Question about Asko D1706 Built-in Dishwasher
Asko d1706 dish washer
Water wont go on, i think it my be the solinoid valve,but if there are other things that could be causing the problem id love to know. thanx dave
  • 4 more comments
  • banff Mar 04, 2008
    Similar problem, when start water pumps out (as nonrmal) but never switches to add water. regardless of selected cycle, keeps pumping out even though no water in machine.
  • Anonymous Aug 11, 2008
    Water entering machine to heater elements but will not go any further will not wash or turn spindels will empty ok. suspect circulation pump any other suggestions.
    Water not circulating around machine comes in to heater element level but will go no further.
    water drains out ok
    Suspect circulating pump.
  • adzarr2 Jan 22, 2009
    no water is coming into the dishwasher
  • russhouck Apr 02, 2009
    Water will pump out, just will not fill. I don't hear the solenoid humming. I see there are two inlet valves. Do I order both to correct the problem?
  • nephi01 May 11, 2010
    This is fantastic. I have same problem and have a pan full of water. I will clean up but...How did the water get there in the first place?
    I'd like to prevent in the future because it's a pain to pull the machine and clean out the pan. Thanks very much!!
Our D1706 dishwasher had similar problems to the above - would not go through its normal cycle because the drain had clogged. I have just fixed it by removing the 550mm by 130mm access panel at the lower-back of the machine. This is done by removing four tamper-proof screws - a six pointed star screwdriver bit is needed. Then old towels were used to soak up all the water lying in the bottom of the machine. I then used a hacksaw to convert the tamper proof screws so that a normal blade screwdriver may be used in future.
Posted on Aug 12, 2009
i used a shop vack to remove the water in the pan and it fixed the problem.
The problem was caused by the drain pipe of the dishwasher that was clogged.
Thanks Timon90
Posted on May 22, 2008
  • 126 Answers
Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so.
Posted on Jan 28, 2008
Water sounds like its comming to dishwasher after awhile dial turns(timer) disher wsher goes in to dishcharge pumping out water but inside of dish washer seems dry like no wash cycle took place
Look inside the dishwasher for large plastic mushroom-shaped thing in the bottom. This is a float. Sometimes a knife or fork or something else gets in the bottom of the dishwasher and won't let the float go down. When the float is up like this, the dishwasher thinks that it is already full of water, so no water pumps in.
If this is the case, simply remove whatever is blocking the float from going down, and it will work again.
Feb 28, 2011 | Asko D1706 Built-in Dishwasher
Asko d1706- drain pump keeps running at the end of the cycle, even in the Off position. Water sometimes remains in the bottom of unit. Any clue
There was a small leak when I re-installed the pump causing water to accumaulate in the base. By reading on your site, I realized that this is normal and expected, for the event that a leak occurs, the pump stays on to purge all possible water.
Thank you
Dec 23, 2009 | Asko D1706 Built-in Dishwasher
My asko D1706 dishwasher will not fill with water or drain.
it could be the float ee if detergent is causeing it to get stuck see if you can move it up and down and you may also have a clogged inlet valve or faulty valve,chec both hoses also it could be a clogged pump.
Dec 01, 2009 | Dishwashers
2 problems 1- dishes coated with white-ish film that won't rinse off, has to be hand washed with soap to remove. 2- heating element isn't heating up at all
The problem is hard water. Go to They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Nov 13, 2009 | Asko D1706 Built-in Dishwasher
No Water
Water on lower bottom will cause the machine to drain all the time. Leakage or blocked drainpipe can cause this. When you dry out the water on the bottom it will sart as usual.
Jul 23, 2009 | Asko D1706 Built-in Dishwasher
ASKO D1706 ... where is the control temp. for element for more dryer ?
you cant ajust the temp its thermostat control,if you want it to dry at end of cycle use rinse aid and open the door at end of cycle to let the steam only have a 55 or 65 wash button on right side next to timer knob.
Feb 03, 2008 | Asko D1706 Built-in Dishwasher
Asko D1706 Built-in Dishwasher Logo
704 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
