Question about Nikon N50 35mm SLR Camera
Error message Hi, I am getting an ERR message after I take a picture. In addition, at times the flash symbol apprears on my LCD screen, even though the flash is on. The lens seems to focus ok, and makes no unusual sounds. I have tried without success to figure out the problem myself. Thank you Irma
  • Anonymous Apr 20, 2008
    I am having the same error message when I load the film it advances but it will not snap the picture. I dont know anything about the camera. It was given to me and without the guide book.
    Sergeant:
  • 201 Answers
Hey there deliafuentes, I would suggest you check your film to ensure it is seated correctly and fed across to the orange line inside the winding post on the right side of the open back of the camera. If this is not the problem, I would check the settings to ensure you are not in a protection mode which will prevent you from snapping a picture which is not properly focused or without the necessary light required. Try turning off the auto features to test the possibility. Another option is the batteries may have insuffient power to drive the features which you are using. Switch to a new set, preferrably not rechargeable or generic. Good Luck!
Posted on Jan 28, 2008
  • Devocap
    Devocap Jan 31, 2008
    Hey there deliafuentes, I think this may help. What type of lens are you using? With the nikon f50, when you use a non-G lenses, the aperture ring on the base of the lens needs to be placed at the smallest aperture setting, usually f/22, f16, or f32. If it is off that setting, you will get an error message. Once you set it, you may also find a lock for it, keeping it in place. Good Luck!
  • Samantha Oct 09, 2011
    I'm getting something like that too on my Nikon N50. Along with the flash symbol on the LCD and the Err on the outside screen, the screen in the viewfinder goes dark. I just got it a new battery and it says that it's taking pictures. I don't want to open up the film to look at it because that would expose all of my pictures I took.
I have problem with my canon copier image ready 5020. error E000004-0000 how do I fix it i'd tried to press 2&8 but its said "Download Mode"
Error E000004 is a fuser related code and is most parts just caused by a paper jam in the fuser area. Before you begin to try and clear the internal flag you must make sure there is no paper or no obstruction stuck in the fuser area. With the power off rotate the fuser model handel to see if any aper or obstruction exsists. Clear it carefully if there is. At any time NEVER USE a knife or sharp object to clear a jam. Common sense I know, but few practice it. Once you clear the paper jam you can see if clearing the flag is the magic you need. If the next stages fail contract a local Canon trained tech to troubleshoot the real source of the error. Clear the error flag do the following steps DO NOT touch any thing else DON'T adjust any numbers. Turn machine on. When main screen apprears press Additional Functions button (*) let go. Press 2 and 8 together let go. Press Additional Funtions button (*) again. Screen should say Service Mode Level 1. Press these screen buttons in the following order. Copier, Functions, Clear, ERR then press OK in lower right corner. Machine will apprear as if nothing has happened but it has. Shut machine off at side. Turn on. Flag is cleared. If code reappears get professional help. This is a fuser code therefore we don't want a fire or anything else happening. Doing this clear you have 30 seconds before macine shuts off. It takes timing. Good Luck.
Jun 28, 2011 | Canon imageRUNNER 5020 Copier
Get Err CF in view finder and cannot take pictures
did you try removing the memory card and making sure its not locked?
Mar 18, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
Jan 17, 2010 | Nikon D80 Digital Camera
Getting error E9101 with my w55
The error shows that(Abnormality when flash is being
charged.) the problem in in FLASH UNIT, it needs replacement, the part number is given below according to the model number you mention DSC-W55 Part No. 1-479-663-31 Description (FLASH UNIT).
Thanks for using ifxya.
Jul 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
I have a canon 4080i error code e000004-0401 comes up and have to shut down when retart get the same message.
you have a fuser related error code, either thermisters or thermo fuse.
to reset error code you need to go in to a service mode and reset it.try this hit the additional fuction button then hit 2 and 8 keys together and additional function button again that will put you into service mode BE very careful in there though.
under function/clear/err code highlight err code then ok reset machine see what happens if error code comes back then you need to get a tech to have a look at ya fuser
Canon Tech
Apr 09, 2009 | Canon Office Equipment & Supplies
Won't take picture though I replaced battery.
Even though it was cushioned somewhat the camera took enough damage to jam something. The flashing symbols are a generic error code it could mean the shutter, zoom, film transport, flash, or some combination of these system are not working (sorry but without tearing the camera apart I can't narrow the problem any further)
Nov 05, 2008 | Minolta Freedom Action Zoom 90 35mm Point...
Err message on my S2 Pro
Try removing the lens, the memory card, and the lithium batteries. With freshly charged AA batteries, turn the camera on. If it comes on without the "err" message in that case, your problem lies with the memory card, the lens, or the lithium batteries. Turn off the camera and add these things until you encounter the problem again.
For a lens, check to make sure the electronic contacts are clean and that the lens gets fully twisted into place, and that if there is an aperture lock, that the aperture is set to the smallest possible aperture (22 or 16, usually).
For the memory card, reformat it elsewhere if it is causing problems. The Fuji S2 is notorious for being picky about memory cards.
Lithium batteries that are slightly run-down can cause all sorts of issues. Your S2 doesn't need to use lithium batteries, except for the built-in flash. You can add an extra AA battery pack to replace the lithium batteries, and that will improve the camera's reliability.
Jun 13, 2008 | Fuji FinePix S2 Pro Digital Camera
Flash not working...
I have a DSC-W80 CyberShot I had a problem with the error code on the LCD Screen that said E:91:01. I played with the camera for a little bit and found the if you push the home button and go to settings. When you get to the settings go to main settings, When you get there go to initalize and follow the instructions. MAKE SURE YOU SAVE YOUR PICTURES OR TAKE THE MEMORY CARD OUT OR YOU WILL LOSE ALL THE PICTURES. I hope this will help you.
Jan 21, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
Please help...I can't take any pictures!
Possibility one : lens unit faulty and proper focus is not being achieved camera goes into error mode because of this and then it switches off to prevent further damage.( replace /repair lens unit ) Possibility two: shutter faulty . Lens delivers proper focus but when you try to take picture goes into error mode because shutter not coming on line or malfanctions. ( replace shutter only ).
Apr 17, 2007 | Konica Minolta DiMAGE S414 Digital Camera
Nikon N50 35mm SLR Camera Logo
138 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
