Question about Garmin StreetPilot i3 GPS Receiver
Usb circuit board connection
Part came completely off of board, when trying to straighten pens one pin broke. Need part #, and where they maybe purchased.
Same thing happened to me. what you need is called the USB PLUG. i bought 5 of them from a place called DIGIKEY ( and here is a link straight to the page you need (
Posted on Mar 28, 2009
My 1gb transend pendrive is show insert disk
hi Gagan,
please remove the covers carefully and check the soldering points of metallic parts and pen drive pcb some times the middle two pins are broken.
if yes you can re solder it with soldering iron and relevant soldering aids.or ask someone to do so.
then clean the printed circuit board with electronic contact cleaner.
most of the time i found the pen drives with broken pins.
Good luck.
let us know the results.
Apr 06, 2013 | Transcend TS1GJFV30 - 1GB JetFlash V30 USB...
Livescribe smartpen (Echo) not able to charge
Sounds like the micro USB cable is defective and needs to be replaced. But, first try the cable on another USB port to be certain that the USB port is OK.
Hoope this helps.
Jan 05, 2012 | Smart Pulse Livescribe pen
How to switch on d915pwk desktop mother board?
You will either need to connect the front pannel connector on the several pin located on the motherboard or you can short circuit this by using a pen or screw driver and contact the 2 red pins (on the front pannel connector)
Aug 18, 2011 | Intel Motherboard
I have a Motorola gps that fell and landed on the usb charger plug and broke the pin off the board. the battery is a sanyot0052 with 4 wires . Can you tell how i can charge this battery via the 4 wires so...
Don't try and charge the battery directly, as it is a lithium battery it can explode if not charged correctly.
You can try connecting (soldering) wires to the circuit board where the socket was connected to feed in 5V from the power adaptor or USB lead.
Mar 08, 2011 | GPS
I get this error message when trying to update my daughters smart pen: 136 InitFunc_NFlashID_Error Format it,use our FAT
I was able to get one of these working that had a dead pen. I reset the pen (insert a pin in the side), and plugged it into a USB port on my computer. I then opened the smartglobe 3 software and it updated the pen. A couple times it failed to format the pen.
I had to switch the pen to another usb port and then it finally formatted and downloaded all of the info to it. It took a looooong time to update. Then it said it was updating the Clock. It then told me to disconnect the pen, but... I was wary of this because most usb devices require some kind of dismounting before you unplug something.
So instead of disconnecting the pen when it said to, I quit the smartglobe software and shut down the computer, without ever unplugging the pen. Once the computer was off I finally unplugged the pen from the usb cable. I turned off the pen and turned it back on. It then worked, (a guy came on and said something)! I think maybe there isn't a way to "eject" the pen properly, so shutting down might (big emphasis on might) allow the usb connection to disconnect successfully without corrupting the flash memory of the pen. Or I just got really lucky. Either way I'm happy! (And not about to update it again I might add).
Aug 31, 2010 | Oregon Scientific Smart Globe Junior
USB CF Card reader broke, how do I fix?
Card readers are cheap.
For example:
$5 delivered to your door.
Apr 30, 2010 | Cameras
System hang when i insert pen drive
1) Check The USB Port for Damaged, Bend Or Broken Pins.
2) Check The Pen Drive For Physical Damage.
3) Try The Pen Drive In another USB Port. (i.e. if u r using the pen drive in the FRONT PANEL USB PORT than try it in BACK PANEL USB PORT)
4) Try The Pen Drive In Another System.
5) Tye Another Pen Drive.
6) If All Above Is Fine Then Format The PEN DRIVE.
7) Try The PEN DRIVE now.
8) Is Issue Still Persists Then..
9) Uninstall the CHIPSET/MOTHERBOARD DRIVER COMPLETELY and then clear %temp% & prefetch files and Restart Your System.
10) Install The Latest CHIPSET/MOTHERBOARD DRIVER and ANY AVAILABLE FIRMWARE for the motherboard..
May 22, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Broken Female audio plug
take a 1-1/2" safety pin, straighten it a bit, heat the tip, stick it inside the broken pin, let it cool then work it out w/the broken pin attached. I had the same problem & this worked.
Nov 05, 2008 | Onkyo Audio Players & Recorders
Convergence in and out?
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it.
Jan 04, 2008 | Mitsubishi WS-65807 65" Rear Projection...
USB Mode/Battery compatible problem
I think maybe one of the battery connections are damaged if so try to straighten them with a very thin long nose pliers .The other possbility could be that you have a faulty circuit board .Service it at sony or hopefully youve bought an original battery
Aug 26, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Garmin StreetPilot i3 GPS Receiver Logo
866 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
