Question about Yamaha RX-V992
YAMAHA RX-V992 I have sound from the left front only. My system has lf rf rr lr c powered sub. Everything worked well until today. I assume a setting has changed, but I do not know what to check. Help please. Thanks, Leon
  • george8 Jul 02, 2008
    exactly the same
  • Gary
    Gary May 11, 2010
    Try swapping the wiring for the LF and RF at the receiver. See if the sound still only comes from the LF side. Also, there is a balance knob--try moving it and see if there's any change. Post your results. Thanks.
djnick989
  • 1067 Answers
SOURCE: Yamaha RX V992, HDMI 2 mode
tell toshiba dvd 720 p only and use bitstream outsetting in audio of dvd player ok if that dont do it run dvd directto tv then digita opti cable from tv back to sterio ok
Posted on Jan 21, 2008
robotek
  • 1512 Answers
SOURCE: Input selector on my Yamaha RX-V596 stuck
Hi Dush
Sounds like the processor has locked up in the unit. Try powering it right down from the wall socket for a day to reset, and then retry operation. If that does not work, leave it disconnected for about 10 days to erase backup memory completely and then try again. Good luck. Don't forget to give me a "FixYa" rating if this works. If it doesn't, get back to me in here and we can talk more about it.
regards
Graeme
Posted on Feb 16, 2008
SOURCE: crackling sound through speakers while watching dvd movie
Yamaha Rx-V361 Firmware Upgrade, A/V-Receiver/-Verstärker - HIFI-FORUM
Posted on Jun 18, 2008
SOURCE: Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Posted on Dec 05, 2008
easyq
  • 144 Answers
SOURCE: The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Posted on Apr 17, 2009
Door speaker wiring colors
1995 Dodge Ram 2500
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Feb 16, 2017 | 1995 Dodge Ram 2500
How do I hook up the 5 speakers on the system?
There should be some identification on the rear panel. The probable arrangement is: Left front (LF), right front (RF), left rear (LR), right rear (RR), and center channel/subwoofer.
Sep 05, 2015 | Audio Players & Recorders
Need the wiring diagram for the 2009 Toyota Corolla
standard radio--------------------
Battery LIGHT BLUE (+) RADIO HARNESS
Accesory GRAY (+) RADIO HARNESS
Ground BROWN (-) RADIO HARNESS
Illumination GREEN (+) RADIO HARNESS
Power Antenna TAN (+) RADIO HARNESS
LF Speaker (+) PINK
LF Speaker (-) VIOLET
RF Speaker (+) LIGHT GREEN
RF Speaker (-) BLUE
LR Speaker (+) BLACK
LR Speaker (-) YELLOW
RR Speaker (+) RED
RR Speaker (-) WHITE
Dec 12, 2010 | Car Audio & Video
I please need a kenwood kvt 516 wiring diagram to hook up my stereo i dont know what each color is. like left fron speaker etc. please help
battery yellow
accessory red
ground black
power antenna blue
amp turn blue/white
illumination orange
dimmer orange/white
RF + gray
RF - gray/black
LF + white
LF - white/black
RR + violet
RR - violet/black
LR + green
LR - green/black
Sep 27, 2010 | Kenwood Car Audio & Video
Need wiring diagram for 1998 jeep grand cherokee limited
Battery red/white
Accessory red/gray
Ground black
Illumination blue/red
Dimmer orange
Power antenna green/red
LF + green
LF - brown/red
LR + brown/yellow
LR - brown/light blue
RF + violet/yellow
RF - blue
RR + blue/white
RR - blue/orange
Sep 22, 2010 | Car Audio & Video
Radio Wire diagram for 1996 nissan pathfinder
Battery red/green
Accessory green/white
Ground use chassis ground
illumination red/blue
Dimmer pink/green
Power antenna red w/silver dots
LF speaker + green
LF - red
RF + brown
RF - black/white
LR + light green
LR - black/yellow
RR + orange
RR - black/pink
Sep 20, 2010 | Car Audio & Video
Hi I need the wiring diagram for the radio harness
Hello! Black=Ground...Blue=Antenna...Red=+12volts constant (memory)...Yellow=Switched +12volts...
Left front+White...LF- White/black...RF+Gray..RF- Gray/Black...LR+Green...LR-Green/Black...RR+Purple
RR-Purple/Black.............
Guru...........saailer
Feb 04, 2010 | Sony CDX-GT110 CD Player
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Speaker wire harness
FORD clearpixel.gif MEM
Green/Yellow
ACC
Yellow/Black
GND
Black
RF
White/Green
RF
Black/White
LF
Orange/Green
LF
Black/White
RR
Pink/Blue
RR
Green/Orange
LR
Pink Green
LR
Pink/Blue
Jun 02, 2009 | 2000 Ford Econoline
DEH-2750
heres the diagram .. but idk bout the rest since i havent used mine yet ..
yellow- Batt/mem. 12v
red- ignition/acc. 12v
blue- power antenna
black- ground
orange- positive dimmer
purple-RR +
w/b - RR -
green-LR +
w/b - LR-
grey-RF +
w/b - RF -
white- LF +
w/b - LF -
Aug 24, 2008 | Pioneer DEH-1600 CD Player
Yamaha RX-V992 Logo
194 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
