Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My RCA Monitor is clicking a little more information about
My RCA Monitor is clicking at the blue bulb in the front, the white housing that holds the blue bulb in its place is clicking, you can see the flash of light inside the white housing that is holding the blue bulb that the wire leads into. After the monitor warms up the clicking goes away I would like to also find the schematics for this monitor
The rempl flyback
Posted on Jan 28, 2008
1974 mgb high beam indicator on dash does not work
Those little bulbs do wear out. You really need a nimble body and small hands to reach above the speedo and tach to get at the housing that holds the bulb. As I recall it was a blue lens on that indicator and a *****-in type bulb.
Apr 08, 2013 | Cars & Trucks
I want to know how to change the bulb in my headlight of my 2005 pontiac montana?
1. Open the hood.
2. Remove the front turn signal/parking lamp
assembly. See Front Turn Signal, Sidemarker and
Parking Lamps on page 5-46.
3. Pull the assembly away from the vehicle.
4. Unscrew the black retainer ring that holds the bulb
assembly in place.
5. Pull the bulb assembly straight up from the
lamp housing.
6. Unhook the electrical connector by lifting up the
blue tabs and pulling the bulb out.
7. Install the new bulb through the black retainer ring
and into the electrical connector.
8. Tighten the black retainer ring in place. Push the
bulb firmly enough so that the blue tabs hook over
the tab on the bulb.
9. Carefully put the bulb assembly back into the lamp
housing. Be careful not to damage the bulb on the
headlamp aiming bar.
Same guide is here in the manual along with pictures.
On page 370
Mar 02, 2011 | Pontiac Montana Cars & Trucks
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
My lamp went out on my rca and i dont know what lamo it is
your lamp for the M502h185 is the following
RCA 270414
that part is available several places on the interent and you can buy the bulb itself or the bulb mounted in a new housing (if yours is damaged) ... if your housing is ok and you can figure out how to mount the new lamp in it then its a little less to get only the bulb ..
here is one place that has both options:
May 22, 2010 | RCA M50WH185 Television
How do I replace the turn signal bulb on my 1997 Jeep Grand Cherokee? It seems like I must remove alot of the front end to get at the bulb... is this true?
For the front turn signal:
There are two ways to get at the bulb.
Way 1) YOU NEED A SKINNY SHAFTED STAR SCREWDRIVER. This is how the manual describes it: Unscrew the 2 star screws holding the parking light housing on. One is on top, the other is between the parking light and the turn signal. This second screw can be very difficult to get to because the parking light and turn signal housing are very close. After the parking light housing is off, you can unscrew the turn signal housing. The screws should be located on top of the housing, underneath the parking light housing.
Way 2) This is the way I did mine: First, you have to take the headlight housing off. It should be pretty easy to pop off if you pry it the right way. It is held on by 1 square clip and 2 ball and socket clips. There is a small risk of breaking the ball and socket clips, as getting the headlamp housing off does require a little force, so be careful. You may want to take the headlight bulb out first, but isn't necessary. (Removing the right side bulb may require removing the battery) Once the headlamp housing is off, the turn signal bulbs should be very easy to get to.
To remove the bulb, simply turn the bulb socket and it will come out.
For the rear turn signal:
Open the lift gate.
There are 3 hex screws that hold each rear light assembly on. I'd recommend a hex screwdriver, as a socket wrench or box wrench would be very hard to use on the screws. Once the hex screws are off, just tug on the light assembly and it will come off. The bulbs are very easy to get to. The turn signal is the yellow one.
Nov 10, 2009 | 1997 Jeep Grand Cherokee
97 Pontiac Trans Sport. Turn signal problem
verify the ground wire is good, black wire, its down on the frame rail, opposite of the air filter housing, if thats OK, it, could be the turn signal switch. but the wires go from the turn signal switch, through the Daytime Running Lights Module, through the fuse panel under the hood, then to the light socket. wire is light blue / white coming out of turn signal switch to DRL module, then its light blue all the way to the socket.
Oct 19, 2009 | 1997 Pontiac Trans Sport
Splicing a monitor output wire from my laptop to
This cant be done.. You need a video card that has the yellow jack [video out]
the red and white jacks are your sound,
get a headphones to RCA adapter for the sound card[computer] going to projector or radio...[just need the RCA adapter to get sound]
But to get the video[yellow jack] to work you NEED a video card with a yellow jack inslled in your computer...or a video card that has a adapter for RCA video
I have a
Sep 30, 2009 | Toshiba Satellite A135-S4527 Notebook
Bulb or Lamp Unit Timer
"paison" was correct and his solution did work for me. Make sure you first select TV on your remote. Now hold down the dvd/vcr button at the bottom of your remote while also holding down the "volume down" button on th front of the TV. Hold until a "Blue Reset Menu" appears on the screen and say the timer has been reset. Noe just follow the on screen instructions.
Dec 28, 2007 | Televison & Video
RCA D52W20 Blue Tube doesn't power on
From your description it does sound if the blue crt has failed. But it can be the crt board or a high voltage issue. intermittantly like that could be a connection problem. is there any hissing ..cracking or smells?
Dec 16, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
