Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
Red gun suddenly went wacko
Watching tv then all of a sudden noticed a red reflection. then realized the reflection was the red gun broadcast but warped. gun appears solid like it has not moved. when i checked the convergence, the lines looked like they were warped by a big magnet.
any suggestions on what i might do? thanks
  • 4 more comments
  • knuz Jan 28, 2008
    T
    love fixing stuff and am fairly handy w/ most everything except electronics. however, after looking into the guts of this tv, i don't think i would have a clue as to where the ic is, let alone removing and replacing.
    any way you could give me a little more guidance?
    thanks
  • knuz Jan 29, 2008
    that i can do.
    thank you, t
  • knuz Jan 30, 2008
    t, pulled out the board and tried to remove the two ic's but could not seperate from the heat-sink so back to plan b. looked up bp95-00142e at partstore.com and pictured item was not my board.
    aa41-00340c is the # printed on mine but was not able to find anything. another website had a bunch of folks with the same problem with their pth5498. one guy tried replacing the ic's but no luck. he finally bought board #aa9501846d from partstore and, behold, problem solved. that board looks EXACTLY like mine - components, wires, heatsinks, etc. only $85, free shipping. what do you think?
  • knuz Feb 07, 2008
    just an update. the aa950... board did the trick. thanks for the help and the encouagement. you saved me some big $$.
  • Anonymous Feb 18, 2008
    This sounds like my TV! Red "shadows". Is this board easy to replace (for a lady)? My TV is about 5 to 6 years old.
  • kroakinmike Mar 14, 2008
    green looks all square but the red color dips on onside of the screen and shoots up like an skate ramp on the other. Even when looking at "video 2" message floating on blue screen you can see a definate red shadow. How easy is it to fix this?
    Genius:
  • 1,694 Answers
Red Convergence IC bad.....small circuit board by itself up
above main boards..........replace both IC's for reliability...
STK392-040.........DO NOT USE GENERIC IC'S ! I use only
PANASONIC brand = no re-calls !!
Re-align when repair complete............T.
Posted on Jan 28, 2008
  • Vista Electronics Jan 28, 2008
    How about replacing the board...that would be easiest....
    Part # BP95-00142E..... source = J & J International,Inc.....
    Cost about $75.00......board is mounted at CRT level by itself
    and unplugs easily...............................T.
  • Vista Electronics Jan 30, 2008
    Go For It ! Sounds like you are on the right track !
6ya staff
SOURCE:
TV goes off suddenly. Searching for connection.
'Searching for connection' sounds like it's looking for a network link. check your internet connection. If it's supposed to be watching cable or broadcast TV, check the setup menu.
Oct 21, 2014 | LG 37LH40 37 in. LCD HDTV
JVC AV-56WP74 Colors quit working or went out of balance.
Guns or CRT are probably ok. Your TV needs a convergence IC STK392-120 replacement. Lamp are used on LCD and DLP rear projection TV's. Color wheel are for DLP's. :)
Dec 26, 2009 | JVC Televison & Video
While watching the tv, there was a sudden loud, sharp pop, sounding like a gun shot, and the picture went blank
Sounds like either something went pop on the main pcb or in the power supply. Will need a repairman to take a look. & Just a caution if you're feeling adventurous, don't do it yourself unless you know what you're doing!!
May 01, 2009 | Televison & Video
Watching TV and top 1/3 screen ghosted by colors
on this type of tv each gun is controled by hor.and ver. chip together. it is on the board that controls the convergence of the tv. some manufactors have recalls on problems like this. i dont know if this one does but it may. you can check with mitsub. i do know that this part is about 250.00
Jan 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
TV suddenly shut off, blinking red light in power button
The TV's power supply capacitors probably went bad.
Check with a mobile tv repair co. to see if it is worth fixing.
Dec 20, 2017 | JVC GD-V502U 50 in. Plasma Television
Samsung 61" DLP TV color issue
The color wheel is either defective or needs to be re indexed.
May 18, 2008 | Samsung HLN617W 61" Rear Projection HDTV
TV Flikers and StandBy Light Flickers
Your pdp panel sounds faulty - Count the red flashes this is an error code.
Nov 13, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Picture suddenly went dark
Hi, Apparently you have a possible component failure with your Panasonic PVQ-2510. This would involve the circuitry at the back/neck of the picture tube. Diagnosis would require familiarity with discreet components, use of a VOM, soldering and general component knowledge. In as much as it is possible that your red drive transistor (or an IC) would require replacement or resoldering, your best bet is to seek the services of a qualified professional. Should you venture to do a do-it-yourself, pls post back. Good luck and kind regards.
Oct 02, 2007 | Panasonic PVQ-2510 25 in. Combo
Red diagonal spottted lines
These are called retrace lines they occur because of the blanking pulse not turning off the electron guns in the picture tube during the retrace period. Since this is occuring with the red gun there may be a proble with the video circuitry connected to the red electron gun of the picture tube. This would include the red amp and the red driver transistors. You will need a schematic and a multimeter to properly test these items.
Aug 03, 2006 | Sony KV-36XBR400 36" TV
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
132 people viewed this question
Top Akai Televison & Video Experts
KISHORE DESHPANDE
Ekse
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
