Question about Kenmore 62702 Microwave Oven
Kenmore elite microwave
I have a Kenmore Elite Microwave model #80822. I was cooking on my stove this evening with the vent on the microwave on. When I tried to use the microwave, it would not work. None of the buttons worked. I unplugged the unit to try to reset it. It still will not work. What could be wrong and how can I fix it?
  • 2 more comments
  • navyfamily Jan 28, 2008
    Yes, the display still lights up, but none of the buttons do anything.
  • Anonymous Dec 19, 2008
    I have the same problem :(
    The vent can't be turned off, however the light inside the
    microwave and display lights do work. None of the buttons
    respond when I poke them. Please help
  • Anonymous Mar 15, 2014
    My Lenmore Elite Microwave suddenly stopped working, is there a reset button?
  • Anonymous Mar 19, 2014
    Light doesn't come on ay , burned out.
  • 2,130 Answers
Does the digital display light up at all? Is it completely dead? Are you sure it has power? Have you tried another outlet? If the outlet is good and the unit is completely dead, the internal fuse may have blown. You can try to take the cover off (with the unit unplugged) and look for a blown fuse. Try replacing the fuse with an EXACT fuse of the same rating. Try plugging the unit back in again and see if the unit comes back on. If not, you may have a power supply issue or defective Magnetron.
Please let me know what you find and we'll go from there.
Good Luck,
- Jim
Posted on Jan 28, 2008
How do I set the timer and use the cook function at the same time on my Kenmore microwave model 405
Either your microwave is defective or you don't understand how to use it. Try Googling (Kenmore)(74229)(manual) without parens to get instructions or go to www.searspartsdirect.com for the same.
Sep 16, 2016 | Kenmore 74229 Elite Black Countertop...
Was it just the exhaust fan that came on? If so this is normal when cooking on the stove for long period of time without the fan running. The heat builds up under the microwave and eventually activates the fan.
Sep 05, 2014 | Microwave Ovens
Have Kenmore microvave and the vent starts on its own
Actually, that's a feature! If you cook much on the range (stove) beneath the microwave, the heat will cause the microwave bottom to heat up quite a bit (just touch it!), and the microwave will turn on it's exhaust fan in an attempt to save itself from burning up. It will shut off in about 15 minutes after you turn off the source of heat.
But if the fan comes on by itself even when the microwave is cool (or at least not hot), then you probably have a defective fan thermostat. This thermostat is located behind the control console on the inside bottom of the microwave.
Aug 27, 2014 | Kenmore Microwave Ovens
I have a Kenmore microwave. The vent will just start on its own and can't shut off
Installing a microwave / convection oven above a stovetop
Needs to be properly vented to outside the house. Only install a microwave that's designed for over-stove use in this space.
Aug 25, 2014 | Microwave Ovens
Why is my microwave model 60609 making extremely loud noise and not heat?
Usually that is a sign that your magnetron tube has gone bad (shorted out).
Jun 10, 2014 | Kenmore 80822 80823 80824 80829 1500...
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Can you put and over-the-counter microwave over a stove?
Yes, that is what they are made for, As long as it has a vent that can be used to vent the smoke from cooking it can be mounted over the stove. Normally the bottom of the microwave should be mounted 16" to 19" above the stove top. The microwave must have a vent with a blower motor in order to be used above a stove top. Most have a thermal switch that will turn the microwave vent on once the temperature reaches a set point.
Jun 12, 2010 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Covers over cooking/night lights are melting
I have a microwave above my stove also but it has not done what yours is doing. I would try a lower watt bulb since it would not give off as much heat. You may need to replace the lens or else just take it out and get rid of the problem altogether. You would have a brighter light anywas even if you kept the same bulb. Most of those bulbs are florescent and do not put out much heat anyway and seldom cause heat problems, esp. giving off enough heat to melt something.
Apr 17, 2009 | Microwave Ovens
Kenmore Elite Microwave hood
Please reply back with your brand and full model number so we can help you.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
May 26, 2008 | Kenmore 64683 Microwave Oven
Kenmore 62702 Microwave Oven Logo
406 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
