Question about Yamaha RX-V530 Receiver
HELP ME!!!!!!!!!!!!!!!!!! Whenever I go to power on my receiver it shuts off after about 2 seconds. I haven't been home than came back to this.. any solutions?
  • snowbumswerd Jan 28, 2008
    thanks. I tried the unplugging mechanism, but no luck. I'm about ready to move on to the other problem. Hope it works, I need my music back.
  • 201 Answers
Hey there snowbumswerd, a power surge may have caused the problem you are experiencing. Some higher end receivers will protect themselves from damage by setting off a breaker switch. The breaker should reset if you unplug the unit from its power source for one minute, and plug it back in. This is the easiest of all fixes. The next option is to check inside for blown fuses. Please ensure the unit is completely powered down and disconnected. They may not be obvious so look carefully. Also you can check your capacitors. They are the tube shape things that look like small batteries sticking off the board. If the top of any of these has lost it's flatness or erupted, then that is your problem. You should use a professional if this is the case. Relatively simple to fix and therefore inexpensive. Hope it helps. Good Luck!
Posted on Jan 28, 2008
What can i do to stop the red light blinking for marantz sr5007?
Turn off the power using X.
2 Press X ON/STANDBY while simultaneously pressing PRESET CH + and PRESET
CH -.
3 Once the display starts flashing at intervals of about 1 second, release the two
Aug 09, 2014 | Marantz SR5007 Home Theater AV Receiver
The receiver shuts down when zone 2 is turned on
Disconnect the speakers on Zone 2 and try to turn on the receiver again. If the receiver works, there is a shorted speaker wire, pinched wire, or a blown speaker on zone 2. Good Luck
Jul 01, 2007 | Yamaha RX-V657 Receiver
JVC car audio cd receiver model # KDR-310 will not stay powered up. Shuts down after 2 seconds. What's wrong??
hi marnie, if all the power and speaker cables are connected correctly, then you might have a faulty or shorted speaker in the vehicle.your unit is sensing a fault condition. check the impedance of eack speaker connected to the unit from the harness plug. if this does not help then your unit needs to be bench tested.
Yamaha RX-V595a receiver shuts off 2 seconds after its powered on
The first thing called out is the impedance switch on the back is not fully in one or the other position. Cycle the switch back and forth to make sure it will 'read' each setting, then turn it on.
Also make sure you if you have anything connected to its convenience outlets that they are not drawing more current than is allowed.
Did you buy it used or new?
Mar 09, 2010 | Yamaha RX-V595A Receiver
When I plug the stilleto into my car adapter it shuts down. Then powers back on to a screen that simply reads "Sirius Connect"
I had the same problem with my home dock, it worked after unplugging the power to the dock for a few seconds
Dec 07, 2009 | Sirius Stiletto 2 Portable Satellite Radio...
Lightning Last Night Nocked The Receiver Out.
leave unpluged overnight. usually capacitors hold charge and will release slowly. try that if doesnt work powersupply is bad.
Jun 03, 2009 | Yamaha RX-V861 Receiver
After turning in my receiver, it immediately turns back off.
Sounds like it's going in to safe mode. This can be caused by a number of things but the first thing to look at is a failed output amp.
May 03, 2009 | Onkyo HTR500 Receiver
Protect mode shuts down the receiver
If this happens only when connecting the receiver, chech the receiver cable. If the cable is fine, receiver connector at the back of receiver is faulty.
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Dec 23, 2008 | Samsung HTZ-510 Theater System
Yamaha RX-V530 Receiver Logo
151 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
