Question about LG LRTP0931 Top Freezer Refrigerator
My fridge just isn't working, its not freezing or cooling. Everything else is just working fine i.e lights
My fridge is cooling but works nonstop.what is wrong?
Posted on Jul 21, 2009
    Champion:
  • 210 Answers
What lights are on in the display, it is most likely an error, possibly a thermal fuse. By the date posted, I imagine you already have solved this issue.
Sgt 48
Posted on Jun 12, 2008
  • 29 Answers
If the thermostat is set too low it may have ended up off, and still leave the lights working. Otherwise the compressor may be the issue. There is a starter relay on it's side, but when that goes the fridge usually cycles. It tryes to start, trips the thermal breaker, and after it cools off it repeats. If it is not off it may be time for a technician to check continuity in the thermostat, compressor, and wiring.
Posted on Jan 28, 2008
Frig freezer wont get cold enough after move . 35 degress then back up to 45 . cleaned everything good . coils everything . worked fine till moved . waited 24 hours after move to plugg in . help
Hi Kim, Before you check out the link below, Read about your refrigerator not cooling?Is your older or newer model refrigerator plugged in, getting power, the lights are on inside but the fridge will not cool and the freezer won't freeze? If your refrigerator or freezer has suddenly stopped cooling and the freezer won't freeze, we have multiple solutions for you.If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor is overheating or not getting proper power and will not start. The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
Refrigerator Is Not Cooling What To Check And How To Fix
Apr 03, 2016 | Refrigerators
I have a Whirlpool Refrigerator model # ET21PKXGW01 the freezer isn't freezing and the fridge isn't as cold as it should be (milk went bad). I did notice right before it stopped freezing/cooling I...
hey how r u today im no specialist but it sounds like a condensor fan if that fan goes your fridge will overheat not allowing proper freezing and or cooling. my family had the exact same problem and my dad was a appliance repair man so he knows about everything when it comes to this stuff..well hope i helped and congrats i hope u and your fiance go far. Jacob Winkler
Jul 16, 2012 | Refrigerators
Vent freezing up in fridge side
Isn't it fanned? The fan should blow cold air into the fridge. May be seized or iced up. Defrost, check and clean condenser, run to check.
May 03, 2012 | Refrigerators
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
Freezer side seems to work but the refrigerator side isn't
Sep 11, 2011 | Maytag Refrigerators
Maytag MDS2351- came home one day and noticed water coming from where u get the ice and water when i opened the freezer it was not cool and everything i had in there was defrosted and then when i went to...
Your fridge operates like that: a compressor liquefies freon vapours; this creates heat so the hot liquid goes thru a cooling radiator with a fan on it (these 2 elements are at the rear bottom of the fridge) the freon fluid goes to an evaporator, turns to vapour and absorbs heat in the process, cooling the evaporator; a fan blows air over the evaporator and spreads the cooled air all over the fridge; the vapours return to the compressor.
In the rear of the fridge you should make sure that the radiator is clean and the fan working; inside the fridge you should make sure that the evaporator is not covered in ice and/or dirt and its fan is working. If necessary clean both.
If they are clean , the fans work but the evaporator isn't cold then either the freon circuit has sprung a leak and all the fluid has been lost or the compressor isn't working - to find out which just put your hands on the compressor : if it's hot and vibrates the fluid has been lost, if it doesn't vibrates then the compressor isn't working.
The compressor isn't working because either the thermostat or itself have failed. To find out which the compressor will have to be powered directly from the mains: if it starts then the thermostat must be replaced, if it doesn't the compressor will.
To fix the freon circuit or to replace the compressor a certified professional is mandatory, you must call one.
Jul 12, 2011 | Refrigerators
Freezer appears to be working, but not the refrigerator section - at most that will only get to 50 degrees. Manually switching to propane makes no difference.
Sounds like your cooling fan is out. If the freezer is fine and the fridge isn't, then the cooling fan isn't blowing the cold air the the fridge. Or you could have ice obstructing the airflow.
Jul 01, 2011 | Refrigerators
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Oct 09, 2009 | Fisher Refrigerators
Open Questions:
See all LG LRTP0931 Top Freezer Refrigerator Questions
LG LRTP0931 Top Freezer Refrigerator Logo
352 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
