LG Flatron L222WT
I recently purchased an LG Flatron L222WT Monitor. I hooked it up (analog) to my Gateway GT5432 computer and it will work for about 5 minutes and then will go black and then it will show up with an odd white pattern. I'm running a Nvidia Geforce 8600GT video card and have 4GB of RAM. I have no problems with my Acer 17" LCD but just can't get the LG to stay up and running for longer then 5 mins
  • 1 more comment
  • Rain840 Feb 09, 2008
    hey my LG Flatron Widescreen i dont know the model number it could be L222WT or WS it was working fine on xp with 1680by1050 resolution now i can't get it on vista 64bit any suggestion
    i have the same monitor i was getting its maximum resolution 1680*1050 i then installed vista 64bit and the monitor doesnt show its real sesolution
  • techguy588 Feb 21, 2008
    The monitor will be working than it will just go dark. If i look closly i can see the image. Is this a product defect? Should I return this monitor? It was on sale.
  • 44 Answers
Check the memory IC, Horizontal-vertical IC then check the processor voltage are the stable & is it support the refresh rate. at last check the EHT transformer, may be your processor controlled through it or it loses the flyback voltage .
Posted on Feb 07, 2008
Hp monitor 2031s does not scan signal from gateway gt5432...
Go back to Dell monitor. Remove any video drivers from hp.change video resolution both in windows and in video card settings to standard 1024 x 768 (yes it will look horrible) then hook up hp monitor. Don't install drivers if prompted get them from hp website then adjust resolution through video card settings after drivers installed which probably require restart.
Dec 01, 2013 | HP Computers & Internet
Can't get monitor out of energy save mode
you talk about a dell monitor but categorised under LG monitor... if it's a Dell monitor, and its recent, it's possible you've put it in analog/digital mode when you need the other mode. push the left button on te front of your screen that should switch your screen from digital to analog or vice versa
Dec 28, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Screen stays in analog mode
analog usually means its hooked up via VGA cable
digital means its hooked up via DVI cable
Sep 04, 2009 | LG Flatron L1750S 17" LCD Monitor
LG Flatron W2252TQ 22'' monitor not working in digital mode
try to set your screen resolution to maximum using Display Settings in windows. Besides, are all software drivers for this monitor loaded and properly installed? Right click My Computer=>Properties. select hardware => device manager. Make sure video icons are not marked with question marks. if they are, install monitor drivers shipped with your monitor.
Jul 26, 2009 | LG W2252TQ Monitor
Analog- out of range
boot PC into safe mode, (pressing f8 on startup) then go to display settings and switch resolution to 640x480 (basic setting)
then reboot into normal mode, and then go to display settings and then choose an appropriate display resolution
this is caused when you replace a monitor as the old monitor ma have had different capabilities from the new
Feb 25, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
LG FLatron W2252TQ Not working properley in DIgital mode.
Fixing power problems with your LG Flatron Monitor (LG1753S) ' Just ...
Fixing power problems with your LG Flatron Monitor (LG1753S) ... So after checking the power isproperly plugged, I shut down my pc again. .... I can start a game and then change the resolution, Popp of "energy saving mode digital" led goes ..
Mar 21, 2017 | Computers & Internet
L222WT flatron 21.6 monitor is not working
Power saving is the default the monitor goes into if it doesn't get the correct signal down the cable wires of the computer. There might be three culprits:  (1) the cable between computer and display (most likely), (2) the display itself (unlikely since you see the LG logo) and (3) the graphics card inside your computer.  #1&2 are easy to check by swapping with a friend for troubleshooting. #3 is tricker and more expensive and might require a savvy friend or a computer repair service (between $60 and $100/hour for labor) plus between $40 and $80 on for a new card depending on whether you need a analog or digital one. Don't waste money on super costly cards unless you use your computer for gaming.
Dec 29, 2007 | Computers & Internet
Computers & Internet Logo
1,526 people viewed this question
David Payne
David Payne
