Question about Epson Stylus Photo R800 InkJet Printer
Prints come out with faint horizontal "stripes"
Recently, I bought new cartridges to replace ones that were out.  I use standard Epson cartridges.  Problem now is, when I print out my color copies of images, there are what I call faint, regularly spaced horizontal "stripes" about 1/8" thick (4 cm) going across the images, any image.  Any idea why?
I checked the ink to see if any cartridges are out, and the printer indicates that they are ok.
Thanks!
Elizabeth
  • 1 more comment
  • ElizabethT Jan 30, 2008
    I looked up about the Nozzle Auto Check in the printer manual. For Mac OS X it says:
    Open Appl. folder, select Epson Printer Utility, select SP R800, click OK,, then select Auto Nozzle Check and Cleaning.
    First, I couldn't find anything under Appln. folder for Epson., and couldn't find it using Finder, Find file. The only way I got a menu for it was to print something on the Epson. Under that menu there is nothing like it says in the manual instructions. I know it has been done before by someone who helped me some time ago.
    Any suggestions?
    Thanks.
    Thank you CoolGuy, I followed your instructions and located the Nozzle Check. I'll try this out and see if that works. Makes sense, at any rate!
    Elizabeth
  • ElizabethT Jan 31, 2008
    I'm still in the process of running the print utility tests on the printer, especially the two on print-head cleaning. Seems that print head(s) are clogged. I ran the print-head alignment test, but I don't think this is the problem. At any rate, keeps telling me I need more ink. Yikes. Expensive! I keep putting more cartridges in (according to the ink-out indicator) and then then the red light goes off. Then I repeat the print head test, tells me I need more ink. I now am unable to find cartridges in the local stores I used to buy from so I have to wait til I get some shipped from an online seller. The tests are showing breaks in the color test patterns on two of the test utilities and I've run these maybe up to five times or so now. I've turned the printer off for now. I'll keep you posted!
    Genius:
  • 3,422 Answers
here is the user guide,go through it carefully and im further looking for a solution to your problem..
click here and entr ur email id n thn click start download,,
Goodluck,
Dont forget to rate me as fixya..
Posted on Jan 30, 2008
  • 1 more comment
  • Priya darshan Jan 30, 2008
    If your prints are too light or contain white spots or horizontal lines thn:
    the signs point to a clogged print head—especially if you haven’t
    used your printer for some time. Clean the head by running the
    printer’s utility program. If you can’t find it, try accessing it from
    Printer Setup Utility (/Applications/Utilities). Select your printer
    from the list, and choose Configure Printer from the Printers menu. You may need to clean the head several times for best
    results. Be sure to print a test sheet between cleanings to avoid
    damaging the nozzles.
    If the cleaning routine doesn’t work, try
    leaving your printer turned off overnight. The next day, run the
    cleaning process again. The dried ink will soften, making it easier for
    the printer to clean.
    If you have a chronic problem with clogged
    heads, make a habit of turning your printer off at night. (Turn it off
    at the printer, not at the power strip.) In some models, doing so will
    engage a capping mechanism that protects the nozzles.
    Most
    printer utilities will let you print a test sheet that uses all the
    printer’s ink cartridges. If you haven’t printed a color image in a
    while, print a test sheet before printing a large file—it wastes less
    ink than a bad print.
    Vertical lines are jagged.
    This is usually a sign that the print head is out of alignment. There’s
    not much you can do to avoid this problem—all print heads become
    misaligned over time. Your printer utility should include an option for
    correcting the problem.
    Alright i found out the sol. to ur problem visit the link below it will explain u everything step by step.
    Click here
  • Priya darshan Jan 31, 2008
    OK Elizabeth...
    Hope ur printer soon gets in good condition..
    Please don't forget to rate me as fixya..
    Genius:
  • 1,067 Answers
Run the nozzel cleaner and other test its in its software menu ok download latest driver from website also
  • nick helpap
    nick helpap Jan 30, 2008
    thats hwat i said to do 1st so rate me as fix ya nozzel cheak ok
  • nick helpap
    Elizabeth ya i told u 1st that was soultion ok nozzel cheak ect software so rate me please
The color is not printing correctly. Things are coming out mostly pink or yellow. I tried the MAINTENANCE tab. The nozzle check showed that the top section (PGBK) looked good. The second section (C)...
The printhead has either become too clogged to flush out with with the internal cleaning operation (which uses a LOT of ink), OR, the nozzles are not firing. If after several cleaning operations there is still no significant improvement, you will need to replace the print head. I see this frequently with Canon and Epson, and Brother inkjet printers. Usually, it is due to leaving the printer idle for too long, or removing a cartridge and not replacing it right away. The air gets to the residual puddle of ink in the head and dries it.
You can find the replacement print head by Google searching "MP830 print head". Prices can vary from around $70 - $90. Changing it out is fairly simple. You only need to lift a lever that holds the head in place. Make certain that it is squarely seated, and then run a few pages of a color document, or do a couple of standard cleaning operations to "prime" the head.
Make sure the hed is NEW and not used or "refurbished". Here is one source on eBay that sells it for $78.00:
http://compare.ebay.com/like/330643273134?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y
Nov 27, 2011 | Canon MP830 All-In-One Printer
Black ink not printing even tho a new black ink cartridge was installed recently and working properly until I opened the unit to install a new color cartridge and now the black ink is not printing and the...
Try to reseat your cartridges. Unplug and replug your printer into the power source to reset itself. If that doesn't help, try to clean your cartridges and check if print quality improves. If you're using Windows, go to Start -> Programs -> Lexmark X74-X75 -> Lexmark X74-X75 Solution Center -> Maintenance -> Clean print nozzles to fix horizontal streaks.
Feb 17, 2011 | Lexmark X75 All-In-One InkJet Printer
I have recently acquired this printer but don't have the manual. The problem I am having is that sometimes the documents print perfectly, next time I try printing it comes out completely faint and blurred....
You need to clean the print head nozzle and perform alignment exercise. There are instructions in the service manual. Please follow the steps to clean the nozzle and alignment. You may download the manual from here. http://www.nodevice.com/manual/newmans/Epson_Stylus_Photo_810_-_820_Service_Manualpdf/get20551.html
IF you have doubts then please revert back. We will help you out.
Jan 04, 2011 | Epson Stylus Photo 810 InkJet Printer
Bought new ink, black not working
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 06, 2010 | Epson Stylus NX300 All-In-One InkJet...
EPSON Stylus SX600FW printer. Recently changed
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Jan 29, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Hi I have bought new in black cartridge and nothing .what should i do ??? Have MFC -790 cw all rest collor printing good only have problem with black one .
Did you use Brother Genuine Cartridges?????
If you are using Generic, replace them with Genuine Brother Ink Cartridges.
Good Luck
Jan 29, 2010 | Brother Multi-Function Center MFC-240C...
Printing Streaky
Most likely the printer has been sitting for along time not used or you have used cheap replacement ink. Epsons are notorious for clogging the jets with cheap ink. unfortunately replacing the ink cartridges will not help because the jets are seperate from them. If cleaning numerous times does not work your next best bet is to buy a cleaning ink cartridge for your model. otherwise youll need a new printhead or new printer. If your going to use cheap replacement cartridges stay away from epson.
Jun 16, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson C1100 - Vertical faint stripes on colour photos
see if this solution fixes the problem.
Also clean the print head using instructions in the manual
http://www.fixya.com/support/t241840-smudges_color_printing_black_ok
Mar 04, 2008 | Epson Aculaser C1100 Printer
Epson Stylus Photo R800 InkJet Printer Logo
287 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
