Question about NexxTech NSFTMD1
Computer reboots when trying to connect to internet
I installed a NexxTech NSFTMD1 in a computer with the WIN 98SE OS.
Everytime the modem dials up, the computer reboots itself.
Any info. towards solving this problem would be greatly appreciated.
Thank You!
  • 574 Answers
SOURCE: modem is making loud connection sound itself
unsolder the speaker, its the black can with the hole in it. No other method unless it attaches to the sound card via a cable.
Posted on May 19, 2008
0 characters
1 Points
Error in installing modem driver
do this...
START.. SETTINGS ..CTRL PANEL...TEL/MODEM .. ADD new modem, but tick the box "I will select modem from a list"
Use STANDARD MODEM.....56000 and press OK
If the modem is connected correctly to a phone line it should be able to dial out.... Don't select your modem driver at all
Please rate my help++++Thanks for using FIXYA
Feb 27, 2010 | D-Link DSL 200 (DSL-200) Modem
HP USB Modem does not break dial tone
If the information connected to your post is all correct (56k V90 usb), and you are using one line for both the internet and the fax, you should hang up from the internet before you try to dial out the fax.
You have not indicated your PC model, so I don't know what operating system you are using. For XP and newer versions, you have to set up and configure the fax using the wizard or configuration software. If you have not done that yet, you need to.
In xp, go to start, Programs , Accessories , Communication , Fax , and then click Fax Console.
You said your computer is new. Win 7 and Vista are much the same:
1.Click the Start button , click All Programs, and then click Windows Fax and Scan.
2.At the bottom of the left pane, click Fax, and then click New Fax on the toolbar to launch the Fax Setup wizard.
3.Click Connect to a fax modem and follow the instructions.
You also need to make sure that your fax/modem is correctly listed in the control panel. In XP, start, control panel, printers and devices. If you do not have a fax printer listed, you need to "install a local fax printer."
The installation wizard should work in both OS without much trouble. If you do have difficulty, Microsoft and adobe both have "virtual printers" you can use. Look in Microsoft office or online.
Also check control panel of 7 to make sure that your modem and fax are listed correctly. Thanks for using Fixya.
Jan 01, 2010 | HP (56K V90 USB) Modem
Alcatel Speed Touch PCI Modem doesn't work on my Win 98
Windows 98 0r 98se are no longer supported by any kind of internet service providers anymore only windows 2000 and newer. hope this helps.
Aug 10, 2009 | Alcatel Speed Touch Modem
Modem issue
a mother board is a big thing to replace. you may want to just buy another computer if thats the case. it may also be the way it hooks up. is it a card. if it's a card thta slot maybe shorting it out. if so try a diffrent slot. my best advice is move away from dial up all together.
Aug 27, 2008 | NexxTech NSMODX2
New computer running slow
if you are using dial up, you shud not have a modem.. modem is just for DSL connection
if you have a modem probably you are using a DSL connection
dial up - connection using a phone line with internet connection; cannot use fone while on internet
DSL/modem- connection using a modem plugged in with computer and fone line; able to use fone even when on internet.
Jul 10, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Installing modem
Most newer cases have a side panel that slides off, look in the back and there should be a screw or a latch that secures the side panel, remove and the panel will slide back about 1 inch and then off. Older ones have the entire top 3 sides formed as one piece and the 3 sided top comes off.
May 19, 2008 | NexxTech NSFTMD1
Modem is making loud connection sound itself
May 02, 2008 | NexxTech NSFTMD1
Hello sir,             I am using P3 computer and I am using  Win XP -Service pack-2. I am using Reliance connected CDMA WLL Phone made by ZTE Corporation for internet surfing.My problem is, for every time while I connect to internet, my modem to be reset and then only I can enter into the internet.I have made all installtions as per the service provide's instructions.I have to reinstall everytime or sometime I can't enter. whether I need any modem drivers for easy access to the internet.My phone model is CLASSIC -23. If yes which type of drivers and how to install.
Oct 13, 2007 | Modems
Open Questions:
See all NexxTech NSFTMD1 Questions
NexxTech NSFTMD1 Logo
Top NexxTech Modems Experts
Brian Sullivan
Brian Sullivan
Are you a NexxTech Modem Expert? Answer questions, earn points and help others
