JVC DR-MV150B DVD Recorder/VCR Logo
Posted on Dec 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have connected my unit to my TV but can't seem to find the correct buttons to press on the hand held remote to bring up the screens to continue set-up.I have yet to find a menu.
josetejas
Level 2:
President:
  • JVC Expert 300 Answers
  • Posted on Jan 25, 2010
josetejas
JVC Expert
Level 2:
President:
Answers
300
Questions
0
Helped
137871
Points
710
Try the Home button
2answers
Raynor Model 120-8 Garage Door Opener. How do I program a Raynor Model 120-8 to a hand held remote please?
ensure that the remote is Raynor and compatible with you model GDO
on the back of your garage door opener there is a colored learn button--press and release-the learn indicator light will glow for a short time usually 30 seconds. within thirty seconds press and hold the buton on the hand held remote that you wish to operate your garage door. release the button when the motor unit lights blink. if you don;t have a light, two clicks will be heard. it has learned the code. procedure will be different for multi function control.
I want to connect my tv to wifi but i couldn't find the setup menu
first your tv needs to be a "smart" type tv set this has both a wired network connection and a wifi connection if it does not have this you will need a converter , you will need your routers password , as you will need to authorize the tv in the routers set up (yes even if you have a dhcp router ) , turn tv on if your using a universal remote most times they cant access the tv set-up menu (on purpose ???) anyways find the tiny buttons along edge to set id bet its near the power button , till you find "menu" press this it will bring up a new screen on tv , use your up/down arrows on remote to go to network , press enter on remote this will bring up a new screen , select "enable" on wireless network an press enter key , this will bring up a new screen it should after a few minutes show a list of routers It can "see" select your routers name using up/down arrows on remote and press enter , a password prompt should show up , enter the network password (from router) and press enter when done , takes a few moments but it should finally say connected (if you did it right ) then exit out of this and bring up "browser" from your menu , this will look like a normal pc browser an you can enter your destination from there , this is a general set up method your tv might be slightly different but this shows suspected path to follow
No buttons work on LG 47LG5000. Neither remote nor the TV side buttons work but I can access all features by holding down 2 buttons for 15 seconds (eg. MENU and INPUT held together first brings up the...
check to make sure you have power to unit. If you do you may have a internal power problem. Have you gone thru a recent lighting storm? If so see your home insurance co. For coverage to repair or replace unit.
Remote to Insignia Digital converter box will not do anything but turn unit on/off, although the light does flash when buttons are push - nothing happens.
Well, try it two different ways, as follows: But be sure that the tv-channel that's selected for tuning will be identical to the "output-channel" which you'll then select for the Insignia converter-box. So, if you first select Channel 3 for tuning the tv set, then you must later select Channel 3 on the "Output Channel" choice for the Insignia "set-up" menu. Similarly, if you first select Channel 4 for tuning the tv set, then you must later select Channel 4 on the "Output Channel" choice for the Insignia "set-up" menu. Be consistent! If you find that the Insignia menu-screen does not subsequently appear after tuning the tv to Channel 3, then start-over with Channel 4 as your proper tv-tuned station to initiate the pop-up screen for the Insignia menu.
Now, here's an example that assumes Channel 3 is the proper tuning-station for your tv-set within your particular region: You will first tune your tv-set itself (by means of its handheld tv-remote) to Channel 3. Be sure, however that your Insignia converter-box is turned-on and properly connected to your tv-set and antenna.
On your tv's hand-held remote-controller, you should find a button that serves as its "input selector" -- with a typical descriptor such as "Input" or "Line" or "Video/Antenna." Press that button, and enter successive channel numbers until you get to Channel 3. You may need to press the digits 03 to signify Channel 3. The tv-screen may be colored bright blue at that point.
Then, as you switch to holding your Insignia remote-controller, press the "Menu" button. (Please note that you will need to press hard and firm upon the buttons of the Insignia hand-held in order to get proper responsiveness; a quick touch of the button will not be effective.) After pressing the "Menu" button, the Insignia menu should now appear on the tv-screen. Now, you need to use your Insignia hand-held remote-controller (not the tv hand-held remote-controller again) to travel through the menu-screen to the "Setup" feature. Then, select "Output Channel." Proceed to select Channel 3 -- which will then be printed for you next to the Output Channel feature. Finally, under the same Setup menu, go to "Auto Tuning" -- which will commence a complete scan of all available channels.
Remember, if tuning by Channel 3 is inappropriate for tv-tuning within your particular geographic region, then repeat the above process by substituting Channel 4.
When you are done, you will rely almost exclusively upon the Insignia hand-held remote controller. You do not especially need to use your tv hand-held remote-controller again.
