Question about JVC KD-LX10 CD Player
Player not coming on
When i plug up the cd player the lights will come on then go off it will take in cd's but the buttons wont come out
0 characters
1 Points
I plug in my ipod using the alpine ipod chord and starts to charge but ipod wont show up on deck and wont play my ipod, why does it fo that? an idea I have come across by accident..when you plug it in and it asks for pc suite or mass storage device, hit the mass storage button and it should work for you.......
Feb 24, 2011 | Alpine CDE-102Ri CD Reciever, iPod and USB...
Blaupunkt sevilla rmd168 turns itself off and wont come
Have you disconnected your battery or any fuses recently as it looks as though it requires a code to be entered.
May 11, 2010 | Blaupunkt Sevilla MP36 CD Player
Cd player will eject cd but wont turn on..
It sounds like the ignition or power wire isn't properly connected. I guarantee that's the problem.
Radio wont come on
There should be a reset button on the unit. That would probably be the first thing I would look at.
Feb 09, 2009 | Kenwood KDC-MP238 CD Player
CD Stuck in cd player
There should be a reset button on either the face of the player or under the faceplate if its removable (tiny black button). Otherwise to remove the cd disconnect the unit and then plug it in or remove the memory fuse or battery lead for 5 seconds.
Jul 05, 2008 | Pioneer DEH-P4100
Not workin correctly
Jun 29, 2008 | Dual XDMR-7700 CD Player
New installed cd player wont work
did tou wire the red line to 12volts when the ignition switch is in the acc or on position- and the yellow wire is powered at all times regardless of the position of the key switch?
Apr 02, 2008 | Aiwa CDC-X227 CD Player
Why won't my cd player eject?
Hi Darla ,
If your problem is with new cd's your trying to play then the try this. New cd's often have around the inner and outter edges and if such disc is used, this may be the reason why it wont play. What you do is take a pencil and use the side of the pencil to rub the edges of the cd. It should clear it up. Now if your problem if that it wont let the cd come out the only thing i can think of is to press and hold the EJECT button and CD button at the same time for more than two seconds. Good Luck =)
Mar 03, 2008 | JVC KD-G120 CD Player
Please Help
check face plate maybe contact dirty if not well our in trouble sometime it not worth to repair it cheers
Jan 08, 2008 | Sony CDX-S2010 CD Player
JVC KD-LX10 CD Player Logo
21 people viewed this question
Top JVC Car Audio Receivers Experts
xxxxxx xxx
Are you a JVC Car Audio Receiver Expert? Answer questions, earn points and help others
