Question about Panasonic TH-37PX60U 37 in. Plasma HDTV
Picture but no sound - touched something on remote and lost all sound
I am showing an icon on the upper right side of screen that displays a sound icon with an x through it. I am not able to get any sound out of the tv. It is something I pushed on the remote but I am not able to cancel . I have tried the mute button and that is not the problem
    Sergeant:
  • 300 Answers
Sounds like the speakers may have been turned off.
  1. Menu
  2. Audio
  3. Speakers
  4. Set to "On".
  5. Exit.
Posted on Mar 04, 2008
The back has gone out.
The back has gone out???? Do you mean the back button icon on the display? The one that looks like this: < ???
If that's it, try a Restart. You can do a Restart by touching the settings icon (right hand upper corner - three bars) and then
touch Settings. When the Settings screen comes up, touch the Settings icon in the upper RH corner again. A drop down menu will appear and Restart will be one of the options. Touch it and let it do its thing.. Be careful to touch Restart and not Reset which is right below it.
Apr 08, 2015 | Amazon Kindle Paperwhite special offers
How do I calibrate the touch screen on a Konica 7165?
To adjust the touchscreen sensitivity, perform the following:
1. Power the copier OFF.
2. Access the Key Operator Mode (Power the copier ON, while pressing the [HELP] key).
3. Touch [10. Control panel adjustment] on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching [10. Control panel adjustment], the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
4. Touch the + at the upper right corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Check the coordinates displayed in the top line at the top of the touchscreen.
5. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
6. If the values are not within the acceptable parameters, repeat Step 4 until the values are acceptable.
7. Touch the + at the lower left corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
8. As verification of a correct adjustment, touch the [CHECK] icon at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
9. Power the copier OFF/ON to exit the Key Operator Mode.
Nov 04, 2014 | Konica Minolta Office Equipment & Supplies
Change language on my sony dcr-sr300
if the cam is set to a language you don't know better take note of the icons on the screen. here's how you do it:
1.press or touch home button (looks like a house icon)
2.touch settings icon (looks like a toolbox icon, its at the bottom right corner of the lcd screen)
3.go to clock/language setting page (to go there look for the up and down button on the screen, it's on the right side of the lcd. in the middle you'll see reference to the page it will show 1/2 press down to make it 2/2)
4.touch the setting that has an icon of the letter A inside a square (that's in the setting upper right portion of the screen)
5.select and touch language set (it should have the language icon, A inside a square)
6.select desired language setting
... hope you'll find this understandable and useful. thanks:)
May 28, 2010 | Sony Video Cameras
Volume Icon has disappeared.
First, right click on the taskbar and select Properties from the right click menu.
Alternatively, you can go to the Control Panel and type the word 'taskbar' in the search box from the upper-right side. Once the search results are loaded, click on the link that says 'Customize icons on the taskbar'.
The Taskbar and Start Menu Properties window will show up on your screen. Here, go to the tab called Notification Area. In the System icons section check the Volume box and click on OK.
The Volume Mixer icon will now show up in the notification area of your taskbar
I hope that this information was helpful and thank you for contacting the experts.
Jan 18, 2010 | Toshiba Satellite A65-S1362 Notebook
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
Camcorder
I have a Aiptexk pocket DZO-V58, it will power on then 5 sec later it power off. Can anyone help!!
Thanks,
Susan B.
Jul 24, 2008 | Aiptek R-PKDV58 Flash Media Camcorder
No picture
is this something to do with the sleep timer?
Apr 03, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Menu icon does not work properly
Try this it may help. First, reset by pressing both VOLDW & SRC keys at the same time and boot up the system in Test Mode. Display the Touch Adjustment Screen with the SRC key of Car TV remote controller, press center section of the "Cross-font" using adjustment stick. (Upperleft - upper right - lower left) Note: When conducting the adjustment for the first time, the display position of the cross-cursor may be little off, but the adjustment should be conducted by using the center position of the font.
Sep 05, 2007 | Kenwood KVT-M700 Car DVD Player
Panasonic TH-37PX60U 37 in. Plasma HDTV Logo
117 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
