Question about Hitachi 50HDX60 50 in. Plasma Television
Satelitte to Cable-TV wont work
I recently moved from satellite to Cable and my TV won't work it shows "no signal." I changed the input from satellite to cable in input 1 and still wont work. Any suggestions?
  • 29 Answers
Check your satellite output. Maybe you change the option in the out.
Posted on Jun 16, 2008
I touched the wrong button on the remote and know tv says no signal and I can't get it back
Try going to your input button on your remote and see if you are still on the right input like if your tv is using a hdmi cable from your cable or satellite box then your input should be hdmi or hdmi 1 or hdmi 2 etc... also if you have cable or satellite make sure you didn't change the actual tv off of channel 3 or 4 whichever you have your cable or satellite box set on. I hope this helps.
Feb 06, 2016 | Televison & Video
Sharp tv was set up with satelitte- now no signal with freeview box - do i have to reset tv?
Have you changed the input setting on the TV to match up with the input port you have plugged the freeview box into on the back of your TV?
Mar 02, 2015 | Sharp Televison & Video
I have dish network and have my satellite receiver connected to TV via HDMI port 1 and have no signal flashing across screen while on. I can change volume and use all buttons on TV and remote except...
Based on what you're saying it can only be a few things.
Trying putting the HDMI cable into a different port on the tv and change input.
Try changing the HDMI cable.
If that doesn't work, change over to component cables, change TV input again and see if that works.
Nov 03, 2013 | Proscan Televison & Video
Sharp tv won't display cable picture (it only shows fuzz) but the netflix and DVD both work. The cable says no input service available. I am able to change the channel on the cable box, but on the tv
Your cable box might not be sending signal out to the tv. Would have to call service provider to have them test your box. Or, you can try unplugging your cable box, and then plugging it back in. Make sure all connections are secure and settings on your tv are accurate. 11_13_2013_3_31_52_pm.png
Aug 11, 2013 | Televison & Video
My dish 322 receiver wont work 2 tv,to get service
  • There are two satellite inputs on the back of a 322. There may be a single cable going to a splitter connected to these two ports or two individual cables.
  • If there are two cables swap them, if you still get signal on the same input only then the receivers input is dead.Otherwise follow the bad cable and ensure it is not damaged or disconnected. Swap the location on the other end and see if the issue stays on the same cable. If so replace the cable, if not replace the LNB or Switch.
  • If there is a splitter bypass it and connect the single cable directly to the input that does not work. If there is no signal the port is bad, replace the receiver. If there is signal then reconnect the splitter, press menu 6-1-1, check switch, and then test. Allow the test to finish. If the two inputs do not match replace the splitter... Its called a DP Seperator
Jan 24, 2010 | DISH Network 322 DTV Receiver
I have recently switched to a Dual receiver from Dish network...I have a coax connection to my Sony but cannot find the way to change the input to find the signal from the coax cable. The TV will not take...
We would be happy to help get that fixed right away. Thefirst thing we want to ensure is that all connected equipment is on. Since we know you are using a coax cable to connect the receiver toTV1, check the receiver's back panel for the output name. If your receiver hasa "TV CH 3/4 out":Tune TV to channel 3 or channel 4, if it is labeled "Home Distribution": TuneTV to channel 62 or 75. We also want to ensure that the TV and thereceiver are connected properly, please visit this link to for moreinformation: http://www.dishnetwork.com/SupportSection/setup-receiver-totv.Once we have made sure everything is connected properly, unplug receiver for 10seconds then plug it back in, this will reset the receiver. If we are still notgetting a picture connect another component (VCR, DVD Player, etc.) to the sameTV, using same cable, same input, and same channel to see if it works. If youget a picture with the other component give us a call at 1-800-333-DISH (3474)for some additional troubleshooting. If it doesn't work with the othercomponent then replace the cable that was used.
We hope these steps resolve the issue. We want to thank you for being a valuedDISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Jan 18, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
How to hookup vcr to TV to tape from satelitte
have a look at ur install bock it will tell u how to do it...connect antenna to ur vcr then use cable from ur vcr output to ur tv antenna ,,,,,after u have done this read instruction .....to connect ur dvd ....just plug ur cables from ur dvd to the back or ur tv....marked as dvd input....
cheers and good luck......very simple.....
Mar 06, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
Multiple video inputs
Unfortunately, you cannot use the connectors at the same time. The S-Video connector overrides the standard video connector. This is why they share common audio left/right inputs. If you could use them separately, they would each have their own set of audio inputs. (S-Video does not carry audio signals on the cable.) I'm assuming that you are connecting your Satellite as an input to your VCR, and then your VCR to the TV via a video connection. The VCR passes the satellite signal through unless you are watching a tape, then it overrides the dish signal. You have a few choices here: 1. You can connect the coaxial (RF) output from the VCR to the TV, and watch the satellite and VCR on channel 3 (or 4). You can then connect the DVD via S-Video, and watch it on "video". This is the simplest solution, and provides the best picture quality for the DVD (with this TV), but lower quality for the dish and VCR. 2. You can connect the DVD player via RF (if it supports that), watch the DVD on channel 3, and connect the VCR via video. This will make the DVD picture quality terrible. 3. You can replace the VCR with a combo DVD/VCR unit. You can then connect the S-Video out from the combo unit to the TV. This is a more expensive solution. 4. You can replace the TV with a model that includes more inputs. This is the most expensive solution, but will allow you to watch your DVD over component cables (very high quality) and VCR and dish over S-Video. Ironically, the obvious choice, connecting the DVD as an input to the VCR (as a pass-through) simply WON'T WORK. The signal put out by the DVD player is "copy protected" (using a system called MacroVision) which the VCR will refuse to play, even as a pass-though. Best of luck with this. Given that you are trying to make this all work without replacing equipment, I recommend option #1, until you decide to break down and buy a shiny new HDTV. They are coming down in price every week, but only you can decide when the time is right.
Mar 22, 2007 | Sony KV-32S26 32" TV
Hitachi 50HDX60 50 in. Plasma Television Logo
59 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
