Question about Mitsubishi VS-60805 60" Rear Projection Television
PLEASE HELP!!!! my dad pushed the factory default reset button while looking threw the options with the remote control and now the tv has a bow in it and looks like all the colors are off and wondering if you could help me
  • buddah61 Jan 28, 2008
    do you know what will fix this problem Blown Convergence IC
  • Mitsubishi Master
  • 8,617 Answers
You are describing classic symptoms of a Blown Convergence IC and the resistors that power it.
Posted on Jan 28, 2008
  • Sonny Berry
    Sonny Berry Jan 28, 2008
    The two Convergence ICs will need to be replaced . The old ones will have to be removed and the replacments solderd in.
How to reset samsung led tv to factory settings?
Step 1 Press the "Menu" button on the Samsung LED TV or the remote control. Step 2
Press the up or down arrow buttons and highlight "Support." Press the "Enter" button to open the Support Menu.
Related Reading: How to Reset a Samsung DVD Recorder Step 3
Select "Self Diagnosis" and press the "Enter" button. Select the "Reset" option and press "Enter." Step 4
Enter your TV's security PIN. The default PIN is 0000; however, if you had previously changed it, enter the new PIN. Step 5
Select "Yes" to confirm your selection when the "All settings will return to factory defaults except network settings" dialog message appears on the screen. The TV powers off automatically and restores the default factory settings.
How to Reset Samsung LED TV to Factory Defaults
Nov 29, 2015 | Samsung Televison & Video
Can I do a Factory default reset on a Zenith Concierge Series H2530Y7 Model Television without the remote control?
ZENITH SC652 Concierge Commercial TV Remote Control buy a master remote then,
  • Press the "Power" button on the Installer's remote control to turn on the TV.
  • 2 Press and hold down the "Menu" button on the remote for about six seconds until the menu disappears.
  • 3 Press the "9," "8," "7," "6" and "CC" buttons in succession. This resets the TV to factory default settings
  • Read more : http://www.ehow.com/how_7393497_reset-zenith-concierge-television.html
    Apr 24, 2015 | Zenith Televison & Video
    Zenith factory reset
    Hi Rebecca,
    Specific reset instructions will vary depending on the model of your Zenith television. For many Zenith TVs you can reset to manufacturer defaults by pressing 'Menu' then press '9, 8, 7, 6, Enter.' If this doesn't work for your set, try a hard reset: unplug your television and leave it unplugged for at least 4 hours.
    You can also try this:
    Instructions
      • 1 Press the "Menu" button on your remote control. Use the up and down arrow buttons to highlight the video option. Press the arrow that points to the right to select the video option.
      • 2 Use the up and down arrow to highlight the video reset option. Push the right arrow button on the remote control to select video reset.
      • 3 Press the right arrow button on the remote control to return the video to original values.
    Read more: http://www.ehow.com/how_8528201_do-reset-zenith-tv.html#ixzz316gKG3ra
    May 08, 2014 | RCA 50in Tv M50 Wh 92s Dlp Hdtv Works But...
    CAN YOU TELL ME HOW TO GET THE CODE OR CODES OR HOW TO RESET TO FACTORY DEFAULT FOR THIS TV
    To do a factory reset, you must have its original remote control. A universal remote won't go. If you have its original remote control, and want to know more, check the site linked here. http://electronicshelponline.blogspot.com/ You have to enter its service mode option to make it a system reset. Never attempt to do it, if you are not sound in electronics. Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option.
    Aug 07, 2013 | Televison & Video
    Cannot get AV Mode
    There is a TV/VIDEO button on frond panel of the tv. When you press each time this button then you will able to access different video inputs. if the button is inactive the probably the micro switch for TV/VIDEO button may be faulty. also check the same with the remote. If its doesn't help then try to reset the tv to factory default setting. For that you need the remote. Keep in mind that when you reset the tv to factory default setting all the memorized parameters will erased(like channel memory, personal preference setting etc ). For reseting the tv to factory default do the following
    1.Turn on the TV.
    2.While holding down the RESET button on the
    remote control, press the POWER button on the TV front panel.
    The TV will turn itself off, then back on again. Release the
    RESET button
    Ajin
    Jan 23, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
    Trying to reset the settings for my toshiba model27a45
    Hello
    It is easy to reset your Toshiba set to factory defaults. Enter each options, ie, picutre, sound etc, and press "Reset" button on your remote control to reset each options to factory settings. The default factory settings for Video is DVD. Ok.
    Jan 07, 2011 | Toshiba 27A45 27" TV
    How to reset sharp aquos lc-32l400m?thanx before
    Sharp Aquos LC-32L450M - i have recently baught this LCD, but I think the 'mpx' ie the multiplex sound is not working. there is this 'mpx' button on the remote, but wen i press it nothing really happens. in the manual its only written in one line "mpx- multiplex sound" . please any one can help me ..I m really not happy wit the sound right now. paid so much & no good sound its bit irritating please any one help.. wats the problem
    Jan 06, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
    How do i find the factory reset?
    This model has what is called the "option" menu which is a hard reset of the set. It returns the set to the condition it was when new in the box---on air band on channel 3.
    What is reason you want to do the reset? I can tell you how if a good reason.
    If this helped you rate this solution as very helpful as I do this here for free and respond with a comment here.
    SD TECH
    Sep 03, 2010 | Mitsubishi WS-55311 55" Rear Projection...
    AWIA VXG140 TV/VIDEO
    http://elektrotanya.com/aiwa_tv-a1419.djvu/download.html
    http://elektrotanya.com/aiwa_vx-g142_service_menu.pdf/download.html
    http://elektrotanya.com/aiwa_tv_vcr_vxg_143.pdf/download.html
    OK in these manuals above you should find, all the information, to reset any codes, the child lock, is most likely on, you need to disable it.
    With the TV turned on, simultaneously press VOLUME down button on the front of the TV set and the number 7 button on the remote control to reset pin code and customer ID.
    If that above doesn't work, try below.
    CHILDLOCK Press ANY NUMB 3 TIMES, THEN PRESS VOL- ON SET & "7" ON R/C FOR 5 SECS this should disable it.
    Jun 01, 2010 | Aiwa Televison & Video
    Restricted channels cannot figure out how to reset to factory settings
    Pressing the menu button should bring up options to adjust the color ,tint,etc. look for antennae options or parental control options to lift the restricted channels. hope this helps.
    Bobalix
    Apr 18, 2009 | Televison & Video
    Mitsubishi VS-60805 60" Rear Projection Television Logo
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
