Question about Kenmore 53542 / 53544 Side by Side Refrigerator
Water dispenses without pushing lever
I need to keep the water turned off from the faucet because the water dispenses without pushing in lever. The lever is not stuck in the in position. When I push the lever, it does not seem to have a problem going back and forth. I hear a click and the light turns on.
Some additional information about refrigerator: I kept the temperature to cold and the reseviour in the refrigerator was frozen for a coule of months. I thought the water dispenser had a problem. I adjusted the temperature until the water thawed in the dispenser but then it dispensed out of the door without pushing in lever.
  • allstarpizza Jan 28, 2008
    Thank you for the suggestion. Do you know where I can view a diagram to take solinoid valve apart and clean?
  • Captain48 Apr 28, 2008
    water coming out of dispenser w/o being pushed had to turn water supply off. Kenmore model 106.57282790
    Scholar:
  • 90 Answers
There is a solinoid valve that opens when you push the switch in. It has apparently failed and is leaking. Sometimes taking it apart and cleaning it will fix the problem.
Posted on Jan 28, 2008
  • Timothy Smith Jan 29, 2008
    Most solinoid valves are held together by 4 screws. Take the coil off which is the large round outer piece with the two flat electrical connectors. Once this is off you will see a silver tube that looks like a mushroom held in place by 4 screws. Pay attention on how the spring and plunger are oriented. The plunger has a point on it that needs to be clean. Under this is a rubber seal with a small hole in the middle and 4 small holes in the outer fold. Make sure that it is all clean. Most appliance repair suppliers have a replacement kit for these which is inexpensive. To find it you will need to track it down. Find where the water line feed to. One will go to the ice maker, the other is for the indoor water. Both are probably underneath the fridge.
Samsung Model RF28K9070SR/AA water dispenser not working, water line & filter OK
while pushing button see if voltage to water solenoid if ok bad solenoid if no voltage check switch
Jun 11, 2018 | Samsung Refrigerators
Why is the water running directly into the ice dispenser and running out of the door when we are not pushing the lever to get water?
Sounds like the water valve is stuck or the wiring or switch is defective. As both ice and water are a problem it sounds more like a defective water valve.
Oct 05, 2014 | Whirlpool Refrigerators
Samsung rf4287hars dispenser not dispensing ice
SAMSUNG RF4282/HARS has a total backwards-double negative on the menu screen ( at least to me ) tho granted, the ice maker is perhaps, lets say, one of the slower cube makers I have ever seen... it has a setting that is .... "Ice Making OFF".... with the option ON/OFF.... make sure that setting is set to OFF if u want ice, or non Orange on the ON screen, or no ice will be made... It could have been worded much better... ie: "Turn Ice Making Off" with option yes or no... but no... My mind says...Make Ice, have options yes or no = just that....if I select YES ... ice making should be on.... not with Samsung... Kinda should go with the other setup settings that Samsung has..... simple yes/no
Words are.... ( selection )
"Ice Making OFF" setting should be set to OFF... just to do that... you are turning the shut down mode OFF and u will be making ice ( you are turning the shut down ice making function OFF in common terms)
As expensive as this machine is.... It should be easier and programing should restore after a power flux.... anyone wanting a lot of ice... forget this machine... we continue to purchase bagged ice and keep it in the freezer in the garage, it can\'t keep up on a daily basis.... I continually have to re-enter my WIFI passcode at every power outage... ( sometimes a lot in summer with storms )
My wife wanted it.... steel look.... she now finds she hates keeping it clean... NEVER AGAIN.... Samsung has some great products, but we have to suck up on this one... never again
Feb 27, 2013 | Samsung RF4287HARS French Door...
My kitchen faucet is a single handle Moen and is approximately 20 years old. Lately it has been acting up which I have been ignoring in the hope it would heal itself. It has been difficulet to turn the...
It may just be that you need a new cartridge. If you can replace cartridge without to much problem I would do that. Depending on your water quality the cartridge may be very hard to remove on a faucet that old. Also if the handle actuating hole is worn very much you may have to replace it also. By the time you buy parts you may have half or more of the price of new faucet, I would recommend that you replace faucet. Hope this helps. Thanks
Nov 17, 2010 | Moen Plumbing
Water continually drips from the freezer door water dispenser. it will stop if I shut off the water supply.Refrigerator is a 12 yr. old GE side by side
The lever you push for water does nothing mechanically to open any water valve. All it does is activate a solenoid coil on the water valve. The water valve itself is dripping like a faucet and needs to be replaced. To replace the valve shut off the water supply and disconnect the water line from the valve. Install the new one. Nothing to it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 29, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Kohler single lever pull-out faucet stopped working. Raising up does not start water flow. Turning left sometimes starts some hot water, but raisinglever up and down does not start or stop water flow as...
Fix a kohler faucet
most likely the gasket broke inside the lever, you have to replace it.
shut the water off from the angle stop (valve under the sink) both hot and cold.
use an allen wrench ("L" wrench) to remove the tiny screw around the lever, >>>>before you do that place a rag covering the drain for if you drop it<<<< after that pull the lever out, that will show the inside of the faucet. use an adjustable wrench to remove the actuator from the base. when you get that part out you should be able to see the damage to the gasket. At that point you need a phillips screwdriver to get the gasket out and back in >>>>take the damaged gasket to the hardware store<<<< and get a replacement you may have to change more than one. after you get all the gaskets in place, reinsert the actuator and don't forget to tight it up with the adjustable wrench. center it so it would dispense the same amount of hot and cold water, replace the lever reinsert the tiny screw with the "L" wrench. turn on water from angle valves and test faucet.
that should do it and save you about 300 bucks
if it works for you don't forget to rate me
Apr 28, 2010 | Kohler Model 10433: Fort® Single-control...
The water dispenser does not work properly. The light does not come off of the cubed ice button. To get water, I push the water button and without pushing the lever, water starts coming out. To stop it, I...
You have a bad main control board . The new pt # WR55X10656 . The dispensor board is not communicating with the control board . However , check this site to see if it can be replaced under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
Nov 15, 2009 | GE GSH25JFR Side by Side Refrigerator
Faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
May 06, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Water dispenser keeps dispensing water when not pressed
If you can pull on the lever to make water flow stop, chances are there is a mineral buildup inside the valve, or the seat in the valve has failed. Either way, the valve normally needs to be replaced as they are not usually serviceable. Leave the Model number of the refrigerator so that I can check what to replace.
Dec 28, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
215 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
