Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Freezer not freezing
The Kenmore side by side quit mqking ice and then the freezer will get cool but will not freeze?
    Scholar:
  • 90 Answers
How old is the unit? Does it seem to have air circulating in freezer? Is the temp in the refrigerator side cold enough? One common thing is for the defrost heater to stop working which causes the freezer to ice up and stop circulating air. If you can put all items in a cooler and unplug the unit for several hours leaving the freezer door open. Plug it back in and see if it starts blowing frost again. That would indicate a bad defrost system. It can be several things but most common are the heating elements. If the defrost timer stops working you get the same results. If this does not produce positive results then it could be a weak compressor or gas leak. Best have a repairman check it or get a new one if it is the compressor.
Posted on Jan 28, 2008
Freezer quit freezing ice cream Thur night, but everything else was fine, not everything is starting a slow thaw
either the ptc overload relay on the compressor is bad and the compressors not operating to cool the unit or the evaporator coil behind the freezers inside wall is iced up and cant let cold air out due to this blockagethen its a defrost heater/thermostat on the evaporator coil issue
Jul 02, 2011 | Kenmore Side by Side Refrigerator
Kenmore sidebyside 106 is freezing wide open on freezer side and barely cooling on frig side. there is ice in venting on the frig side
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | Kenmore 53642 / 53644 Side by Side...
2 weeks ago the ice box was not cooling.. We turned off and back on and it worked fine except the bottom shelv in fridge was freezing items.. Now my freezer is not working.. tried the off and on and it...
Could be a defrost problem. When the coils get froze over it quits coling. Turning it off will temporarily defrost a portion of the coils and it works for awhile. Check behind the freezer wall for frost buildup. If it is, you will have to determine if the timer, heater or termination thermostat is the culprit.
Eric
Dec 23, 2009 | Kenmore 50522 / 50524 Side by Side...
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
could be, but can also be a MAJOR problem not worth fixin! thermostats usually tend to be relieable for that they either cool althe time or quit altogether, the fact that freezer cant freeze ice, sounds as if its running(thermo good) perhaps a freon leak , not enough freon, bad compressor or some other sealed system issue
Nov 10, 2008 | Kenmore Refrigerators
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore side by side - icemaker seems to run too fast because the ice cubes are often hollow and they stick together in large clumps. Everything else in the freezer is frozen solid, so I know the freezer...
IF FREEZER IS A THE CORRECT TEMP/ O-10 DEGREES, THE FREEZER IS NOT THE PROBLEM. THERE IS A THERMOSTAT IN YOUR ICE MAKER, IT IS NOT ADJUSTABLE. IT IS A SMALL BI METAL SWITCH THAT TRIGERS ICE MAKER WHEN IT REACHES ITS PROPER TEMP. THE PROBLEM IS, IT IS TRIGERING IT AT TO LOW OF A TEMP.NOT ALLOWING THE ICE TO FREEZE SOLID. IF YOU CAN HANDLE IT CHANGE BIMETAL SWITCH OR CHANGE ICE MAKER ITSELF.
HOPE WE HELPED YOURS TRULY FXIT
Feb 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
287 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
