Question about Canon Sure Shot 80U 35mm Point and Shoot Camera
Camera blinks H replaced battery and new film it'll take one pik and then shut down
Canon sure shot 80U 35mm
Poor product when it happens to so many cameras. cp
Posted on Jul 12, 2008
Camera does not rewind after end of film it spins, but does not engage the film. Joe M.
it is likely that this model of camera spins the entire roll onto the take-up spool, and then slowly rewinds one frame at a time until the last picture is taken. Then it has already almost rewound,
This shows up when you load the film. The cameras digital counter counts up to the number of pictures available, and counts downward each picture taken.
Sep 08, 2010 | Canon Sure Shot 80U 35mm Point and Shoot...
I have a Canon Sure Shot 115u II Date 35mm Film Camera. No manual. How do I fix the blinking icons on the LED screen? There are a series of dashes along the top of the screen. They look like a place...
remove the battary and the film,the clean the contcts of the bat and bat comparment, and put the battary then operate camera without film.finding it normally operating for 10-20 clicks,put the film and try
Mar 04, 2010 | Canon Sure Shot 115u II Date 35mm Film...
Film advance
throw it away, its already old, buy new ones a pentax g40, its a computer compatible.
Feb 28, 2008 | Canon Sure Shot 80U 35mm Point and Shoot...
CANNON SURE SHOT 80U
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Jan 22, 2008 | Canon Sure Shot 80U 35mm Point and Shoot...
Instructions
There are two conditions under which a blinking "H" will appear in the
LCD panel: (1) when the film has been loaded incorrectly or (2) when the
camera's self-test process detects an internal malfunction. If a
blinking "H" indication appears, perform the following operations in
attempt to resolve the situation:
1. Rewind and remove the film using the rewind button, then remove the
battery to clear the memory.
2. Clean the contacts at the base of the battery compartment with a
clean pencil eraser to ensure proper contact between the camera and
battery.
3. Replace the battery, power the camera back up1.gif and operate it as if
it had film loaded, pressing the shutter release.
Jan 11, 2008 | Canon Sure Shot 105 Zoom Date 35mm Point...
Battery
If this camera is a Canon Rebel K2 the problem may be that it might need a new main drive motor. I have replaced two drive motors in the last couple of days in these cameras. When the motor starts to go bad the film transport may stop in mid cycle and the battery check indicator starts to blink. The battery draw becomes excessive and the camera shuts down. Of course, there may be other problems but this a common one. Hope this helps.
Sep 25, 2007 | Canon EOS Rebel K2 35mm SLR Camera
How do you set the time on the Canon sure shot 80u
Sep 10, 2007 | Canon Sure Shot 80U 35mm Point and Shoot...
Camera is flashing "H"
I've done some research and found out that the flashing H is Electronic failure and needs repair.
Oct 03, 2006 | Canon Sure Shot 80U 35mm Point and Shoot...
Canon Sure Shot 80U 35mm Point and Shoot Camera Logo
259 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