However, be sure to avoid standing in front of your tv-set to change channels by buttons or knobs upon the tv-set itself. Tuning again upon the tv-set itself will negate your prior tv-setting for either Channel 3 or Channel 4 -- and thereby sabotage your working set-up!
I myself incurred chronic anxiety yesterday (June 13), as I was stunned that the Insignia menu-screen did not appear immediately when I pushed "menu" on the Insignia hand-held.
The only buttons that worked on the Insignia handheld remote-controller were the Power-on for the converter-box and the Power-on for the tv-set.
(continued next page)
Because my expectation had been this process would take just a few minutes, I was deeply frustrated and impatient. However, I recognized that my apprehension of impending loss was absolutely appropriate as emotional "signal-processing" for me personally -- in contrast to my formerly high expectation of immediate fulfillment, completion, and gratification. Instead of my intention for quick success, I faced the stunning dread that the Insignia box had become defective or that I'd fail to ever figure-out the problem. I would not have been so impatient if I hadn't expected immediate success for the set-up.
I rejected the slogan that "I just want to get this over with!" I rejected the option of stomping upon the Insignia box! Amidst my hour-long anxiety, I summoned "Courage" -- a mode of patience to accompany my internal "quivering." I did a Google search.
From this Fix-Ya web-site and other troubleshooting sites, I had strong clues that improperly setting Channel 3 or Channel 4 was a primary culprit for the failure of the Insignia's menu-screen to appear. When I finally succeeded, my anxiety dissipated quickly with a temporary relief. But then came the anger that the Insignia "User Guide" had not been clear to explain the process. From that aftermath of outrage, I decided to promptly compose this protocol to assist others who have been similarly tormented -- perhaps to the extent of incorrectly believing that the Insignia converter-box was a defective product requiring prompt replacement.
I need to program my new dishnet work remote
Turn the receiver off using the front panel power button and then press the channel up button and hold it until the unit powers on. This will bring you to the system info screen. There you will see the remote address the remote needs to be programmed to- usually 1. Now press and hold the SAT button on top of the remote until all buttons on the top lite up and release. Now key in the two digit number shown on the screen - numbers under ten will be preceeded buy a zero. Now press the pound sign on the bottom right of the keypad. The SAT button will flash three times and then you will need to press the record button . YOU SHOULD BE ABLE TO MANUEVER THE HIGHLIGHT ON THE SCREEN AND EXIT OUT OF THE SCREENS . Thanks for using Fix Ya. ---and if you can not bring up the system info screen perform the steps on the remote itself until you reach the correct number that will control the receiver- 01 thru 16. if you need further assistance please let me know.
Problems with insignia remote control on converter box
Well, try it two different ways, as follows: But be sure that the tv-channel that's selected for tuning will be identical to the "output-channel" which you'll then select for the Insignia converter-box. So, if you first select Channel 3 for tuning the tv set, then you must later select Channel 3 on the "Output Channel" choice for the Insignia "set-up" menu. Similarly, if you first select Channel 4 for tuning the tv set, then you must later select Channel 4 on the "Output Channel" choice for the Insignia "set-up" menu. Be consistent! If you find that the Insignia menu-screen does not subsequently appear after tuning the tv to Channel 3, then start-over with Channel 4 as your proper tv-tuned station to initiate the pop-up screen for the Insignia menu. Now, here's an example that assumes Channel 3 is the proper tuning-station for your tv-set within your particular region: You will first tune your tv-set itself (by means of its handheld tv-remote) to Channel 3. Be sure, however that your Insignia converter-box is turned-on and properly connected to your tv-set and antenna. On your tv's hand-held remote-controller, you should find a button that serves as its "input selector" -- with a typical descriptor such as "Input" or "Line" or "Video/Antenna." Press that button, and enter successive channel numbers until you get to Channel 3. You may need to press the digits 03 to signify Channel 3. The tv-screen may be colored bright blue at that point. Then, as you switch to holding your Insignia remote-controller, press the "Menu" button. (Please note that you will need to press hard and firm upon the buttons of the Insignia hand-held in order to get proper responsiveness; a quick touch of the button will not be effective.) After pressing the "Menu" button, the Insignia menu should now appear on the tv-screen. Now, you need to use your Insignia hand-held remote-controller (not the tv hand-held remote-controller again) to travel through the menu-screen to the "Setup" feature. Then, select "Output Channel." Proceed to select Channel 3 -- which will then be printed for you next to the Output Channel feature. Finally, under the same Setup menu, go to "Auto Tuning" -- which will commence a complete scan of all available channels. Remember, if tuning by Channel 3 is inappropriate for tv-tuning within your particular geographic region, then