Epson Stylus CX9400Fax InkJet Photo...
Epson stylus CX9400fax.....paper goes in crooked then jams
take the paper out and tap it ,then put in the fax
that might work.
Nov 14, 2009 | Epson Stylus CX9400Fax InkJet Photo...
How do I enlarge the print on an Epson Stylus CX9400 fax series?
the printing wizard it has the size choice ...but the actual size its established by the limitations of the printer ..anyway all documents may be re-sized in the computer and than printed...even in pieces and reattached after if the printer supports only A4 paper maximum
Sep 04, 2009 | Epson Stylus CX9400Fax InkJet Photo...
I have a problem with finding the full software/epson CX9400fax
Please send the model numberof your epson printer. that is the only way you can be helped. There are so many epsons with the same capability as yours.
Cheers!
Apr 15, 2009 | Epson Stylus Multifunction Printer/...
Our Epson Sylus CX9400Fax Series is not receiving or sending faxes. We have already done the phone call to India thing for 90 minutes. All settings were changed and tested. They are now back to factory...
SENDING
    1. Press Setup.
    6. Press OK.
RECEIVING
    1. Press Setup.
    6. Press OK.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
Can't send or receive
fax machines are analog devices and will not work reliably on a digital phone line.
Epson Stylus CX9400 Photo Printer Logo
485 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
