Question about Sony Ericsson Z800i Cellular Phone
Formatting memory stick for a Sony z800 mobile.
Bought a 2nd hand memory stick for a sony z800. How do I format it? I also can't get internet services on my phone, please help.
I have the same z800 just like yours. and i also formatted may mem0ry stick. just go to settings, then general then select Format Memory Stick. it will just take a few seconds.
Posted on Apr 21, 2008
  • 871 Answers
What you can do is look for a card reader that your memory stick can be read, after, you can plug that to your computer and simply format it.
Posted on Jan 28, 2008
Bought a sony dsc h300 camera about 2 years ago...bought a Kingston Memory card for it....what do I do now ?
Have you tried formatting the new memory card? Sony suggest you format a new card using the camera.
Supported capacity:
  • Memory Stick Duo" media: up to 64 GB
  • "Memory Stick Micro" media: up to 16 GB
  • SD card: up to 64 GB
  • microSD memory card: up to 64 GB
You may also want to check the camera's user guide to narrow down what's causing the card not being detected.
http://docs.esupport.sony.com/dvimag/2014/DSCH300_guide/en/contents/12/01/04/04.html
Jul 08, 2017 | Sony Cameras
Tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
on Apr 18, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
Memory stick formatting error
try formatting the stick through the camera itself. else download the software of camera and connect it to pc and see if it has any formatting options...
Apr 01, 2014 | Sony Cyber-shot DSC-W120 Digital Camera
Internal memory formatting error to sony DSC-T2 camera error c:13:01
In DSCT2 Camera, the C:13:01 error message indicates a Self diagnostic message. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Internal Memory or with the Memory Stick.
The Symptoms are:
1. Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
2. Unformatted "Memory Stick Duo" which can be resolved by formatting the MS in the Camera.
3. "Memory Stick Duo" is broken or not compatible which can be resolved by inserting a new compatible MS.
4. There may be an issue with the Hardware part also, which can be resolved by the technicians.
Try turning the power off and on again, or taking out and inserting the "Memory Stick Duo" several times may also help in resolving the issue.
Thanks.
Oct 21, 2010 | Sony Cyber-Shot DSC-T5 Digital Camera
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
Sony memory stick PRO Duo is not working
try formatting it on a pc in FAT file system or run a deep scandisk
May 03, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Sony cybershot dsc-n2
I see the same type of reports on the internet for just about all types of Sony cameras.
It can occur when a memory stick goes bad or when the camera memory stick reader has a problem.
First try a reset of the camera.
You will have to check the User's Manual to see how to do this.
Next try a new (or different) memory stick and see if you get the same bad result.
If you do, it is likely the problem is in the camera.
Sony will probably want about $200 to fix the problem.
Jan 06, 2009 | Sony Cyber-shot DSC-N1 Digital Camera
128mb Sony Memory Stick Duo
            This is a common problem and its quite easy to resolve.
I had a very similar problem with a friends nokia 5200 memory stick , it refused access to the card , i got the message disk is write protected I couldnt even access it from a PC card reader or format it .
             Somehow he had accidentally set a security code for the memory stick and the mobile then forgot he had done it , I tried the usual code of 1,2,3,4 and this didnt work.
        When I tried the number 1 on its own , suddenly I could access the memory stick again and format it and didnt get the message (disk is write protected)...Reset your P800 security codes with the master reset function in the main settings menu.This will remove any codes that restrict access to the memory stick...
Sep 03, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson Z800i Cellular Phone Logo
145 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