repeat the above process by substituting Channel 4. When you are done, you will rely almost exclusively upon the Insignia hand-held remote controller. You do not especially need to use your tv hand-held remote-controller again. However, be sure to avoid standing in front of your tv-set to change channels by buttons or knobs upon the tv-set itself. Tuning again upon the tv-set itself will negate your prior tv-setting for either Channel 3 or Channel 4 -- and thereby sabotage your working set-up! I myself incurred chronic anxiety yesterday (June 13), as I was stunned that the Insignia menu-screen did not appear immediately when I pushed "menu" on the Insignia hand-held. The only buttons that worked on the Insignia handheld remote-controller were the Power-on for the converter-box and the Power-on for the tv-set. (continued next page) Because my expectation had been this process would take just a few minutes, I was deeply frustrated and impatient. However, I recognized that my apprehension of impending loss was absolutely appropriate as emotional "signal-processing" for me personally -- in contrast to my formerly high expectation of immediate fulfillment, completion, and gratification. Instead of my intention for quick success, I faced the stunning dread that the Insignia box had become defective or that I'd fail to ever figure-out the problem. I would not have been so impatient if I hadn't expected immediate success for the set-up. I rejected the slogan that "I just want to get this over with!" I rejected the option of stomping upon the Insignia box! Amidst my hour-long anxiety, I summoned "Courage" -- a mode of patience to accompany my internal "quivering." I did a Google search. From this Fix-Ya web-site and other troubleshooting sites, I had strong clues that improperly setting Channel 3 or Channel 4 was a primary culprit for the failure of the Insignia's menu-screen to appear. When I finally succeeded, my anxiety dissipated quickly with a temporary relief. But then came the anger that the Insignia "User Guide" had not been clear to explain the process. From that aftermath of outrage, I decided to promptly compose this protocol to assist others who have been similarly tormented -- perhaps to the extent of incorrectly believing that the Insignia converter-box was a defective product requiring prompt replacement.
DTV converter box INSIGNIA
However, be sure to avoid standing in-front of your tv-set to change channels by buttons or knobs upon the tv-set itself. Tuning again upon the tv-set itself will negate your prior tv-setting for either Channel 3 or Channel 4 -- and thereby sabotage your working set-up!
From this FixYa web-site and other troubleshooting sites, I had strong clues that improperly setting Channel 3 or Channel 4 was a primary culprit for the failure of the Insignia's menu-screen to apprear. When I finally succeeded, my anxiety dissipated quickly with a temporary relief. But then came the anger that the Insignia "User Guide" had not been clear to explain the process. From that aftermath of outrage, I decided to promptly compose this protocol to assist others who have been similarly tormented -- perhaps to the extent of incorrectly believing that the Insignia converter-box was a defective product requiring prompt replacement.
6answers
Need information on a philips t.v. model 32PT6441/37
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Scenium DLP quit recognizing cable signal
You may have inadvertently pressed some buttons on the remote to take it out of the mode to receive cable channels.
If you unplug the tv from the wall for a while, it may clear the error.
Step 1: Identifying Your TV’s Location
1. If your country is highlighted, press OK on the remote control.
If your country isn’t highlighted, press the up or down arrow button on the
remote control to highlight your country and press OK.
2. Use the number buttons and/or the arrows on your remote to enter your
zip code or postal code. Press OK when you’re fi nished.
Note: If your postal code contains letters, press the up and down arrow
buttons on your remote to enter letters, and press the right arrow button
to go to the next space. The left arrow button also moves the highlight to
the left.
Step 2: Confi guring for Cable
The next series of screens asks you about your cable setup. To supply your TV
with the correct TV program listings, the TV Guide On Screen system needs to
know if your TV is connected to cable.
Note: If you’re using a cable box, always leave it on so you can receive
program information.
1. If your TV is connected to cable, highlight Yes and press OK.
If your TV isn’t connected to cable, highlight No and press OK. (STEP 3:
Confi guring for Antenna
appears–go to page 24).
2. If you have a cable box connected to this TV, highlight Yes and press OK.
Note: The next series of screens is very important because the TV Guide
On Screen system must fi nd the correct cable box information in order
to receive the correct TV program listings.
If you don’t have a cable box connected to this TV, highlight No and
press OK (STEP 3: Confi guring for Antenna appears–go to page 24).
3. Highlight the input where you connected your cable box to the TV, and
press OK.
If you select Cable Input, continue to step 4.
If you select any other option, go to step 5 on the next page.
Important Note: Your cable box can’t be connected to ANTENNA
INPUT if it is to be controlled by the TV Guide On Screen system.
try using the guidelines above.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
