Question about Tomtom GO 300 GPS Receiver
TOMTOM GO 300 THe LCD screen won't light up.
My screen is extremely dim. I can barely see the image. I tried changing the brightness nothing happens. The image is the but unable to see without shining a light on it. Please help.
  • 158 Answers
Screens that don't light up are usually caused by the bulb going ( called " The Backlight " ). Unfortunatly , on a TomTom it is intergral with the screen so cannot be replaced seperatly. You can only replace the whole screen. There are other possiblities for the screen not lighting such as the ribbon cable that goes to the screen might not be quite plugged in right or theres a break in that ribbon cable + other reasons that become less likely as we go down the list. A simple test with a miltimeter by someone with knowledge of tomtoms will prove or disprove the backlight working and you should then know where you stand. Good luck.
Posted on Jan 29, 2008
SONY VAIO PCG-61611l has a very dim screen
Normally, this is in part due to you not replacing it with what should've been an LCD. The reason why it's dim is because those diodes are not getting the required voltage to emit as it should. LCD's work under a different concept where crystals use the light modulating properties of liquid crystals. Liquid crystals do not emit light directly as LED's, because it stand for light emitting diodes.
Mar 25, 2013 | Computers & Internet
Dim display on laptop LCD screen
The part you need is called a CCFL Backlight. Basically, there are lights in the screen that back-light/illuminate the display. Over time it burns out and you are left with a dim and completely dull display. These are a pain to replace and expensive when bought from the manufacturer. But this site has a break down with dis-assembly instructions...if you want to try it.
Mar 10, 2010 | HP OmniBook XE3 Notebook
I swiched off my laptop inspiron 1000 at the off switch. when I put it back on the back light did not work
how do you know it is the backlight? Usually people think that's it but it is the inverter.
f the backlight of your laptop stopped working and the image on the screen is so dim that you can barely see it under bright light, most likely you have a failed inverter board. There is a good chance to fix the problem if you replace the inverter board. If you replace the inverter board but the image is still dim, most likely there is a problem with the backlight lamp inside the LCD screen. If that's the case, try to replace the LCD screen. Note: it's much easier to disassemble the laptop display panel when the display panel is separated from the laptop.
I can definitely fix either way if you are out of warranty from dell.
Good luck! EJ Kudelka 516-860-2969
Feb 06, 2010 | Dell Inspiron 1000 Notebook
MY Laptop Screen Is Dim It Will Not Show Bright
When you say that your laptop "screen is dim", do you mean that there is no light coming from your screen, but you can see images on it? or do you mean that there is light coming from the screen, just a very little amount?
If you can images, but NO light is coming from the screen, then the LCD backlight is dead, and it needs to be replaced.
If there is light coming from the screen, but it's very dim, then you'll need to find the screen brightness adjustment keys on your laptop. This is usually two keys. The first one is normally in the lower left corner of your laptop and should be a different color - like blue or purple, and will be labeled something like "Fn". The second key is normally in the function key row (F1, F2, F3, etc...) and has a symbol on it that looks like a sun or burst of light with an arrow. There's usually one for "brightness UP" and one for "brightness DOWN". Hold down the Fn key, and then press the "Brightness UP" key a few times to see if the screen brightens up. Good luck.
Jan 14, 2010 | HP Pavilion dv1000 Notebook
Screen image fades
The "back-light" inside the LCD is failing.
It's about a $10 part, but it is not a "user-replaceable part".
Instead, take the computer to a qualifed technician, and get him/her to disassemble the computer, replace the part, and reassemble the computer.
Nov 17, 2009 | Panasonic Toughbook W4 Notebook
Outdoor photos are all over exposed and white. Video works fine.
set ur screen first .click one image 1st load on ur pc. see the screen and pc screen then set ur screen brightness and contrast of ur camera
Jun 17, 2009 | Mitsuba DV505 Digital Camera
Screen is very dim..can barely see it..bright adjust doesnt help.
Hi, your LCD screen's backlight has gone out. This is a hardware failure, and you'll need to have it replaced or repaired. THe LCD screen consists of two parts, the LCD screen which creates images for you to see, and the backlight which forces light through the LCD so you can see it. Your backlight has gone out, so your screen still has images, but no light.
May 17, 2009 | IBM ThinkPad T20 2647 Notebook
Tomtom 300
hello Simon,
Yes your'e right, the screen does have a bulb. Its reffered to as the ' backlight ' and from what you describe unfortunatly is sounds like yours has gone.
This light is somewhat integral to the screen so its more reasonable to change the whole screen rather than just the light.
There are other possible causes for the light not to be on as special circuits are employed to light up the screen. If these circuits are damaged in your device then its unlikely it will be economical to repair them.
I do hope this helps you or at least helps you to decide how to procede.
Good luck
Jul 22, 2008 | Tomtom GO 300 GPS Receiver
Dark scree
I too have the same problem with the same monitor.. tv looks great OSD looks great.. pc is dim.. This has nothing to do with the inverter board or the backlight.. I believe that there is an issue with the components that render the Computer video.
Jan 17, 2008 | Samsung SyncMaster 17" TFT LCD Monitor
Tomtom GO 300 GPS Receiver Logo
486 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
