Question about Toshiba Satellite A100-S8111TD Notebook
Time and date is stalling
I just had the hard drive replaced and now i adjust the time and it rus for a while then stalls. It is also causing applications such as lime wire to stall it is very frustrating as whenever i open the laptop it is at the date and time i last used it same as if i walk away for a few hours the time will stall. Is there a simple solution
  • 3 Answers
It is most likely that your cmos battery is dying out. You will have to replace it. And as far as limewire and other applications are concerned, many of them will not run right if the appropriate time and date are not set correctly. You can look up your particular laptop online to see what type of cmos battery it takes and order it and replace it yourself. There are many useful sites that will tell you step by step how to replace your cmos battery. Or, you can take it to a service tech and have it replaced, but this will probably be more expensive for a laptop. Good luck.
lori
Posted on Jan 28, 2008
    Novelist:
  • 113 Answers
I'm not sure what you are describing, but I think you mean that your laptop is shutting itself down (likely hibernate or stand-by mode) quickly if you are not actively using it? If so, you can adjust these settings by going to Control Panel - Power Options, and select different timing settings or even entirely disable hibernate and stand-by. Realize that if you are not plugged into the power cable this will use the battery up faster, since that's what these power saving settings are for.
If you are saying that your sysem Clock is freezing, then something else is the problem, and the laptop may have been damaged when the hard drive was replaced.
Engine stalls but starts right back up
tune up time?
stalls, are cause by 5 major systems fail, (50 causes)
so i have only these questions.
1: can you save the stall with the fast right foot.
???????? was it very easy, kinda hard, or I can;t
dies WOT save the stall, wot -= wide open throttle (yes, pedal to the metal,
Jan 24, 2014 | Jeep Wrangler Cars & Trucks
Causes stalling
seems like flooding
you remove spark plugs. see them soaked with fuel. flooding.
does car restart easy? never stated.
if you lose spark , the ECU cuts fueling, but not 100% of time.
so spark tests are first.
also make sure the EGR is not stuck open.
when the car starts to stall.
can the fast right foot , prevent it?
if yes, is it easy to do.or is it fighting you hard. or not possible.
now you have some ways and means.
Sep 16, 2013 | Honda Cars & Trucks
2009 Hyunda Santa Fe stalls while driving
I had a similar problem with my Santa Fe. It occurred intermittently but after I turned the steering wheel to the left. After much screwing around by the dealer and trying to baffle me with BS we heard about a strange solution. I am not a mechanic but the problem somehow related to a spring in the Airbag on the steering wheel. Changed the spring and "Stone the flame'n crows" problem solved. Never had a problem since.
Jul 27, 2012 | 2003 Hyundai Santa Fe
Bought the Bike Used from a HD Dealer 2004 XL1200C Sportster. 2400 Miles 2nd time I took the Bike for a ride It was Slamming into Gears Very Loudly, Had the Clutch adjusted and Gasket Replaced, Next Time...
check for the pinched vacuum line at the carb,, sportys are hard to locate because they are tucked in way behind , it ay have come disconnected, unless there is a load on the motor it will idle fine, add a little load and you get the feeling no fuel is getting through unless you rev it up
Jul 01, 2011 | Harley Davidson XL 1200 C Sportster Custom...
I have a F250 lariat with a 460 - truck stalls when I put it in gear - even after it runs for 20 min. Sometimes it will stall while I'm driving. I had carborator replaced last year. Hope you can help.
Some possible causes could be:
Vacuum leaks cause an engine to run lean witch can cause the vehicle to stall when put into gear.
Improper base idle adjustment can cause the vehicle to stall when shifted into drive or reverse
A malfunctioning or damaged carburetor can cause the vehicle to stall when shifted into drive or reverse
Improper ignition timing can cause the vehicle to stall when shifted into drive or reverse.
A malfunctioning or damaged transmission or torque converter can cause the vehicle to stall when shifted into drive or reverse
Oct 31, 2010 | 1987 Ford F 250
1995 Ford Windstar has an intermittent stalling issue.
If it wont stall in neutral or park it may have a bad torque convertor clutch in the trans causing the engine to stall.
May 07, 2010 | 1995 Ford Windstar
Per diagnostic codes i have replaced CTS and MAF on 1993 Mazda 626 2.5 6cyl, now it stalls and quits at a stop, does this have to do with clearing the codes after the work is done, does the computer need...
u followed the pin point tests for these codes you had? did you disconnect the battery after you installed new parts? sounds like u have not fixed the problem, you do have a repair manual correct? did you check the intake air hose for cracks on the bottom which will cause a stall? did you clean the idle speed control valve and the throttle valve, they can also cause this stall, never adjust the the hard stop screw, it will chnage nothing and cause all kinds of other problems, it is not the problem, most likely the intake is sludged up clean it and then disconnect battery for 5 minuter, driv about 50 miles and problem should clear up, if it doesn't you have other issues, recheck for codes.
Oct 19, 2009 | 1993 Mazda 626
1988 Bronco 2 stalling out.
have te ignition module and stator been replaced? that is the common cause of this, and yes the engine being out of time can cause this stall out, when you time the engine remember you must remove the timing shorting bar at the distributor connector to the TFI ignition module or the timing will be severely retarded
Jul 17, 2009 | 1988 Ford Bronco II
1997 GMC Savana stalling
HI. Had the same problem and searched for months. its pump injectors. You re looking for 1500$ part and 400$ labor.
Mar 21, 2009 | 1997 GMC Savana
Toshiba Satellite A100-S8111TD Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
