Home | Toshiba | SD-V394 DVD Player / VCR Combo | Need a code for esa dvd...
Toshiba SD-V394 DVD Player / VCR Combo
Problem for Toshiba SD-V394 DVD Player / VCR Combo
Need a code for esa dvd player only please. (3digit)
By tigger71 on Jan 28, 2008
Trying to set up leap frog game for my toddler. cant locate 3 digit code that works
thanks
Same Problem
Jan 27, 2009
-   I have an ESA DVD and tried using a GE universal remote. First I used the remote's search code procedure to get DVD to turn off. Than there is a procedure with this GE universal remote to find the 3-digit code. I did that procedure and found 3-digit code. Unfortunately not all buttons on remote work properly but I can turn on/off, play, stop, pause. Enough to not have mutiple remotes.
Good Luck -   Guest
Solution #1
posted on Feb 14, 2008
Not Rated)
Mergatroid
Rank: Wiz
Rating: 84%, 202 votes
As this is not a Toshiba, I can't help you.
esa is not a popular brand name and it is unlikely you will ever find a code for it.
If you want to use a universal remote, you should buy well known brand names, not obscure ones.
Did you loose the remote for this unit? Just use the remote it came with.
Was this helpful?
Yes
No
Popular Solutions for Toshiba SD-V394 DVD Player /
Questions and Unsolved Problems for Toshiba SD-V394 DVD Player /
Do you recommend Toshiba SD-V394 DVD Player / VCR Combo?
Answer
Answer
looking for hack codes for Toshiba VHS DVD SQ PB official name SD v394sc Thanks, Sandra
Answer
my tv has a built in dvd player. The sliding disk holder got stuck and is sticking out and will not... (More)
Answer
One side of the disk drawer has come off it's track and is now stuck open
Answer
i bought my player from a church yard sale - where can i get a manual?
Answer
I am able to record audio on DVD but not image. What I am doing wrong?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba SD-V394 DVD Player /...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 1447
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
