Question about Samsung HCL4715W 47" Rear Projection Television
Samsung HCL4715W 47 in. Rear projectio
When I turn the tv on the colors are blurry (so is picture). Its like I put on somebodys eye glasses......When I turn the the tv off I can see a red line the goes from the top left to about the top middle...any suggestions would be greatly appreaciated
I miss my big screen Steve...
  • 3 more comments
  • whasup57 Jan 29, 2008
    donteck , yes the on screen menu is good.And yes to seeing double images of red green and blue..And yes the tv gets very high usuage ....
    I stopped by a repair place and they said it sounded like a convergeince (?) if I took the set to them it would cost about 300-350...does this sound about right?
    thank you
  • whasup57 Feb 03, 2008
    Hi Don,
    Yes we do get double vision - actually it looks like triple vision of difference colors not lined up on the screen. Yes it is a HIGH usage set in our home! How much should we expect to spend to fix and is it worth fixing? Can I fix myself by buying a parts and repair manual?
    Steve
  • GrnFuzzyScrn Feb 19, 2008
    I'm seeing a blurry green shadow. None of the manual adjustments are working. I'm not tecnically saavy enough deal with convergence parts, etc. How much should I expect to pay a repair technician? I'm in the Atlanta metro area. Thanks
  • kra-z Mar 21, 2008
    Is there a way to fix the double vision our selves?
  • DON BLACKSTONE May 11, 2010
    IS THE ON SCREEN MENU GOOD ? DO YOU SEE DOUBLE IMAGE ,RED,GREEN, BLUE, ? DOES THE TV HAVE HIGH USAGE ON IT? IF THE SET HAS HIGH USAGE IT PROBABLY IS THE CRT'S (TUBS). THESE SETS ARE KNOWN TO HAVE LOW QUALITY TUBS IN THEM. AND THEY LAST 1-3 YEARS.
    DON..
  • 21 Answers
IF YOU HAVE DOUBLE IMAGES YOU CAN GO IN THE MENU AND TRY TO ADJUST THE CONVERGENCE, OR US THE AUTO JUST. ON SOME SETS IT IS ON THE FRONT. IF IT DOESN'T CORRECT THE PROBLEM THEN IT IS CONVERGENCE. I REPAIR 2-3 A WEEK. WE DO IT IN THE HOUSE, NO NEED TO TAKE THE SET OUT. MAKE SURE THEY REPLACE BOTH CHIP'S AND THAT THEY USE ORIGINAL PARTS, THE GENERICS DON'T HOLD UP. THEY USUALLY LAST 3-5 YEARS DEPENDING ON THE USAGE OF THE SET.
DON..
Posted on Jan 29, 2008
  • DON BLACKSTONE Feb 03, 2008
    YES. WE CHARGE $305 DONE IN THE HOUSE...
    DON..
  • DON BLACKSTONE Jun 15, 2008
    IF IT IS CONVERGENCE IT IS NORMALLY $300-$350. BUT THAT INCLUDES THE HOUSE CALL I DO IT RIGHT THERE IN THE HOUSE. I DON'T LIKE MOVING THE SET'S . THE MORE YOU MOVE THEM THE MORE CHANCE OF SCRATCHING THE SCREEN AND CABINET. TO CHECK IF THE SET PAYS TO FIX, GOTO THE CONVERGENCE ADJUSTMENT IN THE MENU AND LOOK AT EACH COLOR, RED, GREEN , BLUE. IF ANY OF THE COLORS ARE NOT SHARP (IF THE CROSS IS BLURRY) THEN THAT CRT IS NO GOOD. THEY CAN FIX THE DOUBLE IMAGE BUT YOU WILL STILL HAVE A BAD CRT(S).
    DON.
HCL4715W 47 in. Rear Projection Television: My tv has an overlapping picture and the colors ar...
You have a bad convergence board. Replace two of the STK 392-040 ICs. And check all the resistors that are next to these ICs. Rplace the resistors as neccessary. This will repair your TV. Thanks for asking...sorry it took so long to find you!
May 17, 2010 | Samsung HCL4715W 47" Rear Projection...
HCL4715W 47 in. Rear Projection Television: Wheb the TV is turned on the screen is fine, howev...
Yes,this tv can be fix it have convergence problems.The convergence board the 2 STK covergence ICS are defective and some or all it resistors are dead.The shop will cost u $300-350 for parts and labors.
May 16, 2010 | Samsung HCL4715W 47" Rear Projection...
Wavy colors across the screen and the color has separated. ghosts on picture -four eyes ect. I can't adjust the convergence.
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Samsung HCL4715W 47" Rear Projection...
I was watching my HCL4715W TV and the picture
It sounds like one of the convergence Ic chips is bad---you will need to locate and replace both of them and look for any damaged parts around them; there usually are two pico fuses in this area, one for each IC. The fuses do not look like glass fuses--they usually are green or orange in color and will have the amperage marked on them and on the top of the circuit board.
Aug 09, 2009 | Samsung HCL4715W 47" Rear Projection...
Power light is on T.V. is not responding
u may have a bad convergence board stk392-040
Apr 30, 2009 | Samsung HCL4715W 47" Rear Projection...
HCL47154 47IN REAR PROJECTION TV
sound like one of your tubes went dead..
Sep 30, 2008 | Samsung HCL4715W 47" Rear Projection...
Using the component 2 outlets
please read your owners manual for the samsung ptv to determine the best input to use and possible proper settings to adjust in your menu's.
Nov 15, 2007 | Samsung HCL4715W 47" Rear Projection...
HCL4715W Rear projection "Red" color is dim
screen adjustment,remove front bottom cove and find the focus block the screens are also on the same block,if your not sure don't try.
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
New PCB SUB - But blurry and color off.
have you tried to also adjust the lenses to fine tune the focus .
HCL4715W Rear projection blurry
The focus controls on this set are in the front behind the bezel. I'm not sure, but, I think on this age of Samsung, the screws to the front bezel are on the back side of the set. After removing the screws from the back, the front bezel snaps off and the door behind the bezel need to be removed. Watch the wires connected to the bezel, they need to be attached in order to turn on the set. The focus controls are on a black control block (there are three of them, one for each color). Adjust each color for sharpest picture. I use words on the screen for alignment. Each CRT board has a screen control (Adjust each slowly until retrace lines appear on the screen and then back off until they disappear). You may turn off the color and make sure that the picture is black and white. If it is not, then, which ever color is dominant, back it off a bit with that screen control. Facing the set, Red is left, Green is middle and Blue is on the right. Use only one hand inside an operating television. Do not touch the board, just the controls. This concludes television alignment 101. Any questions respond to this post and I'll reply.
Aug 26, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
144 people viewed this question
Jerry Greenberg
Jerry Greenberg
