Question about JVC AV-48WP30 48" Rear Projection Television
Red and Green lines
I have red and geen lines through my JVC rear projection TV, we had the convergence fix 2 years ago, what can be the problem now and is it worth fixing we only had the set for 6 years.
  • 1luz Jan 31, 2008
    The only part we've replaced was a convergence board 2 years ago. That problem caused the RBG to not line-up properly and caused a 3-D affect. Like if you were looking at a 3-D image without the proper glasses.
    This new problem kinda comes and goes. Initially when the TV is turned on, it's clear, then all of a sudden, we get red and green lines through the picture. Sometimes the lines go away, but always seem to return. I've not attempted to replace any parts other than the convergence board and was wondering if you could suggest what parts may need to be replaced.
    Thanks!
  • Rv4family Feb 01, 2008
    New- Tv given by friend said needed to replace card number stk 392-110.
    have been picking up clues here and there on where and what to do.
    Have 2 new ones ,finally found where they go.
    Question, it looks like no soldiering is involved in this replacement, is this true?
    If so, is just the heat sink compound all I need when replacing them? Do the pins just sit in there straight?
    Did I see that a good number of these ( stk392110 B 2 E 8) can be knock off's? Any way to tell on them? Not sure where wife bought them and should i up grade to a different one?
    Your help would be greatly appreciated.
    Thank's
    Rv
    Jvc AV-48WP30
    Chassis # A105
    DOM- August 02
    Genius:
  • 1,694 Answers
Yes,it's worth fixing....if done right, with first quality parts.
Should hold up 3-5 years....What can you tell me about
previous parts ??...............................................T.
Posted on Jan 30, 2008
PANASONICV that now has a "blurred" screen. We can see the channels but it looks like it's has a shadow around the images. The screen in in a red hue with green blur. TX-51P100H 51"...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 29, 2011 | JVC AV-56WP74 56" Rear Projection...
We have a RCA D52W23 rear projection TV. Now the color looks like it is in 3D. A friend has the same problem a few years ago and bought a part on line and fixed it themselves. What is the part and where...
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 19, 2011 | RCA D52W19 52" Rear Projection Television
Sorta looks like 3d red&green mostly also has red lines arching across bottom 1/2 of screen
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 14, 2011 | Zenith R57W46 57" Rear Projection...
I have a large sony hd read projection / a few days ago - i started getting faint green lines that are arched - higher in the center - symmetrical, an about 1.5 inches apart - a few times , the tv has...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 09, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
Convergence is out...trying to manually adjust but only have blue and green lines....no red...how can i fix this?
Tv have 100% convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 22, 2010 | JVC AV-56WP74 56" Rear Projection...
I have a jvc av56wp74 double immages in red and
Ur tv have convergence problems,it dead.U must have soldering tools and know how to solders to fix the convergence problems.U must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 05, 2010 | JVC AV-56WP74 56" Rear Projection...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
RCA 46 inch convergence problem
AM sorry, but can you provide your model number TV and chassis please?. I will tell you location parts. Thank you
Jul 14, 2008 | RCA P52926 52" Rear Projection Television
Red lines on screen
REPLACE THE CONVERGANCE IC"S.STK392
Dec 23, 2007 | JVC AV-48WP30 48" Rear Projection...
Wavy green and red lines
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Nov 09, 2007 | JVC AV-65WP74 Rear Projection Television
JVC AV-48WP30 48" Rear Projection Television Logo
114 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
