Could be a bad roll out switch a small thermal device located around the base of the burner ,locate on wirind diagram an ck with ohm meter should read closed , also could be to much gas presure if natural gas get the gas co. to check presure , also could be a faulty equipment ground from supply from breaker panel make sure well grounded and connections tight ,must have this gnd to keep gas valve open , hope some of these ideas help .
